Tire balance problems!!! - YotaTech Forums
Go Back   >
Click Here
LinkBack Thread Tools Search this Thread
Old 01-24-2003, 07:54 AM   #1
lilwily's Avatar
Every time I take my runner to get the tires balanced....I have to
take it back and watch the shops every move. They have to be
perfect or I make another trip back. They (discount tire in
Houston) always say it was close....but on these 2nd gen runners
it has to be perfect or you feel it at 60mpg.
Anyone else had this.....?
Wily
lilwily is offline   Reply With Quote
Old 01-24-2003, 08:12 AM   #2
bbarggren's Avatar
Hey......as luck would have it, I was just reading about this problem, and found a GREAT website that goes into detail about why this problem exists, and how to fix it for good. Go check it out...
http://www.gadgetonline.com/vibration.htm
bbarggren is offline   Reply With Quote
Old 01-24-2003, 08:27 AM   #3
Churnd
Guest
Posts: n/a
your best bet is to get your local dealership to do it. i know it's more expensive but they'll do it right. unless you know a shop that can balance tires lug centric.
Old 01-24-2003, 08:47 AM   #4
Rick F.'s Avatar
Location: Far western Kentucky (transplanted from central PA)
bbarggren hit it on the nose. you can go to www.gsp9700.com to get locations that have the GSP9700 near you.
If it helps any, we all seem to have this problem.
Rick F. is offline   Reply With Quote
Old 01-26-2003, 01:00 AM   #5
toddowaddo's Avatar
Same problem when I bought tires at Sam's (never again). Toyota dealer made them right though.
toddowaddo is offline   Reply With Quote
Old 01-26-2003, 09:11 AM   #6
YoungFeller's Avatar
Tire balance has been a constant battle for me. Once I had a set that ran pretty well. Then I (like the moron I am) wanted to try something different. Ever since I traded in that set, I haven't found anything that works that well. (I think it's punishment for not sticking with what I had)
I'm using Equal now but my tires are retreads and there's only so good they can get. Equal's more expensive than I thought it'd be, but it helps.
It's tough not to have weights pulled off the rims on trails. That's one way to frequently go out of balance.
Eric
YoungFeller is offline   Reply With Quote
Old 01-26-2003, 09:10 PM   #7
Another thought
I thought I was having trouble getting my tires balanced. Discount has the Hunter machine too.
Turns out it was my brakes causing the shaking (warped rotors/ drums).
Mike
mhawker is offline   Reply With Quote
Old 01-27-2003, 09:27 AM   #8
DavidO06's Avatar
hey, where in houston is the discount tire. I have had the same problem. I'm not sure if it is just my tires or if it is them. I have all-terains, and they may be too difficult to balance correctly. The discout tire i'm talking about is off of 1960.
DavidO06 is offline   Reply With Quote
Old 01-27-2003, 08:37 PM   #9
williemon's Avatar
I have my tires on the runner balanced on the vehicle with a spin motor. If theres a high spot in the tire, they will cut it off and true the tire. For about 40 to 50 thousand miles of my michelin ltx at tires life, they ran with NO weight at all and was as smooth as glass all the way up to 90mph. Now that their past 50k, they need just a little square stickon.
williemon is offline   Reply With Quote
Old 01-28-2003, 06:58 AM   #10
lilwily's Avatar
David,
The Discount I took them to was on hwy 6 north in Coperfield.
I did take it back and they put them on that new machine. They
hadto break all the tires down and spin them on the rims. Then
they balanced them again. It seems to ride better now....but I
will have to get it on the frway to see. Why wouldn't they do this
when you first buy the tires? It is normally 10.00 per tire, but they
didn't argue when i complained a little. I do have almost 10k
miles on them......they could have done this from the get go!
Wily
Flying91's 1991 4runner LOWEST SAS 30" tires Flying91 86-95 Trucks & 4Runners (Build-Up Section) 31 01-14-2017 09:27 PM
White tire letters in, or white letters out? Scenic WonderRunner Off Topic Talk 36 03-03-2016 08:37 PM
Why are Toyo tires so tough to get? BushPig Tires & Wheels 3 11-28-2015 11:38 AM
What to do with old tires and wheels? DrZero Tires & Wheels 2 07-13-2015 10:59 AM
BFGoodrich All Terrain T/A KO2 or Goodyear Wrangler Duratrac Tires djpg2000 Tires & Wheels 0 07-11-2015 08:26 AM
Tags
balance, balanced, balancing, bay, discount, green, highlander, issues, ongoing, problem, problems, shaking, tire, tires, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
