| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
PSI w/ Mud Terrian???
__________________
-Jake 1990 4Runner <> 1990 Toyota 4Runner-22RE-5 speed-TG 3" front/4" rear-35" BFG M/T-4.88's-rear LSD-front TruTrac-MC Rear Bumper-TG DOM Sliders-TG Front Bumper SAS Build-Up Old Rigs: '85 4Runner (RIP) '95 4Runner (sold) |
#3 (permalink) |
this is a very subjective question, there is no set psi for anyone to run every tire at.... no 2 situations or vehicles or conditions are ever the same.... industry standard on a truck/suv is between 30-35 psi with 32 being the general rule of thumb
i currently have 31s on my truck and i am running them @ 50 psi which is the max for the bfgs i have, for best fuel economy, eventually this will wear down the center part of the tread, but i have mroe tires in the backyard i can switch to when that happens..... tires vary in max pressures so check the tire itself for max inflation... some max out at only 35 psi, otehrs 50, others more Last edited by jimabena74; 10-04-2005 at 12:40 AM. |
#4 (permalink) |
32psi
__________________
87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders 190XXX miles |
#5 (permalink) |
I run 32 to 35 Highway and Air down to about 25 off road. Depending on the terrain of course.
__________________
1990 4Runner 4x4 3.0 Auto. Sitting on 31X10.50 Baja Claws, Aisin manual hubs, OME shocks & coils. Optima Redtop, 40 Series Flowmaster and High flow Cat |
#6 (permalink) |
with my 36" swampers, I run about 28 for normal conditions. I tried 35 on the highway and it was too stiff and rode bad.
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#7 (permalink) |
On my AT's, I run 38 but they're brand new and I wanted to try out a couple of different psi's before I stuck to one. 34 is next and according to Jason B, moving from 32 to 34 for him gained him 2 extra mpg.
#8 (permalink) | |
285 MT/Ts 35 psi on road
__________________
Eric 88 4runner Quote:
#9 (permalink) |
My Kumho MT's have a max load rateing at 50psi. When hauling in my pickup i run 45-50psi. fronts are 35-40
trail pressures in the 18-25psi range depending on how much ground clearance i need
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#10 (permalink) |
so for better mpg, run the tires closer to max pressure?
__________________
#11 (permalink) |
35 Psi.
__________________
-Glenn- |
#12 (permalink) | |
Quote:
that will get better mpg, but at the sacrifice possibly of ride quality and tires going bald in the middle mroe than the edges |
#13 (permalink) | |
Quote:
The only thing that comes to mind with 50 P.S.I. in your tires is an increased change of a blow out. You don't drive to save gas.
__________________
-Glenn- |
#14 (permalink) | |
Quote:
what is my increased chance of a blow out? the tires are rated to have 50 psi cold in them.... i actually run 44 psi cold... but used 50 as a general number... i don't drive t osave gas, however, i do a lot of hiway driving and at the pressure i run at my truck is awesome on the highway.... the 3.07 gears and the around 31" tall of my 31" tires helps out on gas mileage and top speed |
#15 (permalink) |
i run mine at 20 psi
__________________
-Geoff *1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi. |
#16 (permalink) | |
Quote:
__________________
-Glenn- |
#17 (permalink) |
Lessee, I have 15.5 in one, 21 in another, those are the rears. Then 18.5 in the right front and 37 in the left front. After I get the 'steering' and 'alignment' and 'rear diff whine' problems fixed, I'm adjust that air pressure...Might even buy some new tires, get all 4 of them the same size this time...
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil Last edited by Flamedx4; 10-04-2005 at 03:14 PM. |
#18 (permalink) |
thats why I said the closer you are to the max pressure, obviously its not smart to run them at max psi. the rest is just personal prefference of ride credability...
__________________
#19 (permalink) |
thatnks for helping me process...
__________________
#20 (permalink) | |
From this site I found out about the "chalk test" and tried it out on my BFG A/T's. I found that around 45 psi was the optimal for my tires. Too much and the center will wear quickly and give a rough ride. Too little the outside tires wear faster and loses gas mileage.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can. Quote:
#21 (permalink) |
I seem to recall that the findings involving Ford Explorers rolling over and playing dead on Firestone tires were because of under-inflation; people airing down to get a better ride. We're talking about trucks and 4Runners here. If you can't handle a rough ride buy a sedan.
As for me, I run mine at 50psi. |
#22 (permalink) | ||
Quote:
Bingo
__________________
#23 (permalink) | |
Quote:
Bingo. When I put on new tires, I just watch as the nubs wear off. Adjust until the tread surface wears evenly. Note that on really big tires this isn't really possible. My 35s would need to be at about 12 pounds to get even wear. Rides like an old Honda 3 wheeler (bouncy bouncy mushy bouncy) at that kind of pressure, plus consumes gas like crazy. Rides the best at about 40, but then wears out the center of the tread face really fast. So I compromise, and rotate often.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Mud terrian tires? | Nebrkid817 | Tires & Wheels | 20 | 03-28-2008 05:32 PM |
| mud terrian tires- wider is better? | shantz | Offroad Tech | 38 | 07-25-2006 07:59 PM |
| mud terrian tires- wider is better? | shantz | Tires & Wheels | 38 | 07-25-2006 07:59 PM |
| Mud Terrian Tires for my new Runner | Stump1883 | Tires & Wheels | 35 | 04-11-2006 06:09 PM |
| Goodyear MT/R's and Mud Terrian Tires in General??? | Stump1883 | Tires & Wheels | 10 | 07-04-2003 07:52 AM |
