| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#101 (permalink) | |||||
Tire Size
#103 (permalink) |
he speaks the truth
![]() um, did you get lost in Antarctica?? -40! holy cow. I've seen some reviews showing they ride smooth and handle well in about 0 degrees. Other than that I do not know. If you cant pass up the deal I would use them for a winter tire and just switch back to your Firestones at the end of season.
__________________
Silver '99 Toyota 4Runner Limited RP Black Widow Rack|8K R.S. HID Kit|265/75 Federal MT|Cobra NightWatch CB|Fosgate Sound|24" Magnaflow|DeckPlate Mod & KN|Fog Mod|Bumper Light Mod|Altezza Tails|Clear Corners & Turns Lift Here Armor To Come Check out my Photos |
#104 (permalink) |
mmhmm gets cold like that in parts up here
![]() FYI -40C=-40F I think dedicated snow tires will outperform A/Ts in on-road compact ice if that is the primary use.
__________________
My Build Thread The 4Cruiser: 98 4Runner SR5, 5VZ-FE, Sonoran Steel 1.2, BCC custom swing-arm rear armour, full Budbuilts, 285/75R16 Goodyear Duratracs, extended diff breather, airbox deckplate, red LED cluster, console,Wabfab front discos, Warn M8000 winch, Shrockworks full hoop, PIAA 520s and 510s, Stubbs HD-SKO Sliders, External tran cooler, tundra brakes and 5.29s and ARB lockers next |
#105 (permalink) |
Primary use would be city driving in the Edmonton Area. If I take it slow, I know I'll be ok. I may be making a trip or two through the mountains to see my siter in Vancouver though. That's when I'll see a difference.
#106 (permalink) |
wats the difference between the regular 4" lift and the stage II, i dunno which one i have i bought the lift kit used off ebay???
#107 (permalink) |
and howcome i have to regear so high, wats wrong with the stock gears??
#108 (permalink) |
Max Tire Size
I have a stock 94 4runner SR5 with it's standard tires installed..
What is the max tire size that can be installed on her without doing any mod's? 32 / 11.5 ? |
#109 (permalink) |
Your gong to bigger tires, without a regear your vehicle will be the dog of dogs...
It will be Slow, to put that in a different set of terms.
__________________
04 4Runner - Sold 97 T100 - Sold 86 Runner - Project - Sold 02 Mustang GT Vert - Stuff done, 181 GPS confirmed miles per hour on Autobahn A-5 between Stuttgart and Hockenhiem:) For Sale 92 4Runner 3.slow - little lift, ISR, Dynomax catback, manual hubs conversion, Downey rear springs, more coming count on it... |
#110 (permalink) |
Stage II comes with more hardware on it in the Front - look on like 4wheelparts.com and copare the kits, or go to procomp's site and compare them, not much difference but the Stg II just has a little more beef
__________________
#111 (permalink) |
33x10.50" The width is what kills clearance.
Try searching next time, probibly the most common question asked
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
#112 (permalink) |
I run a 4" pro-comp lift (Not sure what stage, guy didn't say when I bought it). I run 33x12.5R15s. Stock gears, my truck is a dog. I usually have to leave it in 3rd just to go uphills, and passing other cars on the road is a pain in the ass. I need 4.88s...
__________________
1986 4runner SR5 5speed 22re 155k original miles 4" Pro-comp lift|BFG M/T KM 33x12.50x15|ARB Front w/ Warn Winch|Aisin manual hubs Need: Avid Offroad sliders/Budbuilt skid and crossmember/rear bumper/4.88s/rear aussie/Zuk coil mod Ask me why they call me Duckie. |
#113 (permalink) |
If you have good treads on the Firestone, I wouldn't worry about it. The extra sipings and the softer compound does work better on snow tires, but up in the mountains, the AT's would actually work better in the deeper snow. I don't have any experience with FS AT's but I had REVO's and they worked well. My current BFG KO's work better, though. If in doubt, just get a pair of chains or cables.
__________________
01 Tacoma DC TRD OR 4x4 |
#114 (permalink) | |
Quote:
How cold does it get in CO though? My concern is the -40 degree celsius temperature make my tires like a brick. I would imagine that it would be a bit warmer in CO than in Alberta/BC |
#115 (permalink) | |
Quote:
You ever run 33x10.5 and not adjust any of your suspension? |
#116 (permalink) |
Geez, you Canadians always think you live in the coldest, snowiest and harshest environments.
might be right. In Utah, we probably see -5 to -20 C in the benches and a bit colder in the mountains. However, I also spend time up in Wyoming with -20 to -50 temps. No problems thus far on AT's. My opinion, once again--stick with good AT's and carry chains/cables. Don't think some snow tires will magically make your truck unstoppable. I found the difference between my KO's and snow tires is marginal. I have tried just about every one of them, too. (Nokian Hakka, Blizzak, Hankook, etc). Chains are a big step ahead of these tires. Oh, carry recovery gear, too.
__________________
01 Tacoma DC TRD OR 4x4 Last edited by cackalak han; 10-01-2009 at 03:47 PM. |
#117 (permalink) |
Hey Canadian Bacon. I spent a couple of winters in Edmonton. You and I both know that when things get really cold and it snows on top of already hard pack or icy roads it is worth having a proper winter tire. Yes the AT will work for the most part, but when you have to stop on the Yellowhead of Whitemud on pure ice you will be glad to have proper winter tires. Also you should check with insurance, I am not sure if it went through, but when I lived there someone was telling me about insurance putting blame on people in accidents that weren't their fault if they didn't have proper winter tires. I am not 100% on that but it is worth looking into.
__________________
1996 SR5 5speed rear locker. |
#118 (permalink) |
Cackalak, yes ATs work to a degree but when you are driving in city traffic the big difference is stopping. I have driven on good ATs and winters and have not noticed a huge margin as far as accelerating and cornering but I have noticed a difference in terms of stopping ability and the is what matters in traffic.
__________________
#119 (permalink) |
Yeah, I do understand the benefits of a true snow tire. I have used it on multiple cars. But I just don't see any more benefit compared to my KO's. I do take precaution and drive slow and ALWAYS slow down way in advance. Knock on wood, but no accidents on snow thus far. And, BTW, although Salt Lake's roads do stay clear most of the time, the roads in Wyoming are much like the conditions you're describing -- snow on top of ice. My KO's have done great.
Also, the additional benefit I get from AT's is that when the snow gets deeper, I am able to get better traction. The AT's aren't great at clearing mud/snow, but it's a whole lot better than snow tires. Just my observation. Lastly, I don't know if you've used chains/cables, but they trump both AT's and snow tires. It is my opinion that if you have good tires and are prepared with cables/chains, you'll be fine in most instances. Side note: dannomite - which AT tires are you talking about? Nitto TG's were terrible in snow, in my experience. REVO's were ok. BFG's were the best. They also have the Severe Service winter rating, which is also found on snow tires. FYI, just an extra series of tests on snow qualifies them for this. In some states, like Oregon, won't allow a car to pass unless they're equipped with tires bearing this symbol. BFG KO's have this, along with General AT's and a couple more, I think. This is what the symbol looks like:
__________________
01 Tacoma DC TRD OR 4x4 Last edited by cackalak han; 10-01-2009 at 05:09 PM. |
#120 (permalink) | |
Quote:
What isnt wrong with stock gears and big tires?
__________________
87 Toyota 4Runner 22RE--5spd swap (W56)--4.56s--BJ spacers--Pro Comp Stage II 4" bracket lift--63" Chevys w/2" blocks--40 series--late style steering box swap--BudBuilt Dual Case X-member--V6 calipers--32s--MC rear bumper--SAS parts collecting time... 79 Toyota Longbed 4x4 Frame-off Resto time. 04 GMC Sierra 1500 the DD |
#121 (permalink) |
Well, baisicly adjusting the torsions is either loosening them to lower the truck, or tightining them to lift it a little.
If you look at your lower control arms in relation to your frame, they should be parrellel. They shouldn't be at any real angle unless you have a lift. I personally havnt run those tires but its commonly known around here (quite a few guys use them here) that 33x10.50" tires, on stock rims (rims that are wider and/or stick out farther than stock ruin your clearance) will clear with little if any trimming of the inner fender pinch weld. You will notice that your truck is a little slower though...
__________________
#122 (permalink) |
i knew it would slow the truck down but seriously that much??? sry my main build is my camaro, i didnt think it would slow it down THAT much though, its already slow as hell, didnt think it would have made that much more difference.
#123 (permalink) |
If you already think its slow and your putting a 4" bracket lift on, you'll be in the 33-35" tire range, Its gunna be a slug. What motor and trans do you have?
__________________
#124 (permalink) |
v6 5spd,
#125 (permalink) |
Staff
You should be able to throw 42" swampers on there with minor trimming.... Make sure you have the 4.10 gears tho. Your stock cv's will be fine as long as you weld the front diff
__________________
94 4runenr: all the good stuff....... 89 4runner: 3.0, Auto, 5.29 lockright f/r. 31x10.5 wildcountry ATs. 81 2wd pickup: 22R | 5-sp | long bed |Civic SI seats | LockRight | Hella 500s pacific-crawlers.com For all your Trail-gear and HID lighting Solutions Needs check out yotaworks.com Online store coming soon :) |
| Tags |
| 10, 105, 12, 15, 16x7, 1993, 2009, 325x115, 33, 33x125, 33x1250x15, 34, 4runner, 50, fit, good, jeep, recommended, rim, size, stock, tire, tires, toyota, wheel, wheels |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| The official "I can not sleep" thread | Jimmeh | Off Topic Talk | 11 | 10-19-2007 01:56 AM |
| The "Official" 3rd Gen Gas Tank Relocation Thread! | ravencr | The Fab Shop | 118 | 03-26-2007 02:37 PM |
| What does "X" wheel look like on "X" vehicle, and max size tire? | wjwerdna | General Vehicle Related Topics (Non Year Related) | 29 | 03-24-2007 06:24 PM |
| Official : "ITS ALIVE ! ! " thread | NCSU-4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 37 | 04-04-2005 07:22 PM |
| The official "How many miles on this part?" or "Is this normal wear?" thread.... | 4RUNR | 95.5-2004 Tacomas & 96-2002 4Runners | 12 | 11-28-2003 10:10 AM |
