oddball tall/skinny radial tire sizes
Old 03-05-2011, 05:51 AM
wifes4now's Avatar
since 3rd gen 4runners like a tall/skinny tire, ive been looking at some like the 255/85r16 and 255/80r17.
however, on here i was reading a guy has some 305/70r17 GY MTR and it took me a minute to realize that it was kinda taller than normal.
(it should have been 305/65r17, because the standard is for every 1" in wheel increase, the tires aspect ratio goes down 5%).
then i started lookind around and i found both GY MTR and Toyo make a 285/75r18 =(34.8x11.2)
also found GY MTR or DURATRAC and BFG A/T also have a 275/70r18 =(33.1x10.8).
does anyone know of any others - 18" or smaller wheels, (i would like 17" better)?
please list brand and model with the size, plus any experience with that brand, model,or size.
Old 03-05-2011, 06:35 AM
wifes4now's Avatar
i just remembered the j**p OE tires
BFG KM 255/75r17 (32.0x10.0)
Old 03-11-2011, 07:09 AM
rod_knock's Avatar
235/85/16 or 235/80/17 common in lots of brands but mostly load range E havent seen any that arent but they are 32 x 9.25 the 16's are a 7" treadwidth and the 17's are 7.2 i have been looking into these but have no experience with them hope this helps you out
Old 03-11-2011, 07:48 AM
Junkers88's Avatar
The only 255/75/17 that I could find, and that I have knowledge of/experience with, is a Treadwright Guard Dog.
http://www.treadwright.com/c-39-255-75r17.aspx
Not sure if that's the type of tire you were looking for though.
Old 03-11-2011, 06:51 PM
wifes4now's Avatar
i used to have a set of 235/85r16 studs for winter on my F250 powersmoke
i come up with 31.75" for that size, i have 265/75r16s (same size) now i was looking for taller
Old 03-17-2011, 08:00 AM
4byrunner's Avatar
I have heard conflicting opinions about running 235's. Some say they ride okay and some say due to the ten ply side wall they are really stiff. If you run them at half pressure (full pressure is 80psi) then they can heat up and feel a little loose on the road. However these tires comes factory on j**ps and some other vehicles.
Some tire shops won't even install them on your 4runner due to insurance reasons because you see reducing your trucks footprint on the road resulting in less traction. I've been wanting to run 235/85/16 on my 99 runner for a while for winter tires but will most likely get them only for a summer set and run 265/75/16 for winter driving in the snow/ice. I'm thinking about the General grabbers AT2
Old 03-26-2011, 06:55 AM
wifes4now's Avatar
nitto makes a 295/70r18 (34.25x11.6) in both the terra (AT)and trail (MT) grappler
Old 04-10-2011, 06:37 AM
wifes4now's Avatar
hankook, goodyear, and bfg all make some 255/75r17
if i could find some skinny 18" wheeels (they all seem to be 9-10" wide)
i think i might get the 275/70r18 Durtracs (tall 33" x just under 11")
djpg2000
11-11-2020 04:56 AM
jgallo1
10-26-2015 06:39 PM
Gravel Maker
RuffStuff
08-06-2015 04:27 PM
Luvmeye22re
08-04-2015 03:53 PM
coffey50
07-28-2015 10:55 AM
Quick Reply: oddball tall/skinny radial tire sizes
