Nitto Terra Grappler vs Destination A/T - Snow Battle
First off - wanted to thank everybody for playing a role in creating this amazing resource. I'm a new '99 SR5 Highlander owner, and reading through the forum made the decision to buy incredibly easy.
I'll post pics soon, if interested, but first I had a tire dilemma I was hoping you could help me work through:
I'm living in western NY, and the big issue is snow (which is why I bought the 4runner). Right now the tires that came with it are 265/70/16 Continental Conti-SUV. Not bad wear at all, but I'd like something with more bite for the snow/ice roads.
I'm looking at Nitto Terra Grapplers and Firestone Destination A/T's, both in 265/75/16. I searched through the forums and it looks as though Terra Grapplers are well liked, but I was wondering if there was any thoughts in comparison to the Destinations, particularly regarding snow.
If there's a better suggestion, for winter conditions, I'd love to hear it. I was looking at those two in particular because of price (150 each on the car for Destinations, 175 each on the car for Nittos) and I'd prefer to stay around that range.
I'd also love to hear any other winter additions I should consider. I'm looking to build a tank, so any advice is more than welcome.
Thanks in advance.
Thanks in advance.
I've had the Nittos and at the price difference you mention I would try the Firestones.
The Nittos were great, and I'll admit I did not keep them rotated enough. But they wore quickly in my mind.
Wet and snow and ice traction were excellent in the Nittos when new. But at 3 years in I was looking around...probably not the best tire at 3/4 wear. Just my opinion.
Also I want to make you aware that you may experience rubbing of the front mudflaps at the 265/75 tire size. If this is not a big deal for you then so be it. But backing up or sharp turns or compression of the front suspension caused me to remove front flaps to run that size. Others report no issue.
Would love to see a pic of the coveted 99 Runner Highlander edition. Be aware that not all 99s have the taller springs- hence the rubbing issue. My 99 for example had the shorter springs originally until I lifted. No issues at all now with the 4crawler.com 1" body lift.
I would highly recommend doing a lot of research regarding tire tread, the spacing in the voids between tread lugs, siping, etc so that you can tell what what would or would not make a good snow tire. Typically you're going to want something with a lot of siping to aid with snow and ice traction. There are also tires out there (I know that my pro comp mud terrains are) that are pre-drilled for studs, so when winter time comes you can install the studs for the icy junk, and then just remove them when it melts.
The blizzak tires are designed for snowy/icy conditions, though they're not really designed for daily use otherwise. It would be worth seeking out an extra set of wheels on craigslist or something, and get some dedicated snow tires (especially since you live up where it does snow a lot) and then in the spring time, just change back to your continentals
Thanks for the replies thus far -
The debate between an A/T and dedicated snow tire is something I've thought about a good deal. The tossup is that the Conti's are not great tires, and I feel as though, if I got snow tires and kept the Conti's for the other seasons, I'd then be up a creek for anything wet or mud related (wasn't just going to go on trail runs in the winter). Wet is a particular concern - it rains a ton in my area, and not just drizzling.
I'm well aware that an A/T is somewhat of a jack of all trades but master of none when it comes to the seasons, but since I can't afford to get both A/Ts and Winters, it seems that the balance of an A/T would be best year round. That's what brought me to A/Ts like the Terra Grappler and Destination A/T. Am I wrong in my thinking?
Regarding siping - It looks as though TGs have some degree of siping already, if I were to go with that tire would you recommend more?
Going back to the debate between tires - part of the problem is that there isn't really a basis for comparison between the tires. On Tirerack it seems as though Destinations are highly rated, but since Nitto isn't sold through that vendor I can't get a comparison. Thus I submit myself to the Lords of Yota.
Thanks again for all the help.
Pic:
Uploaded with ImageShack.us
Pic:
I hear nothing bot good things about the nitto tires.. but the Dakota definity M/T tires for $138 each and buy 3 get one free from pep boys was too good of an offer to pass up.
(and by buy 3 get one free they mean after a mail in rebate that took 2 months for my check to arrive)
I have the Deatination A/T on my truck. I use it at the beach and hunting on a 550 acre farm.I've had them for three years,and nothing has performed better than the firestones.Last year we had over 20 inches of snow for weeks.I went thru the fields and back and forth home with no problems.
Quick update: After talking to a few people both here and on 4Runner.org I decided to go with the Destination A/Ts. I'll post pics soon...but they look great and fit perfectly as 265/75s. I was able to drive them around in the rain this morning and so far I like them. We'll have to see when winter strikes how they hold up.
For those interested: I went through Firestone because they were priced the same as tirerack (when you add in shipping/installation) and they threw in the extended road hazard warranty and free rotations/balancing/discounted alignment for life. Not too bad. Total was $700 on the truck.
i have nitto terra grapplers on my 08 tundra and love them. there quit and do good in the rain. no snow down here so can't help you there
justdifferentials
14
06-11-2017 08:36 PM
FS[MidWest]: OEM Toyota FJ Wheels 2007-2010 $500
dbd6604
10-11-2015 05:30 PM
justdifferentials
09-05-2015 06:52 PM
