LT vs P rated tires??
Old 01-21-2009, 10:04 AM
wootman's Avatar
Looking for new tires to compliment the new OME lift. Probably either BFG AT's (if I can find a good deal on them) or Nitto TG's. Both come in either LT or P ratings. I know the ratings refer to number of ply's, just not sure which is better?
Old 01-21-2009, 11:02 AM
4Crawler's Avatar
LT tires would be the best:
- http://www.4crawler.com/Diesel/Tires.shtml#SIDEWALL
I find P (passenger car) tires have too soft a sidewall for use on a heavier truck. I once ran a set of P metric tires on my old FJ55 Landcruiser and the sidewalls were shot in a year or two. Replaced those with some LT tires and it was so much more stable in the corners. With the P tires, it felt like it was wallowing in the turns, very mushy and slugging cornering response.
Old 01-21-2009, 11:36 AM
ozziesironmanoffroad's Avatar
P actually stands for 'pmetric' and LT is, obviously, light truck. to me, the only vehicles that should run P rated tires are cars. SUVs and trucks, IMO, are too heavy for Pmetric tires.
Old 01-21-2009, 04:53 PM
Mulkey's Avatar
There are 3 different types of LT, usually C, D, E ratings. Usually a 2 ply difference between P and LT C rating tires. The tread will be slightly deeper on LT. At least this is the case with Bridgestones.
Old 01-22-2009, 07:41 AM
cackalak han's Avatar
I don’t think SUV’s and trucks are too heavy for P-rated tires at all. It depends on the uses. I wouldn’t recommend an LT tire for a soccer mom that will never see anything but asphalt. The P-rated tire will ride better and get better MPG on the road.
Old 02-21-2009, 09:37 AM
Shoe1983's Avatar
When choosing what ply to run you have to make sure that tire will hold the weight of the car/truck. in a diesel case i would try to run an D or E ply rated tire. but someone with a ford ranger heck ya all day but rated 4 ply tire. you also have to consider what you will want to do with the tire"off-road, highway? rating ply's B-4, C-6, D-8, E-10 and it goes up like F-12. and bfg A/T's rock chip like a fool it would be a great tire if it wasnt for that!
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
digdug40
08-28-2015 02:24 PM
DirtRoad93
08-23-2015 05:50 AM
Quick Reply: LT vs P rated tires??
