Correct tire pressure? 4x4 tacoma 265/75/15
I do not have an owners manual. I have 265/75/15 tires on a 99 4x4 xtracab tacoma. any idea what my tire pressure should be?
On the side of your tire is a MAX PSI. A good rule of thumb (to minimize tire wear) is to fill them 2 psi under the max. Now obviously if your max is 80, then 78 might ride a bit hard, so 60-70psi is what I useally rec. I have 65 psi as my max and I put 60 psi in them. Rides fine and makes the tires last to there fullest potential, (as far as tire press. is concerned)
skoti89
07-08-2015 12:05 AM
