Last edit by: IB Advertising
- Toyota Tacoma Tires General Information and Specs<br>Important information to help you understand your Tacoma.
bigger tires on stock rims- Bad idea?
well, i have a 1998 toyota tacoma xtra cab 4x4 with a 2.5 inch lift, and it has finally come to get new tires. but i'm a college student who is strapped for cash so would it be a bad idea to put 33x10.5 15's on my stock 15x7 rims or should i stick with the 31x10.5 15's that i have?
it will not harm anything putting 33x10.50 on a 7" rim. also, you have a 3.4 therefore, its not as much as a problem to regear. you'll find lower result of MPGs, but only slightly.
well the truck has 4:10's so even though that's not the optimal gearing, it's a start. the only drawback. my tacoma has the 2.7 4 cylinder. even though it's a step above my 22re, it's not exactly a power house despite all my power adders
33-10.5's will be fine on the stock rims. Weather you want 33's with out a re-gear is up to you, some would say 33's and 4.10's with no problem, others would say hell no! I say it's up to you.
Yep, good fit:
- http://www.4crawler.com/4x4/BFG_AT_KO.shtml
33x9.50 and 10.50s on 15x6 stock wheels:
I'd choose height over width, but if you dont do much wheeling it may be a wash to you. 33's and a 4cyl are bad, definitely managable though, you will want to regear in the future.
X2 there. I run 10.50's on stock 7" wheels and have no issues. When I need a little more traction I just let some air out of them. You'd be surprised how much traction you get out of a 10.50 at 12lbs of air.
along time ago i had mickey thompson 33x14.50 on 15x8 stock jeep cj7rims but they were really soft compound ,they had like 25 or 30 pds of air . they wore out fast.but didn't seem 2 have any other issues .they were like a sand tire ,u could hear me coming from a block away!
i ran 10.5s on a my runners stock wheels no problem wore evenly, but now i run 10inch wide wheels and i love how it spreads out my tread on the trail.
In fact i have 2 15 inch aluminium 10inch wide wheels i will sell you for 25 a piece plus shipping if you want to do it right and go with wider wheels
