best mud tire
Old 06-06-2012, 02:21 PM
  #41
vang_22re's Avatar
Come on now. Those can't be louder than super swamped boggers
Old 06-06-2012, 08:04 PM
  #42
ROCKGUARD 1's Avatar
i had 32" hankook dynapro-mt rt-03 , they were great off-road and decent on-road. i would get it again. i now run mickey thompson baja claw 31", very quiet on pavement and AWESOME on trail when aired down to 18psi.
Old 06-11-2012, 08:27 PM
  #43
ratso's Avatar
Goodyear duratracs are the best street/snow tire.
Old 03-20-2013, 06:09 PM
  #44
wolf28's Avatar
yes this thread was dead but these 33-12.5s are killing me id like to get rid on my rims and tires and get some black steelies with 33 10.5s
Old 03-20-2013, 09:01 PM
  #45
vang_22re's Avatar
Hello thread!!!
Wolf, ill take those 12.50 if your close
Old 03-21-2013, 07:37 AM
  #46
wolf28's Avatar
i wish i was closer to sell them to u i liove in uppr michigan yea these 10-11 wide rims and 12.50s look like balloon tires lol great for sand but i wanna cut down to 33-10.5 something that looks dcent and little better mileage
Old 03-21-2013, 07:49 AM
  #47
wolf28's Avatar
so im looking a some black steelies rims and i want the tire to stick out maybe .5 -1.50inches out from the fender wat back spacing would i need
Old 03-21-2013, 07:58 AM
  #48
SCToy's Avatar
you should considering the KM2 33x10.5R15. I bought a used set with about 60% tread left. I have put about 15k miles on them since then and they are probably at 10% now, but I figure I'd get at least 30k out of a new set. That's with a locked diff and I drive 90% mountain roads and I DO NOT take it easy. If I were a less aggressive driver/doing more highway I could easily see getting 40k out of a set.
Old 03-21-2013, 08:04 AM
  #49
wolf28's Avatar
was looking at the km2s or ebay mt specials since money is a problem
Old 03-21-2013, 08:12 AM
  #50
Orion22rte's Avatar
Anybody look at the dick cepeck crushers? Spose to be excellent in mud wid good road manners
Old 03-21-2013, 08:18 AM
  #51
wolf28's Avatar
can any one answer about the backspacing
Old 03-21-2013, 03:48 PM
  #52
highonpottery's Avatar
I can't comment if you swap your tires for a different size, but if you decide to keep the 33x12.5x15s, then get some 15x8-3.75 or 3.5" backspace wheels. that's what size I run on my truck (the 3.75") with 33x12.5 Toyo's. Wheels stick out right around where you're asking. I have about 3/8" between sidewall and UCA.
Why do you want to get rid of the 33/12.5s? Personally I love mine
Old 03-21-2013, 05:38 PM
  #53
wolf28's Avatar
can i put my 12.50 on a 8 inch wide rim
im runnin 33 12.5 on 11 wide rims and its killin my mileage i was lookint at going to a 15x8 rim with 33-10.5s
Old 03-21-2013, 06:03 PM
  #54
wolf28's Avatar
i like the way that looks doesnt make the tires look like balloons like my wide rims do
Old 03-21-2013, 06:04 PM
  #55
what's your mpg now? what might really help is lowering your truck if it's still got the 6" lift. i can't imagine how much wind it catches that high as mine already catches a lot of wind with only around 2" lift. i don't know physics that well, but i would guess that just changing the contact patch of your tires isn't going to make a significant change for your MPGs. you might gain acceleration because they'll be lighter. obviously driving style also has a lot to do with mpg's as well.
i get around 15-18mpg with 22re/5spd/4.88s/HEAVY 33x12.5 Toyos/2" lift.
Old 03-21-2013, 06:20 PM
  #56
wolf28's Avatar
was loking at getting these http://www.summitracing.com/parts/sum-84-5883/overview/
i get about 14-16 mpg with 3.0L 5 speed
Old 03-21-2013, 06:50 PM
  #57
i think that's about average mpg for a 3.0 truck.
fairly certain that's the spec of wheel you will want if going with an 8" wide, and it gives you options vs being stuck with limited width tire. 3.75-3.5" is about the BS you need in order to keep distance between sidewall and UCA with large 12.5" tires. i'm pretty sure a 33x10.5 will fit on stock 15x7-4.75bs wheels without rubbing as well - that's why so many people run that size BFGs.
Old 03-21-2013, 07:19 PM
  #58
wolf28's Avatar
ok well ill prolly get these and swap over my 12.5s onto these 8 wides as lond and my sidewalls dont rub
Old 03-21-2013, 07:21 PM
  #59
niall's Avatar
Going from a 33x12.5 to a 33x10.5 is going to make NO noticable difference in your mileage.
Old 03-21-2013, 07:29 PM
  #60
wolf28's Avatar
alright well then will at least these rims fit with no sidewall rub so i cant get rid the ballooned tire look
Quick Reply: best mud tire
