50 psi? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Tires & Wheels
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-28-2009, 08:36 AM   #1 (permalink)
kawicowboy's Avatar
50 psi?
I just happened to notice that the tire pressure on my 96 Taco with 15in rims and Michellin tires says 50 Psi, that sound crazy to me can this be right, my wifes 97 LTD runner with 16s says 32 psi.
kawicowboy is offline
Old 10-28-2009, 08:39 AM   #2 (permalink)
seanmearse's Avatar
Does it say max next to it? or did you just check the pressure and thats what the gauge said?
__________________
The Internet, where men are men, women are men, and children are FBI agents.
Proud sponsor of the re-poster thread.
http://www.yotatech.com/f5/you-re-poster-193103/
84 SR5 pickup, Mostly stock 22R, K&N air filter, Mobil 1 oil filter, Cherry Bomb, Mobil 1 engine, Royal Purple diff and trans fluid, 15X8 street locks, 3 inch procomp front springs, waiting to buy rears, rancho RS9000XL's up front.
2003 Vstar 650, straight pipe, loud and fast baby!
seanmearse is offline
Old 10-28-2009, 08:44 AM   #3 (permalink)
kawicowboy's Avatar
It says 50 on the tire so I guess thats max, But I noticed while checking tire pressure that it was at 50, so I looked at the tire to see.
Old 10-28-2009, 08:44 AM   #4 (permalink)
ACSig's Avatar
I have Goodyear LT tires on mine, at least I think they're Goodyear. They are 50 psi, but my parents 04 and 86 are both around 30 psi with stock tires. So I figured since they are Light Truck tires I might as well try 50psi and I didn't notice a difference, so I life them there.
__________________
1995 4Runner, V6 3.0, 5 Speed, 2 12" Audiobahns, Manual Hubs, 2 130w Offroad Lights
ACSig is offline
Old 10-28-2009, 08:51 AM   #5 (permalink)
seanmearse's Avatar
Should run whatever is recommended for the vehicle. Im at 29 psi cause it offers the best contact patch.
__________________
Old 10-28-2009, 08:51 AM   #6 (permalink)
You shouldn't run the tires at their maximum rating unless they are holding close to their maximum load. There really isn't any reason to run the tires at 50psi for a Tacoma that isn't hauling anything.
My tires on my 4Runner are load range D with a maximum pressure rating of 65 psi, but I run them at 40psi for on-road driving.
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 10-28-2009, 09:18 AM   #7 (permalink)
kawasakimoto_7's Avatar
thats all crazy talk.. you can run your tires at whatever you want without going over your max.. but dont go too low, youll get shoulder wear if so.. i work for discount tire and i run my 31x10.50's at 45 PSI and i think the max is 50.
__________________
1995 toyota pickup 4x4 reg. cab
22RE 5 spd
bought: 206,000
stands now: 218,000
recent top end rebuild
marlin crawler front bumper w/o stinger
31x10.50's
black steel rims
flowmaster 40
kawasakimoto_7 is offline
Old 10-28-2009, 09:22 AM   #8 (permalink)
VSU_4runnin's Avatar
well i think the 50 is the max, my bfg a/t's are filled to 30, but while driving, let's say 70 down the highway for 2 hours, if i pull off and check the tire pressure, its close to 60 psi. that higher rating is to compensate for the heating and expanding of the o2, or N.
__________________
1998 Toyota 4Runner:
33" BFG A/T T/A: KO 2.5" Lift
CB Radio Brush Guard
Yakima roof rack
manikin head (Viola), and more to come!
Clicky For Picky
Buildup
GATTORA
KJ4HVQ Skywarn Ga 208
ΦΣK
DAMN PROUD!
VSU_4runnin is offline
Old 10-28-2009, 01:28 PM   #9 (permalink)
seanmearse's Avatar
Quote:
Last time I ran any tires that high, my centers wore down first. Do the chalk method, across the tread, take a little short drive, and look at your contact patch at 45psi, then check it the same way at 30psi. to little outside wears, to much center wears, its just basic science.
__________________
Old 10-28-2009, 01:45 PM   #10 (permalink)
Ironmike4x4's Avatar
Send a message via AIM to Ironmike4x4
Quote:
You beat me to it. If you want the maximum life out of your tires I would inflate them to what you find on the chalk test. You want it to wear evenly from the center to the edge. Proper alignment, tire rotations, and inflation will give you the best results.
You will often times hear people say to bump up the pressure to the maximum to get better MPGs. IMHO if you are paying more for the tires than you are saving for mileage it isn't worth it.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can.
Quote:
Originally Posted by Tofer
"ohhh you are one hot 4runner, look at that flex... oh yeahhhh"
Quote:
Originally Posted by YotaFun View Post
Yeah...
Teens these days...
(granted I am 19 ...
Ironmike4x4 is offline
Old 10-28-2009, 03:29 PM   #11 (permalink)
SC4Runner's Avatar
To me, tire pressure is dependent on 2 major factors: The weight of the vehicle, and the width of the tire. Tacomas, since they are lighter than other pickups would require less than the max psi listed vaule on the tire.
As already said, the easiest method is to just use a chalk line.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe.
1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe.
SC4Runner is offline
Old 10-28-2009, 03:44 PM   #12 (permalink)
Staff
4x4Fink's Avatar
x3 for the chalk test.
Fink
4x4Fink is offline
Old 10-28-2009, 03:50 PM   #13 (permalink)
MaK92-4RnR's Avatar
I keep mine at 45. 50 seems... steep.
__________________
1992 Toyota 4runner SR5 4x4 3.0 V6 5 Speed - Completely stock with 136k Miles.
Modifications:
Exhaust: Doug thorley headers, magnaflow hi flow cat, borla turbo muffler, 2.25 piping with a 3" tip
Stereo: Pioneer Premier Deck, 2 12" Subwoofers, Brand new speakers all around, 1 450w 4 channel amp, 1 1000w 2 channel amp.
CB Radio: Cobra 19 DX IV 40-Channel Compact CB Radio
MaK92-4RnR is offline
Old 10-28-2009, 05:15 PM   #14 (permalink)
Mine max at 65. I run at 50 on the highway and 16 off road.
sn0wrunnin is offline
Old 10-28-2009, 05:23 PM   #15 (permalink)
chad1041's Avatar
35 on my tsl's the trick is not just air pressure alone that the biggest but keeping them rotated too
__________________
95 taco 3.4 3in body 3in susp. tsl 33 12.50 15
chad1041 is offline
Tags
1995, 22, 22r, 22re, 30, 4runner, 50psi, check, oil, pressure, psi, rims, speed, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
