Is 4.30 a decent gear ratio with v6 to pull 38's
Old 08-18-2014, 02:52 PM
Killeryota1512's Avatar
I'm looking at buying another 92 toyota it has 38inch mud grapps with 4.30 elocker is this an alright gear to pull the tires and 16-17inch rim or will It eat the clutch and kill the engine
Old 08-18-2014, 03:02 PM
millball's Avatar
4.30 way too high.
Prob need 5.29's for 38's
Unless everywhere you go is downhill
Old 08-18-2014, 03:21 PM
Punchy's Avatar
Or 5.71
Old 08-18-2014, 03:57 PM
JasonYota's Avatar
Originally Posted by millball
4.30 way too high. Prob need 5.29's for 38's unless everywhere you go is downhill
x2 ^^
Old 08-18-2014, 04:05 PM
highonpottery's Avatar
you can DO it, but it's not even close to being ideal - and like you already though, it's likely going to take some life off of clutch and engine due to the struggle.
likely has 4.30 gears because that's what a stock e-locker came in. does the front match ratios? people swoop up used e-lockers pretty often - so you could likely sell it off for ok money and buy yourself the one you want, or rebuild this one.
don't forget - just because you have the gears to move 38s, doesn't mean your [stock] brakes can easily stop 38s in emergency situation
justdifferentials
14
06-11-2017 08:36 PM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
whiteyota93
09-29-2015 02:31 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Is 4.30 a decent gear ratio with v6 to pull 38's
