31x10.50 15s on a 6 or 7 or 8inch rim?
i got a 94 3.4 swapped 5 speed extended cab pickup and plan to get new tires for it. it currently has on 235/75r15s and i am planning on running 31x10.50 15s. i have the stock 15x6 rims.
will 31x10.50 tires fit and run safely down the interstate and do slight offroading safely on a 6 inch wide rim? or would it be better on a 7 or 8 inch wide rim? i do air them down a bit when i offroad.
thanx travis.
thanx travis.
True but what if I get the same backspacing and offset? I thoight I read somewhere stock was 3.75 inch backspacing? I will look when I pull the wheels off the truck next time.
Ivw done some reading and see that most people use 3.75 backspacing. But what about offset? I want a wider looking stance without tearing out my balljoints and bearings.
3.75inch backspacing and what offset?
I dobt know what offset is stock. I read -20mm but unsure.
1uzRunner
63
11-10-2018 03:58 PM
Cycles
09-29-2015 06:37 AM
FS[PacNorWest]: 1993 4 Runner, V6, 4wd, Auto,
AkitaDog
09-03-2015 09:01 PM
