YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Trip Planning, Trail Reports-Photos, Land Usage-Responsibility, 4Wheeling 101, & Expedition Gear > Camping, Expedition, & Overlanding Gear
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-27-2007, 11:12 PM   #1 (permalink)
Heating while camping
I sleep in the back of my 4Runner everytime I go camping (few times a month). I am going camping for New Years and we are expecting near freezing temps. Can anyone think of a safe way to have some if any heat while I am sleeping back there? I know I would probably need to have the sunroof popped up or a window crakced for fresh air to avoid carbon monoxide poisoning.
__________________
'98 4Runner Limited White w/ silver flares
98runner210 is offline
Sponsored Links
To remove this ad, register today!
Old 12-27-2007, 11:21 PM   #2 (permalink)
farmerj's Avatar
a warmer sleeping bag and dress in layers...
put some foam or other insulation under you as well...
crack the windows on the front and in the rear so you can vent the water vapor from your breath.
__________________
Life is too short to have to work....
RIP - 4 July 2008 - '88 4Runner, Audiovox Cruise Control,Valvoline Full Synthetic Gear oil, SR5 instrument cluster, '95 4Runner Seats, Rear U-bolt Flip
farmerj is offline
Old 12-27-2007, 11:32 PM   #3 (permalink)
do i have to crack the windows?
__________________
Old 12-27-2007, 11:57 PM   #4 (permalink)
farmerj's Avatar
you want some air movement to vent the water vapor...
other wise EVERYTHING will be covered with moisture.
__________________
farmerj is offline
Old 12-28-2007, 12:04 AM   #5 (permalink)
apalmer1's Avatar
you could use a small propane heater as long as the windows or sunroof are cracked enough to ventilate it and you make sure that it has a plastic base and isnt touching anything heat sensitive
__________________
04 taco, 3.4 5spd. loads of goodies, loads of reinforcements, getting really hard to break.
85 pickup, 327sbc, truggy, in progress.
86 mazda b2000 street queen haha.
90 mazda mx-5 all orriginal.
when in doubt, tach it out.
apalmer1 is offline
Old 12-28-2007, 05:32 AM   #6 (permalink)
I searched the threads and found a thread about this. No definite answers, some good and bad ideas. I have seen Coleman has catalytic heaters that are designed for closed spaces like tents. I dunno where to put it where it won't be knocked down or over. I was thinking if there was some way to hang it.
__________________
Old 12-28-2007, 05:38 AM   #7 (permalink)
AppleJack's Avatar
I used a Mr. Heater for car camping and tent camping. It has a low O2 sensor which will shut it off. It also shuts off if it is knocked over. I set mine in the front seat and was toasty warm all night.
__________________
Fires, Friends, and Books Decree
Wisdom, Strength, and Controversy.
To believe with certainty, one must begin doubting.
AppleJack is offline
Old 12-28-2007, 06:02 AM   #8 (permalink)
fishon1213's Avatar
Get a power inverter and a electric blanket and wrap yourself up like a burrito. Heh heh
__________________
1985 4runner 85K LOL
1994 Camry 220K
fishon1213 is offline
Old 12-28-2007, 06:28 AM   #9 (permalink)
Baloo's Avatar
Send a message via AIM to Baloo
We camp in our area a lot, usually between September and May. We live in the Chicago area. Need I say more?
Heaters may seem like a good idea, however aside from the hazard, are really not necessary.
Get a good sleeping bag. My preference is one that is rated around 20 degrees Fahrenheit. Why not colder? I want the greatest range without changing bags.
Along with the bag, get one or two fleece bag liners. They add about 10 to 15 degrees of warmth. As mentioned earlier, dress in layers and keep a knit cap of some type on your head. I also put the socks I am going to wear the next day on my hands. It keeps my hands warm and the socks toasty in the morning.
While on that, change your clothes prior to bed, especially those closest to your body. Clean, dry clothes warm much better.
One thing that is kinda gross, keep a wide mouth bottle of some sort in your bag with you. Mark it well with duct tape. You don't want to have to get out of a warm bag when nature calls. This works for males. Sorry ladies, I don't know a way for you.
The windows do need to be cracked slightly. This is why tents come with vents. As you breath, you are putting moisture into the air. It may not seem like much, but you will wake up quite damp. You also want them crack to reduce carbon monoxide concerns. It really won't affect the temp as much as you think.
Hope this helps.
__________________
2001 Toyota Tacoma DBL cab.TRD Off Road.
ISR & Deckplate. XM/Sirius. VHF/UHF/HF Radio, Laptop & GPS Mounts. FlexFuel Conversion.
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, chocolate in one hand, wine in the other, body thoroughly used up, totally worn out screaming "WOO HOO, WHAT A RIDE !!"
Baloo is offline
Old 12-28-2007, 06:28 AM   #10 (permalink)
patrickryanb's Avatar
I would just use a warm sleeping bag, boil water and put it into a Nalgene or other lexan bottle, then put the bottle in your sleeping bag. Works like a heater in the bag so you body doesn't have to warm up all that "dead" cold air. definately keep the windows cracked or frost will be everywhere. Also you can keep some snack foods by you so if you wake up cold in the night, eat some food so your body can generate more heat. My 2 cents.
patrick
patrickryanb is offline
Old 12-28-2007, 06:36 AM   #11 (permalink)
Co-Founder/Administrator
Staff
Corey's Avatar
I would never use a gas/propane type heater in a tent or rig.
To many deaths, even with ventilation.
Long long ago (back in the early 80s man) the X and I and our oldest were in our first tent trailer camping in the snow.
We had the windows cracked and lots of air coming in.
We still woke up with the taste of propane in our mouths, and slightly dizzy.
It was one of the old Coleman ones with the heat array on top.
Later I got a much nicer one with the shut off if it tips over, but it was only used first thing in the morning when we got up or you had to sit on the portacrapper in the trailer.
It was never left running during the night.
As mentioned, get a good sleeping bag made for cold temps.
__________________
Corey
2007 FJ Cruiser
ARB bumper, Warn XD9000, OME lift, roof top tent, so much more, see my website & buildup thread
PNW FJ CruisersDetailing 101Join TopsitesMuffler ComparisonsMaggiolinas In The Wild
FJ Cruiser BuildupNew Roof Top TentVideo Of My PenthouseRehinge Your ARB/Engel Fridge
Corey is offline
Old 12-28-2007, 06:41 AM   #12 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
Coleman makes a great propane catalytic heater, no open flame, and no fumes, might still want to crach a window, but it will run near on 4-5 hours wide open on a 1lb bottle of propane, so a coulpe hours while you go to sleep, wake up early, tun it on, and let it warm up the runner before you get up. Or, buy a bigger bottle of propane and run it all nite
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 12-28-2007, 08:34 AM   #13 (permalink)
I am starting to think just bundling up is easier and safer. I thought about the catalytic heater but don't know where to put it. where it wouldn't burn or melt anything. Would Academy carry the fleece liners and the Naglene?
__________________
Old 12-28-2007, 08:41 AM   #14 (permalink)
CJM
CJM's Avatar
Do not use a propane heater!!!!!! Get an electric blanket and power inverter or bundle up.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 12-28-2007, 08:47 AM   #15 (permalink)
ChickenLover's Avatar
Quote:
I use one of these. They are great (and safe). Mine runs 7hrs on one 16oz tank and keeps the 4runner comfortably warm. It was about 80 bucks at wal-mart. The last time I used it was on my Thanksgiving hunting trip. Overnight temps were slightly below zero, the inside of the truck stayed in the 50's.
I sit the tank-side by my tranny shifter and prop the legs up on the top of the center console. I have no melting issues.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 12-28-2007, 08:58 AM   #16 (permalink)
Quote:
I would advise against this, unless he is running auxiliary batteries. Cold weather and batteries are natural enemies.. Like hammers and nails.
__________________
Old 12-28-2007, 08:59 AM   #17 (permalink)
Damned double posts.
__________________
Old 12-28-2007, 09:08 AM   #18 (permalink)
CJM
CJM's Avatar
Quote:
I forget not everyone has a dual battery setup...
__________________
CJM is offline
Old 12-28-2007, 09:30 AM   #19 (permalink)
spdjnky's Avatar
You laways have the option of a ceramic heater
http://www.harborfreight.com/cpi/cta...emnumber=94592
I have never used one and it might not do any good at all but it might be worth a shot.
__________________
1986 4Runner Automatic
rebulit 22re
OME leaf springs
BJ spacers
Edelbrock IAS shocks
31x10.50 Pro comp Mud Terrains
spdjnky is offline
Old 12-28-2007, 10:38 AM   #20 (permalink)
farmerj's Avatar
Anything you do....
For a comfortable nights sleep, make sure you get plenty or insulation under you.
Your body will compress that layer and the truck will suck the heat right out of you.
__________________
farmerj is offline
Old 12-28-2007, 10:50 AM   #21 (permalink)
hross14's Avatar
