YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Trip Planning, Trail Reports-Photos, Land Usage-Responsibility, 4Wheeling 101, & Expedition Gear > Camping, Expedition, & Overlanding Gear
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 06-02-2005, 11:45 AM   #1 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Best Mosquito Trap?
The dang skeeters are getting attrocious now so I need to do something about it soon.
So which traps are you guys using and what is the most effective?
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Sponsored Links
To remove this ad, register today!
Old 06-02-2005, 12:16 PM   #2 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
traps? tiki torches well its not a trap but seems to work.
__________________
Dan
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 06-02-2005, 03:14 PM   #3 (permalink)
CynicX's Avatar
Send a message via AIM to CynicX
i think these are the best.....my father has one here in SC and he lives right on a big man made pond....with out it you cant even sit outside in the summer, i'm talking even in the blazing heat they will still bite and right through your clothes...its crazy...
with it on you can sit outside at night with no clothes on (if for some reason you had a need to do that) and not get a single bite...
__________________
06 Subaru WRX
CynicX is offline
Old 06-02-2005, 03:14 PM   #4 (permalink)
CynicX's Avatar
http://www.mosquitomagnetdepot.com/?source=overture oops...i forgot the link...hehe sorry
__________________
06 Subaru WRX
CynicX is offline
Old 06-02-2005, 03:17 PM   #5 (permalink)
FilthyRich's Avatar
I bought a Coleman Mosquito Deleto last year. It runs constantly on porpane and has a sticky trap inside, blaa blaa blaa
I am not convionced it traps them. I haven't really seen a lot on the trap. I t emits some smell that is supposed to repel them, but...
I am little skeptical, but I will use it this season and see how it works...
__________________
Eric
88 4runner
Quote:
Originally Posted by AxleIke
"Just wheel what you got until it doesn't cut it anymore".
FilthyRich is offline
Old 06-02-2005, 03:18 PM   #6 (permalink)
96LtdYota's Avatar
Send a message via AIM to 96LtdYota
our family uses THIS at our coast house beginning in spring through fall...
we turn it on the second we get there and whithin a few hours a HUGE portion of the mosquitos are gone.. the rest can be taken care of by the 3 tiki torches we keep in the backyard...
the backyard is on a marshy swamp of stagnant 2"-5" water with lots of folige for nesting.. without this thing our backyard would be unbareable...
__________________
Beaux
Its injured...
96LtdYota is offline
Old 06-02-2005, 03:21 PM   #7 (permalink)
FilthyRich's Avatar
Quote:
I am ordering this thing!
__________________
Eric
88 4runner
Old 06-02-2005, 03:22 PM   #8 (permalink)
BT17R's Avatar
I had a half-dozen Swallow-specific birdhouses made. The Audubon guy said they had to be a certain size and shape, the hole must be just so, etc. So far, nada. I might have screwed up by coating them all with spar urethane on the outside and they don't like it? There are still Swallows around in the forest, not as many around the house as I'd hoped. They're supposed to eat their weight in mosquitos daily, or so the yarn goes...
BT17R is offline
Old 06-02-2005, 03:25 PM   #9 (permalink)
tulsa_97SR5's Avatar
We also have one of the propane powered types, got it at Sam's a few years back. It never has a ton in the little bin they are supposed to end up in, but I can tell the difference when it's runnning. Maybe they get burned up when they pass by the little flame?
__________________
Brian
85 sr5, 5spd - back on the road, doing DD duty for now
86 2wd reg cab - future project
90 sr5, 97 - gone
tulsa_97SR5 is offline
Old 06-02-2005, 06:07 PM   #10 (permalink)
That sounds alot like my backyard.....we have a forest right up against the back of the yard and our property seems to catch water from my neighbors properties since ours appears to be lower than the rest. I was told not to use a mosquito trap because it would draw them from farther away but that seemed to be flawed logic so I wanted to give it a try and see if the situation improves.
From the tests, it seems like this unit was the best but it is quite expensive and I doubt I could even find one up here in Canada (we have mosquito magnet and skeetervacs for the most part).
There were quite a few tests:
http://www.megacatch.com/testresults.html
Looks like the mosquito magnet Liberty was a good second choice:
http://www.megacatch.com/testresults_JPSmith_ultra.html
I wonder if you could build your own even cheaper since the best ones don't use propane, they use commercial CO2 cylinders which can be filled very cheaply and produce more CO2......just a thought.
__________________
- Jamie
Old 06-05-2005, 02:44 PM   #11 (permalink)
Well I finally got the SkeeterVac SV-35 which supposedly does 1.2 Acres.
I'll post back once I have tried it for a week or two.
Seems to have pretty decent reviews:
http://www.epinions.com/Patio_Furnit...nion_list#list
__________________
- Jamie
Old 06-05-2005, 02:50 PM   #12 (permalink)
4-RUNNIN' FREAK's Avatar
There is the commercial version where I work, and the net bag fills up in like 3 days.
Be careful when taking the bag out, since some of them blood suckers are still alive.
Maybe run it under hot water or a shot of bug spray.
You must replace the little scent packs too, works waaaay better.
__________________
'02 4Runner - '06 XRunner
Breakdancing
www.BadgeYourRide.com
Check this out Multi-Touch Interaction Research http://mrl.nyu.edu/~jhan/ftirtouch/
Highest Xmax 6.5" subwoofer made
Total Posts: 32,218 (75.35 posts per day) [/center] [/color]
Still A Neon
4-RUNNIN' FREAK is offline
Old 04-27-2008, 11:43 AM   #13 (permalink)
georgiayota's Avatar
For the mosquitos around here the best thing I have found is a Thermacell. They are about $20 at walmart, and they work! Just turn it on and wait five minutes for it to warm up and they wont bother you.
http://www.mosquitorepellent.com/
georgiayota is offline
Old 04-27-2008, 02:35 PM   #14 (permalink)
stormin94's Avatar
We've got lots of bats over here, lots of spiders, and a bug zapper, and tiki torches, and even with all these things, sometimes bug spray isn't enough. I can't imagine the mosquitos without all of these. But lucky for me, it's a dry year this year, so there isn't a whole lot of em, and the frost last weekend killed most of them too. We also have these damn "Lake Bugs" anyone who's ever been to Lake County, CA in the spring/summer knows what I'm talking about. They're little gnats, but there's like a billion kazillion of em. They don't bite, but they don't taste too good either.
__________________
1994 Toyota 4Runner SR5 4X4
208,000 miles and counting
3.0 V6, 5 speed
14/19 MPG city/hwy(before 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 05-05-2008, 03:38 PM   #15 (permalink)
dlbrunner's Avatar
The best thing to do with those traps is put them at the neighbors house a few houses away. Before they kill the skeeters, they have to attact them, you are more likely to get bit when you have a high concentration of them in your yard.
__________________
Duncan
Current: 95 4X4 SR5 V6, Yakima tracks/rack installed. Aisin hubs. Sonoran Steel IFS Truss. Cobra CB(finally!)
Desired: 66 FJ45 shorty
EX's: 89 4X4 V6 Downey'd
72 FJ40 W 350/SM465 powertrax, "Billy"
dlbrunner is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Minnow/shrimp trap question jethro Off Topic Talk 2 05-30-2006 05:44 PM
Mosquito recovery? 4RUNR Off Topic Talk 10 08-17-2005 03:34 PM
Mosquito net on sunroof? Rishi Off Topic Talk 4 05-17-2005 05:18 PM
Impromptu VA4ROC Skeet/Trap Shoot Roadrunner Virginia 2 06-29-2003 07:07 PM
Rattle Trap Fever uberdog 95.5-2004 Tacomas & 96-2002 4Runners 1 06-14-2003 08:47 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
