| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Co-Founder/Administrator
Staff
12v power supply for camping (roof top tents, tents, ect)
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#2 (permalink) |
A couple of options for not having to lift the hood to connect, would be to use Anderson Powerpoles, or if you have a tow package with a 7 pin round connector, to wire up to the trailer charge wire as most manufactures and installers will let that be hot with the ignition off, for this you would only need to add a trailer end and wire up the power and ground.
__________________
93, 22RE, 5Spd, Reg Cab, Short box, ICOM IC-V8000, Hella 500's, Cobra 75 WX ST, tool box, home-brew headache rack, extended diff breathers, basically stock but upgrading as money allows. - Firefighters, Because Police need heroes too Prepare for the worst, Hope for the best Try Geocaching |
#3 (permalink) |
Staff
Thanks, I had thought about those quick disconnect plugs above.
I also have the trailer package, but I would have to look at my plug. I wonder how much amperage though the trailer wring can provide, and where do they fuse those at most of the time? That is a great idea if that pans out for the trailer wiring.
__________________
#4 (permalink) |
Staff
The trailer package on the FJ would be a 4way flat or round plug or a 6 way at best. The 7 way is generally only used for heavy trailers in the class IV or higher group that have elec. trailer brakes and on board batt's to charge like you might find in a race car/travel trailer.
The anderson plug would be your best bet... you could also fit out a set of booster cables with an anderson. With a receptacle at either end of the FJ be ready and able to offer a boost to anyone from either end.
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0 K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler custom covered SR5 seats, map lights, factory AC tv4184 style black interior conversion started mods to come... header, custom centre console, stereo upgrade tinted windows Founding member 1972TLC fan club - Get well soon Mary Toyota Hilux... Get in or Get out of the way. |
#5 (permalink) |
I believe the fuse will be in the under hood power center, I wouldn't worry about the size of the wire, to much, as it is in place to provide a charge to a trailer battery, and what you are planning on I think it would be ok. For heavy power demands, now or in the future, I would definitely add the powepoles fused to an auxiliary battery.
When I added my tow package I put in 8 gauge wire, specifically for running higher than normal power to the trailer.
__________________
#6 (permalink) | |
Quote:
I agree with the use of the powerpoles as they can handle much higher amperage, depending on the model, and the ability to connect jumpers from either end, with out lifting the hood, and as a side benefit it makes it harder for someone to disappear your jumper cables.
__________________
#7 (permalink) | |
Staff
Quote:
__________________
#8 (permalink) |
Staff
Just checked, mine has a four pin plug.
http://www.accessconnect.com/trailer_wiring_diagram.htm ![]() The image above with one male three female is what I have. So there is probably no charge line in it.
__________________
#9 (permalink) |
No charge there, only left turn/brake, right turn/brake, tail (or running) lights, and ground. powerpole's may be your best option.
However if you were to build or buy a trailer(to carry all that stuff I see you reviewing) like an M101, the RV plug would be a good thing to add to include brakes and power.
__________________
#10 (permalink) |
Staff
__________________
#11 (permalink) |
Nice, when you get ready to add the harness, it is easy to do yourself. The hardest part should be wire routing, or finding the brake wire under the dash.
__________________
#12 (permalink) |
Staff
Today I popped open the tent and hooked up the new box to the battery.
That extra alloy lid that came with the box worked out like I thought it would. It wedged in between the mattress and holds the box up. I plugged in the 12 tent light and it works in any of the three outlets. But as soon as I plugged in the 12 v bunk pad warmer, BAM!, it blows the 30 amp fuse up by the battery. This was with the tents light running too, and I would imagine the light can not be pulling over 1/2 amp? The warmer pad pulls 7 amps max or so. I am suspecting the pad is defective or the plug is. I did not have time to investigate it further, but I will be ordering a 12v extension cord that goes right to the battery, and I will see what happens when I plug the bunk pad directly to it. If it blows, I will cut off the bunk pad cigg plug and wire in a new one. I do not think it can be my wiring of the box, as I mentioned all three sockets worked when I tested out the tents light.
__________________
| Tags |
| 12v, add, battery, box, camping, charge, gauge, hook, plugs, power, project, supply, tent, trailer, travel, wire |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Affordable roof top tents? | jjrgr21 | Camping, Expedition, & Overlanding Gear | 8 | 09-18-2009 07:34 AM |
| Roof top tents | Corey | Camping, Expedition, & Overlanding Gear | 20 | 03-14-2009 04:34 PM |
| Low priced Roof Top Tents... | CarTopCamper | Vendor Advertising | 0 | 04-22-2008 04:59 PM |
| Roof Top Tents II | Bundubasher | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 05-09-2003 07:57 AM |
