| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Ramblings about air shocks
#2 (permalink) |
![]() pics or it isnt possible...
__________________
#3 (permalink) |
yeah lets see some pics..... Your stock cv's wouldnt allow for 12 inches of travel! But nice idea on the air shock I am going to look into that. Also I didnt think that a bracket lift increased travel..... I might just go pick one up I know where I can get one for $100 thats in great shape and then the air shocks would fit better..
__________________
91 xtra cab 3.0 trail gear 5" sas/ 5" rear kit, TG sliders, bumpers, flatbeded, 529's locked F&R |
#4 (permalink) |
ummmmm, yeah, sorry to tell ya, but 12" of travel would require a little more mods than just differnet shocks...
http://forum.ih8mud.com/79-95-toyota...936-rotbw.html http://forum.ih8mud.com/79-95-toyota...e-options.html and the only reason I know that kinda travel is possible with this setup, is cause I heavily researched it, and actually have half the parts to build the setup ![]() I too would like to see some pics of this setup... if this wasn't your first post, we wouldn't be bust'n yer ass about it
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... Last edited by iamsuperbleeder; 03-19-2009 at 03:13 PM. |
#5 (permalink) |
air bags in front on ifs???
Yea dido im interested in seeing this thing
#6 (permalink) | ||
12" of travel, sounded good......sorta
__________________
Quote:
Quote:
------------------------------------------------------ 1991 Toyota 4Runner SR5 4x4, 3.0 V6, Auto, Alpine CDA-9807, 31x10.5's, 4.56's, 1" RB lift, 2" SDORI Coil spacers, Optima RedTop, Aisin manual hub conversion, and the all important FSM's |
#7 (permalink) |
![]() notice the lower shok mount is wut, 1/2 the distance or less to the outside of the hub (where the wheel mounts) from the a arm pivot ... so the 8" of shok travel translates to LONG travel ifs at the wheel ... i hav the stock top bumpstops there is no way the axleshafts could possibly GO beyond stock downtravel angle ... (it's a stock trailmaster drop mount lift) the pic shows maximum uptravel everything except the torsion bar adjusting bolt is connected i drove this way after i purposely broke the bolt on a dip (i wuz tired of puttin slots in the adjusting bolt holder metal trying to saw thru the bolt hed while laying on the floor with my circular saw, so i broke it insted) it felt funny put a hole in the floor of course made a loud noise too mite even kill sumone sittin in the passenger seat, dunno the axleshaft made no noise so wut's the axleshafts joints max angle? i'm not gonna take mine apart wen i already know mine works and has the stated travel but i'd get airshox cuz they're super cheap and WAY superior there is a neoprene sleeve inside the outer shok cover it's not even a bag or donut just glued i guess the shok body itself is the rest of the air bladder truly excellent stuff had mine at least 3 years never a problem i can air up my rear suspension 5" e z could easily be dun on a sas gawd it will be too phunny if it starts a trend on them *cough* other boards gabriel stopped making the hyjacker rabbit stickers gawd |
#8 (permalink) |
wait a minute, are you serious...
bracket lift with loosened t-bars and adjustable air shocks... you fail... btw, you also admited that you've modified the LCA for the shock mounts, and he's wandering about using a setup on STOCK (as in left alone) control arms, soooo... you fail X's 2
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... Last edited by iamsuperbleeder; 03-19-2009 at 07:40 PM. |
#9 (permalink) |
the track bar clears the frame by 1/4" at full lock
SO how could the axleshaft POSSIBLY be unable to do sed travel ??? i related my actual years of experience just put on a 4" drop kit take out the t bar adjusting bolt jack the wheels off the ground take off the shok and MEASURE THE FREEKING WHEEL TRAVEL ALREADY o k ? dun b surprised wen at full lock the track rod hits the frame cuz it will ... |
#10 (permalink) | |
Quote:
![]() you talking about the TRE's and/or the center drag-link (called the Relay Rod according to Toyota)? those come close to the frame on a BONE STOCK setup... either way, those would have nothing to do with the CV's amount of travel btw, I'd jack the truck up in the air BEFORE removing the T-bar adjusting bolt
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... Last edited by iamsuperbleeder; 03-19-2009 at 07:49 PM. |
#11 (permalink) |
no,
drop mount kit is INSTANT more travel unless u limit it with bumpstops or short shox just like removing the stock bumpstops is instant more travel with NO lift ... wut's cornering like with bj spacers? ever notice the difference in camber change while the suspension flexes? |
#12 (permalink) |
wut is the end of the steering on both sides called?
cums with ball joint... |
#13 (permalink) | |
Quote:
I'm not going to argue about the aditional travel they can give you; that's all providing you take some tention off the T-bars from a stock setting, otherwise all you'll do is effectively raise the front up 4"
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... |
#14 (permalink) | |
Quote:
the inner one is the longer of the two, the one that's got the funky bend in it; it's the one that really comes close to the frame
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... Last edited by iamsuperbleeder; 03-19-2009 at 07:58 PM. |
#15 (permalink) |
jeeeeeeeez
i hav box stock a arms with box stock original mounts and completely STOCK trailmaster 4" lift and am gettin told i'm wrong about my actual experience by someone who duzn't know wut a track rod is if u understood wut an airshok is i guess you would understand how the t bar is not supplying all the lift or "spring" action i can take the t bars off and drive the truck and it mite hav superior ride at least at times CUZ I HAV AIRSHOX gawd |
#16 (permalink) | |
Quote:
listen, bro... I'm not even going to BEGIN to argue with you about experience or knowledge, cause I garuntee you there's a lot of people on YT here that'll back me up and you go ahead and just take yer t-bars off... ride around on them "air shocks" for a few thousand miles... good day sir
__________________
#17 (permalink) |
lemmesee,
didn't somebody named toyody take off the t bars and put only shox on their newer model? gawd airshox in quotes as if they dun exist even tho i provided a pic ... my axleshafts work perfect after 200+K miles original boots almost a foot of travel such a superior ride ... and instantly adjustable lift could hav in cab controls could be modded to eliminate body roll with sensors and valves like an expensive car only DIRT cheap to do that |
#18 (permalink) |
__________________
96 4Runner, 4in lift (883's w/ top plate spacer, Land Cruiser's 8 coil) Pro Comp Xtreme AT 315/75/16's. rear e-locker I UNDERSTAND THE WHOLE JEEP THING THATS WHY I HAVE A TOYOTA!! |
#19 (permalink) |
I was thinking of making my own suspension kit with the help of a local guy that races who made his own. I would say that considering I run a jd fab 4x4 kit that is a 3"+ wider kit and I only pull 14" that you would really need to go wider to pull 12". I think I will have to build my own stuff to be something like 6+" on each side to pull much more then 14" but if Im going that far why not shift the engine back and run a center mounted setup ha ha.
__________________
1994 yoda jd fab lt front,62" deaver back,full glass, and kings. 1997 xj the DD/prerunner 1974 bronco 5.8 EFI 4r70w np205 "IN PROGRESS" With the navigation arrow pointed straight at Ihop Aunt Jamaima really likes me cause my syrup is so hot! |
#20 (permalink) | |
Quote:
I know what air shocks are; I use to retail them all day long I also happen to know what a track bar is, and you WILL NOT find one on an IFS vehicle... period... a track bar is used to keep the axel aligned in a coil spring solid axle setup
__________________
91 PU 22re 4wd MySpace Don't take life so seriously... none of us get out alive anyway... Last edited by iamsuperbleeder; 03-19-2009 at 10:08 PM. |
#21 (permalink) |
@toynado,
when arguing, please type in english. none of these "gawd," "lemmesee," or other random conglomerate words that just leap from your imagination. also, don't argue with superbleeder. He's been with this forum for quite a while, and you sir, have not. Being a part of this forum means learning about, in essence, this specific year of toyota. many users also bring outside experience to the table from jobs or personal repairs / modifications of their trucks. While you may have an interesting setup, please give us pictures IN DETAIL of what you are trying to describe. @ superbleeder, don't be so immature. Let him believe what he wants to. What do you get out of winning an argument with a presumably 16 year old (assumption by diction) over the internet. Arguing over the internet is like the special olympics... even if you win you're still retarded. NOW PLEASE, ASNWER THE OP!!!!!!
__________________
1994 Pickup 22re 5spd M/T 2WD, 188,888 miles -rebuilt front end (totaled to driving in 2 months) -custom spectre intake Toyota Pickup Repair Manual :) My Crash Repair re-Build thread |
#22 (permalink) | ||
Sounds good....sorta. OP, prove your "proven" setup. Pics, decent quality pics of your rig in action, showing your 12" of travel. A very simple way of backing up that in which you are claiming.
Short, and to the point. Pics, or what you are claiming is bogus. Put up, or shut up.
__________________
Quote:
#23 (permalink) | |
Quote:
__________________
#24 (permalink) |
![]() thats a track bar... its on a JEEP... with a SOLID AXLE... and COILS... dun argew wit peepolz dat kno mor dan u... and for the record, the IFS DROP BRACKET LIFT KIT that you have on your truck does nothing to increase the amount of flex that you can obtain with the front end... all it does is drop the front dif down... the flex stays the same... here, i even drew some pictures for you... IFS STOCK... ![]() IFS W/LIFT KIT ![]() also, travis... ![]()
__________________
| Tags |
| 4runner, air, collins, fort, gabriel, outter, pu, removing, rod, shocks, shockstoyota, tacoma, tie, trailmaster, travel |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| air shocks | mrfarinhight | 86-95 Trucks & 4Runners | 7 | 08-31-2008 05:26 PM |
| air shocks??? | bigpest88 | 86-95 Trucks & 4Runners | 0 | 12-01-2006 12:05 AM |
| dangerous ramblings from the Porcelain throne | shiftless89 | Off Topic Talk | 31 | 05-22-2006 09:21 PM |
| Air Shocks | tundra_1 | 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 | 2 | 03-20-2005 09:34 PM |
| Ramblings from a summer on the road... | Flygtenstein | Off Topic Talk | 4 | 08-04-2003 01:47 PM |
