YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area, & More Articles In The Wiki) > Maintenance & Repair
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-30-2008, 02:00 AM   #1 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
Step by step: Replacing radiator on 3rd gen p/u
So your rad needs replacing, mine did too. This writeup is intended to shed light on the task of changing out a rad and how to properly flush a radiator.
*Note* My truck is equipped with a 3" performance accessories body lift kit. This kit uses brackets to drop the rad, these brackets use non-metric SAE nuts. Notes posted with a * refer to body lift equipped trucks only.
Tools/supplies needed:
-Metric sockets/open ended wrenches 10-12-14mm
* SAE sockets/open ended wrenches 1/2"-
-Flathead screwdriver
-Plyers
-Jugs to hold old coolant. (near 7 gallons once flushing is complete)
Parts needed:
- Radiator
- 2 jugs of Toyota Red coolant
- 1-2 gallons of distilled/purified water
- Oem toyota Thermostat
- Consider replacing your rad cap if your new rad didnt come with one
- Also consider replacing your rad hoses
*note* I also replaced my fan shroud at this time
Prepping for removal
- Park truck on level ground
- Open hood
- Remove rad cap along with the overflow hose and tank (for clearance)
- Remove battery (for clearance)
- unbolt and move washer fluid tank out of the way
- Remove 4 12mm bolts on skid plate
- Locate the drain on the bottom right of the rad. If your rad is a toyota brand rad the drain will look like this.
-If aftermarket, the drain will look a little different. Should be in the same location.
- Use plyers to open the drain.
-Don't forget to undo the rad hoses. Becarefull of the bottom one, there is going to be coolant stored in it.
Try to catch it with your drain jug/pan and not your face like me
- I used the time waiting for the rad to drain as an oppertunaty to unbolt the rad.
- It is only mounted by 4 bolts on the radiator support.
*note* The drop brackets pictured on the rad mounting points are due to the body lift.
- Clearance will be tight, take your time. I used a rachet to start them off, then when the rachet wouldnt fit anymore I used an open ended wrench.
- Now that its unbolted it can come out. Be prepaired to wiggle and finess the rad out, it can be a fit fit.
*note* My fan shroud was torn to bits prior to this, I did not have to worry about its clearance when removing. You may need to undo the 4 mounting nuts and remove it from the rad for clearance over the fan.
Removal
-Once removed, it might look a little something like mine did...
Me thinks that shroud is not very effective...
- Now is a perfect time to replace the thermostat. I opted not to as it was replaced earlier this year.
-It is also a perfect time to test your fan clutch ( if equipped). Spin with considerable force, if it rotates more then 1/2 way, it should be replaced.
Instalation
- Place the fan shroud over the fan
- Slowly lower the rad into the engine bay
- Make sure to avoid the mounting studs, they can rip fins out without a problem
- Don't force anything!
- It should look something like this once loosley in place.
- re-install 4 rad mounting bolts
- re-install 4 rad/shroud mounting bolts (tighten by hand)
- re-install coolant hoses
- re-install Overflow tank
- bolt down washer fluid tank
- reinstall and connect battery
It should now look a little like this..
- Fill rad cold completly full with tap water. This is just to get everything flushed.
- Put on rad cap once full, and start the truck. Get everything circulating for a few minutes. I waited just till the thermostat opened then shut off the engine.
- Now open the drain and drain out all the water/coolant.
*note* Make sure you catch this stuff in a jug, there will be a good amount of coolant in it from inside the block.
-Once flow has stopped tighten drain
- Now its time to fill it up with the good stuff.
- Pour in one jug of toyota coolant
- Fill that now empty jug with distilled water and pour it in
- Now mix some 50/50 mix in that jug and use that to top everything up
- Now we need to burp the rad.
- Jack up the front of the truck a good foot or so. The more the better!
- Support on jackstands (dont forget to chock a rear wheel)
- Open the rad cap and Start the truck
- Make sure your heater is set to hot, this will flush the heater core
- Watch the bubbles come out of the rad and add coolant accordingly
- Squeeze the upper rad hose to get excess air out of the top
- Don't forget to fill up the overflow tank
Make sure you feel the upper and lower rad hoses periodicly to make sure the coolant is circulating properly.
- Once truck is fully warmed up, put on rad cap and shut off engine.
- Remove jack stands and lower truck
- Re-install the skid plate
Don't forget to rinse off your work area if you spilled any coolant.
Over the next few days keep an eye on your coolant level, Toyota rads are notorius for holding air. This air should purge out and the coolant level will drop. Make sure you top it up after every drive.
Congrats you are done! Grab a beer and relax.
If I have missed anything, or if you have any helpfull hints that could be helpfull for this process, feel free too PM me.
-Jay351
*Please note* You can buy kits to aid in flushing the rad, this may be needed if you cannot get everything flushed out by yourself. They go for about 30 bucks or so.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Finally! Painted the toyota. Step by step pics. 56K no no. MIKEMOKAS 86-95 Trucks & 4Runners 54 10-18-2008 09:05 AM
WTB...3rd Gen. step bars and/or fender flares. The_Original_Zimp Items Wanted 1 05-01-2006 10:03 PM
Step by step intructions for retro-fitting 99-02 front bumper on 96-98 4Runner? Jason B 95.5-2004 Tacomas & 96-2002 4Runners 4 08-31-2004 09:11 PM
3rd Gen Side Step Bars FORANA 95.5-2004 Tacomas & 96-2002 4Runners 2 08-18-2004 03:17 PM
Lift install: Step by step Instructions AznSky 95.5-2004 Tacomas & 96-2002 4Runners 11 10-15-2003 05:12 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
