Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Idler arm rebuild how to
Worn idler arms, very common thing. Most people will buy a new idler arm for 100 dollars plus! Here is how you rebuild it, to like new condition for under 10 bucks.
Symptoms: shakey wheel on the hwy, sloppy steering. To check: Get a friend to get in your truck, and turn the wheel side to side. If your idler arm moves up or down its time to rebuild. Supplies/tools: -12mm socket -19mm socket -17mm socket -14mm socket (if installing a brace) -Long rachet for leverage -17mm open end wrench -14mm open end wrench (if installing a brace) -Hammer -Flathead screwdriver -Grease -Idler arm bushings Removal No pictures due to greasy hands. I found removal easier if your wheels were turned to full lock to the right. -Remove 4 12mm skid plate bolts and remove and set aside skid plate -Remove the idler arm cotter pin -Remove castle nut -Remove 3 17mm bolts holding the idler arm to the frame *keep track of the bolts, they are different lengths* -Smack the relay rod with a hammer and idler arm should pop out" *note* Some have had problems removing the idler arm and have had to rebuild it while it is still installed. Dissasembly Using your flathead screwdriver pry off the idler arm cap. I had to tab the screwdriver with a hammer to break the seal. ![]() Next remove the 19mm nut at the top of the idler arm. This holds the whole assembly together. It will probibly be very tight, I used a breaker bar for this job. ![]() Remove the nut and remove the washer. Mine was pretty stuck so I had to pry it out with my flathead screwdriver. ![]() Next, slide the arm out of the housing. If your idler arm has not been serviced in a long period of time, don't expect this to be easy. Mine was rusted in place and took a good whack or two with a hammer to get out. Here is the arm out and the old worn bushings removed from the housing. ![]() Your idler arm is now dissasembled. Reassembly Take your new idler arm bushings (pt# 90386-18002 for 86-91 trucks and 4runners) out of the packaging. Here are the old vs. new bushings ![]() Now, do not lube your bushings yet. Install them into the housing dry. They are a tight fit so carefully use a hammer to tap them into place. Lube the surface of the bushings now. Generously lube the shaft of the arm assembly and slide it back into the housing. ![]() Slide on the big washer followed by that 19mm nut. Sinch the bolt down tight. Torque the big nut to 58 ft–lb. ![]() Last but not least, tap the idler arm cap back into place. Feel free to use a little adhesive here to make sure it will not fall off. ![]() If you are installing a brace or have one installed already. The big flat washer and the idler arm cap are not reused. Re-install -Slide the arm into the relay rod -Install 17mm castle nut loosly -Install 3 17mm bolts holding the idler arm housing to the frame *torque to 105ft-lb* -Tighten 17mm castle nut on relay rod to 43ft-lb -Install new cotter pin *Optional stuff* You can also drill, tap and add a zerk fitting on the housing so you can grease it regularly. Brass bushings are also available for around 45 dollars. But you will probibly need to machine them to fit: http://www.custommachiningusa.com/Specialty_Items.html DONE ![]() You should now have much better steering feel and smoother operation. All for under 10 dollars and an hour of your time. I would rate this job a 3 out of 10. If you can do your brakes, you can defantly rebuild your idler arm.
__________________
91 Pickup - xcab - 5sp - 3.0 - sr5 - 4x4 - 230,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs |Diff breather mod | Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 Last edited by Jay351 : 05-24-2008 at 12:16 PM. |
| Sponsored Links |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Idler arm rebuild woes | Matt16 | 86-95 Trucks & 4Runners | 5 | 12-01-2007 02:00 AM |
| Idler Arm Rebuild? | Saint_Berzerker | 86-95 Trucks & 4Runners | 5 | 09-20-2006 03:59 PM |
| Replace or rebuild idler arm? | Tiger Paw | Maintenance & Repair Archives | 2 | 05-02-2005 10:16 AM |
| idler arm rebuild | Churnd | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 01-16-2003 01:48 PM |
| Idler Arm Rebuild | MNRUNNER | Maintenance & Repair Archives | 10 | 12-02-2002 01:31 PM |
