Staging Area For Tech Article Submissions Got a tech article to submit? Post it here
Hi-Lift and Tool Mounts (DIY under $20) - 2nd Gen Tacoma
Old 01-28-2013, 08:59 AM
Benson X's Avatar
I finally got around to making a mount for my Hi-Lift using the factory bed rails, and ended up making a few more for my shovel, axe, hatchet, fire extinguisher, and flashlight.
I have limited tools, so I had to improvise on some things. Not all the holes and measurements are 100% exact, but each mount it still solid and secure.
NOTES:
  • A drill press and vise is recommended and would speed up the entire process. I did not use either, but it made for additional work.
  • You can make all the mounts on here using (2) 36" pieces of flat-bar (listed below)
  • Most people will be using different style shovels, axes, hatchets, flashlights, fire extinguishers etc. - keep that in mind and make sure to measure and test fit your tools before drilling and cutting. Don't get pissed at me if your setup isn't the same as mine.
  • I am not proficient in drafting or design, so please excuse the crappy dimensions/diagrams
  • Please feel free to leave pertinent questions, constructive feedback, or comments.
  • As always, I am not responsible for any damage or injury resulting from anyone doing these mods.
TOOLS USED:
Drill (or drill press)
Center punch
Small Pilot bit (7/32")
1/4" bit (titanium recommended)
5/16" bit (titanium recommended)
3/8" bit (titanium recommended)
Hammer
Vise (or equivalent)
Cut-Off Wheel (Dremel works)
10mm wrench and socket
13mm wrench and socket
14mm wrench and socket
Tape measure
Sharpie
LIGHT!!!
PAINT:
I primed and spray painted each mounting bracket black. I then dipped each bend in Plasti-Dip and double-dipped the bottom mounting brace for the fire extinguisher. The plasti-dip should help prevent any vibrations and absorb some shock.
----< Hi-Lift Mount >----
PARTS NEEDED:(each part is a hyperlink)
I got pretty much everything at Home Depot aside from the T-Nuts.
(2) 3/8-16 T-Slot nuts
(1) 1.5" x 18" Steel Flat Bar (1/8" thick)
(2) 2" 3/8-16 Bolts
(2) .75" 3/8-16 Bolts
(2) 3/8" Lock Washers
(6) 3/8" Washers
(2) 3/8" Fender Washers
(2) 3/8" Rubber Fender Washers
(2) 3/8-16 Nylon Locking Nuts
(2) 3/8-16 Jam Nuts
(2) 3/8-16 Wing Nuts
Step 1:I measured, cut and drilled my mounting plates using the 1.5" x 36" Steel Flat Bar (1/8" thick).
I measured 9" down and marked it with my Sharpie, and then made another mark at 8".
Cut it off @ 9". Bend it to 90
° from the 8" mark using your hammer and vise (or equivalent). Make (2) of these pieces.
I drilled my top holes .75" down from the top (the un-bent side) centered .75" in.
I drilled my second holes 4" down from the top, again centered .75" in.
Step 2:Assemble your mounts and attach to the bed rail.
For the Hi-Lift Mounting Bolt:
2" Bolt >>> Mounting Bracket >>> Nylon Locking
Nut >>> Washer >>> Jam Nut >>> Hi-Lift >>> Wing Nut
*NOTE* When tightening your Jam Nuts down, make sure the flat edges are parallel to the edge of your flat bar. The Jam Nuts fit perfectly in the Hi-Lift holes to help stabilize it when mounting and help hold it in place.
For the T-Slot nut that goes in the rail:
T-Slot Nut >>> Fender Washer >>> Mounting Bracket >>> Washer >>> Lock Washer >>> .75" Bolt
Assembled:
Step 3:Attach it to your bed rails, and mount your Hi-Lift
FRONT:
BACK:
DETAIL OF THE JAM NUT IN THE HI-LIFT HOLE:
HI-LIFT MOUNTED
Benson X is offline
Old 02-10-2013, 02:23 AM
Benson X's Avatar
----< Tool Mount >----
I got pretty much everything at Home Depot or Lowe's aside from the Quick-Fists and T-Nuts.
(4) Original QuickFists (I got the combo pack + 2 originals)
(1) 1.5" x 19" Steel Flat Bar (1/8" thick)
(2) 1-1/2" 3/8-16 Bolts
(6) 3/8" Fender Washers
(6) 3/8" Thick Rubber Fender Washers
(4) 1/4-20 1" Bolts
(4) 1/4-20 Nylon Locking Nuts
I measured 9.5" down and marked it with my Sharpie, and then made another mark at 8".
Cut it off @ 9.5". Bend it to 90
°from the 8" mark using your hammer and vise (or equivalent).
Make
I drilled my 3/8" top holes .75" down from the top (the un-bent side) centered .75" in.
I drilled my 1/4" holes 2.5" down from the top, and the third set at 5-5/8" down from the top, both centered .75" in.
Step 2: Assemble your mounts and attach to the bed rail.
Quick-Fists to the Mounting Bracket:
1" 1/4-20 bolt
>>> plastic washer (incl. w/ Quick-Fist)>>> Quick-Fist >>> flat bar >>> 1/4 washer >>> 1/4-20 nylon locking washer
Mounting Bracket to the T-Slot Nut: I had to stack the fender washers to make a spacer. Otherwise, my shovel would hit the rail.
1.5" 3/8-16 Bolt
>>> 3/8 lock washer >>> Mounting Bracket >>> fender washer >>> rubber fender washer >>> fender washer >>> rubber fender washer >>> fender washer >>> rubber fender washer >>> T-Slot nut
Step 3: Attach your mounting brackets, and mount your tools.
Benson X is offline
Old 02-10-2013, 02:31 AM
Benson X's Avatar
----< T-Mount >----
(2) Original QuickFists
(1) Super QuickFist
(1) 1.5" x 28" Steel Flat Bar (1/8" thick)
(2) 2" 3/8-16 Bolts
(2) 1-1/8" 3/8-16 Coupling Nuts (used as spacers)
(2) 3/8 Lock Washers
(2) 3/8 Fender Washers
(2) 3/8Thick Rubber Fender Washers
(5) 1/4-20 1" Bolts
(5) 1/4-20 Nylon Locking Nuts
(5) 1/4 Washers
(3) 5/16-18 1" Bolts
(6) 5/16 Washers
  • I measured 14" down and marked it with my Sharpie. I made another mark at 24" and one more mark at 27.25"
  • Cut into (3) pieces: 14", 10", and 3.25"
  • Bend the 10" piece 90° at the 8" mark.
Piece #1- (14") The Top Mount
Drill holes according to the diagram:
Piece #2- (10" bent 90° at 8") The Middle Mount
Piece #3- (3.25" curved to form a "J") The Bottom Brace
Step 2: Assemble Your T-Mount
Starting with your Top Bar, tighten your Original Quick-Fists to the 1/4" holes on each end. I attached them just as I did on Tool Mount:
Quick-Fists to Top Bar:
1/4"-20 Bolt >>> plastic washer (incl. w/ Quick-Fist) >>> Quick-Fist >>> Mounting Bracket >>> 1/4 washer >>> 1/4-20 nylon locking nut
Next, attach your Bottom Brace to the Middle Bar.
Bottom Brace to
Middle Bar:
1/4"-20 Bolt >>> Bottom Brace >>> Mounting Bracket >>> 1/4 washer >>> 1/4-20 nylon locking nut.
Lastly, attach your Super Quick-Fist to your Top Bar and connect the Middle Bar.
Super Quick-Fist To Top Bar:
5/16-18" bolt >>> 5/16 washer >>> Super Quick-Fist >>> Top Bar >>> Middle Bar >>> 5/16 washer >>> 5/16"-18 nylon lock nut
Tighten the last 1/4"-20 bolt through the Top Bar into the Middle Bar.
Assembled:
Step 3: Attach the T-Mount to the bed rails
Now it's time to attach the T-Mount to the bed rails.
2" 3/8-16 bolt >>> 3/8 washer >>> T-Mount >>> 3/8 lock washer >>> 1-1/8" 3/8-16 coupling nut >>> 3/8 fender washer >>> 3/8 rubber fender washer >>> T-Nut
Assembled:
----< Finished Product>----
Benson X is offline
nick9455649
09-11-2015 05:10 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
skoti89
07-08-2015 12:05 AM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Hi-Lift and Tool Mounts (DIY under $20) - 2nd Gen Tacoma
