A Arm Bushing Replacement for T100 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Tech Write-Ups (Staging Area & More Articles In The Wiki) > Staging Area For Tech Article Submissions
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-10-2008, 12:29 PM   #1 (permalink)
89OldBlue's Avatar
While recently changing the brakes on my dad's 96 T100, I noticed that the whole A Arm shook as I wrenched on the bolts to take the calipers off. So, a week later, I began dis-assembly, and here are the steps.
1. Raise truck, supporting the frame with jack stands.
2. Remove tire.
3. Remove the 4 bolts that bolt the A arm to the spindle (what the rotors are mounted to) (Both nut and bolt are 12mm).
4. Remove the 2 bolts that are at the frame side of the A arm (19mm).
Before next step, note that there are shims that are between the frame and the bar on the back of the A arm, which need to be replaced in the same orientation as they were removed.
5. Open the hood and remove the two bolts that bolt throuhg the bar on the back side of the A arm, which bolt to the frame (19mm).CAREFUL OF THE SHIMS!!!
6. The A arm will now slide out, and you will need to take it to a machine shop to have the old bushings pressed out, and the new bushings pressed in.
7. Replace in the same order as removed and voila!
89OldBlue is offline
Tags
arm, bushing, bushings, control, forum, idler, lower, removal, replace, replacement, side, steps, t100, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Control Arm Bushing replacement? 86Original 86-95 Trucks & 4Runners 19 06-15-2009 08:42 PM
A-arm bushing replacement Wildcat_4R 86-95 Trucks & 4Runners 9 07-02-2007 01:45 AM
Control Arm Bushing Replacement BLKNBLU 95.5-2004 Tacomas & 96-2002 4Runners 14 07-01-2007 09:18 PM
Idler arm bushing- quick one... climo 86-95 Trucks & 4Runners 1 12-29-2006 08:43 AM
FS: IFS 89-95 Control Arm Bushing AH64ID The Classifieds GraveYard 3 10-08-2006 03:15 PM
2009 InternetBrands, Inc.
