YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 12-07-2007, 08:08 PM   #1 (permalink)
Yeah, another 4.3L to 4runner swap question
I've looked around this site and other places on the web and still have some questions about the GM 4.3 swap into a 1990 4runner.
The '90 4runner 3.0 L automatic blew a head gasket and developed a knock, so we plan to retire the engine. We found (and bought) a donor vehicle, a '90 Blazer S15 4x4 automatic - it suffered a rollover during offroad manoevers but runs good.
First question: Is it possible to use the GM Blazer 4.3, GM 4 speed automatic transmission, and GM transfer case in the 4runner? It seems that many use the 4.3, add on an older TH350 (for the correct length), and then use an Advance adapter to fit the transmission to the Toyota transfer case. But is that necessary? Is it possible and practical to use the Blazer 4 speed automatic and transfer case? What problems or advantages are there to this?
Second question: Advance Adapters, Northwest Off Road, and Downey are three names that keep on coming up for doing the swaps. What is our best choice, given the swap we want to do? If anyone has experience with this, can you tell us what parts we need to buy?
Thanks for your help.
swamp dog is offline
Sponsored Links
To remove this ad, register today!
Old 12-07-2007, 08:14 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Search Pirate aswell for info on this. You dont have to use the toyota trans an tcases you can use the 4 speed but some people like the manual yota trannies and they work well and fit nicely behind a 4.3. Another stonger better option is to put a jeep ax15 behind it. do some more searching cause the info is out there. As for does it work??? Anything is posible to make work if you have the time,money and skills to do the job its possible and yes it has been done
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 12-08-2007, 07:29 AM   #3 (permalink)
4.3
I run a 92 4.3 CPI,700R4,Toy x-case in my 1986 runner. It all fits great ! I am not sure about running the chevy case. I guess its possible, check for clearance issues. I didn't go with the chevy case, because I already had my built Toy transfer case. Downey has a good TBI-TPI conversion manual, but its more of a sells pitch.
If you need help, just drop me a message.
4runnerchevy is offline
Old 02-26-2008, 09:01 PM   #4 (permalink)
4.3 engine swap
this may seem like a dumb question but i don't know a whole lot about piston engines lol im a rotary guy myself and i have a 1990 4runner auto tranny and i was wondering is there anything i need to get to do a swap for my 3.0 efi? thanks
mtrandall is offline
Old 10-06-2008, 02:33 PM   #5 (permalink)
pattergrub's Avatar
hey dude downey gets their mounts from advance adapters anyway
__________________
91 pickup: v8 swap almost done!! holley carb, edelbrock intake, 4"pro comp lift, 4:88 gears, detroit lockers front and rear, downey intake, downey fibreglass fenders and hood, jet ecm, pro comp skid plate, warn bumper, 33" mickey thompson mtz's, pro comp steering stab. msd distributor, alum rad, Hunsaker suspension seats, grant steering wheel, 205 t.c. - custom drive shafts -
pattergrub is offline
Old 10-06-2008, 09:11 PM   #6 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Quote:
Are you asking about a swap from a 3.0 to a Chevy 4.3?
You'll need the engine, either the adapter to use your trans and transfer or the stock chevy trans/transfer, ECU and wiring harness from the 4.3, exhaust work, Chev fuel pump, motor mounts, possibly new tran crossmember, probably drive shaft work, and other things I cant think of.
Adam F is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Yeah, I'm a noob still. Tire question deathrunner 95.5-2004 Tacomas & 96-2002 4Runners 13 07-18-2007 09:44 AM
Oh Yeah! Got me a 4Runner. MadCityRich 95.5-2004 Tacomas & 96-2002 4Runners 3 12-11-2006 08:31 PM
Wiring Question: 5 spd Swap from Auto, '89 4runner wrenchtech 86-95 Trucks & 4Runners 1 05-01-2006 01:42 PM
Finally lifted my 04 4Runner Limited, yeah! Duc Hunter 03+ 4Runner/GX470, & 05+ Tacomas 37 03-06-2005 06:32 PM
Yeah, another horn question hungryStu 95.5-2004 Tacomas & 96-2002 4Runners 4 02-12-2004 05:50 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
