v8 swap 82 toyota - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-29-2009, 05:32 PM   #1 (permalink)
Question v8 swap 82 toyota
i got a 82 toyota and i wanna put a 350 in it what all do i need to do and what to worry about, thanks
stillblazed is offline
Old 06-30-2009, 01:37 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Starts using the search function at the top of the page. also search the forums as theres an entire section on motor swaps. IMO the 350 is too big and heavy without doing mad amounts of fab and other work to have it as your powerplant. Another great option thats a chevy motor for you is the 4.3. better choice IMO into that truck
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 07-07-2009, 04:55 AM   #3 (permalink)
Yeh i put a 4.2 Chev in my 80. Lots of work but hey at the end of the day lots of fun now its on the road
HarryBCO is offline
Old 07-09-2009, 06:38 AM   #4 (permalink)
Banned 'cause I was 4runnerchevy also banned
4.3 is just about the easiest swap for a Toyota, and the best bang for the buck.
86toylet is offline
Old 07-27-2009, 02:50 PM   #5 (permalink)
if youre stuck on a v8, a buick 350 would be perfect!
it is about an inch wider/taller/longer then a 350 but it'll fit(same kit as buick 231/3.8 v6) the kicker is it only weighs 450lbs.
and if you want to convert to a serpentine setup you'd just have to get the parts for a gn setup.
but a chevy 4.3 will give it good performance without being overpowering
and unlike a chevy 350 both can be had used for low $$ more so on the buick 350..
Nothingface5384 is offline
Old 07-27-2009, 08:51 PM   #6 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Quote:
Originally Posted by Nothingface5384 View Post
and unlike a chevy 350 both can be had used for low $$ ..
Huh? A 350 is about the cheapest engine out there. Parts are a dime a dozen, readily available, and in TONS of cars and trucks in the junkyard. I've seen a few given away for free.
Thats what makes the 350 swap so desireable.
Adam F is offline
Old 07-28-2009, 07:20 PM   #7 (permalink)
around my area, chevy 350s go for 450 to 600(plenty for 500)
buick 350 you can find a 70-80k engine for 50 bucks to 150...just picked one up for 400 with only 23k on it
ive found plenty of 80k 4.3 for 150 to 250
was just stating you can fid both those engines for same milage or less for less cash
Old 08-06-2009, 10:28 AM   #8 (permalink)
BlueRidge's Avatar
Do your homework bro on that swap. A 1980 only has 31 inches of space from firewall to where the radiqtor mounts. I'm currently installing a 302 and it's tight, even with the short Ford Racing water pump kit it's a bitch to get it all in without fabricating/modifying anything.
BlueRidge is offline
Tags
1980, 1980s, 350, 4runner, 82, chevy, info, put, sale, setup, swap, swapped, toyota, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
