V8 with Air Conditioning? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-02-2008, 11:26 PM   #1 (permalink)
RevNL's Avatar
Has anyone ever swapped a V8 and saved the air conditioning?
The Chevy V8 is sitting on the mounts and is stuffed as far back as it will fit. The engine has a long pump and serpentine belt accessories, which I'd also like to keep. There's enough room for a radiator but an electric fan will have to sit behind the grill in place of the AC condenser.
I really want to keep the air conditioning.
If I reform the firewall around the distributor enough that the cylinder heads become the limiting factor (or go with an LT1), it still doesn't look like it will buy enough space to put the fan behind the radiator or fit a belt fan.
Has anyone successfully done this before?
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift
RevNL is offline
Old 04-06-2008, 03:37 PM   #2 (permalink)
RevNL's Avatar
I ask some fun questions, don't I...
I will figure this out, and I'll post the outcome with photos when it's done.
__________________
RevNL is offline
Old 04-06-2008, 07:00 PM   #3 (permalink)
one2high's Avatar
If you go with the LT1, you can put the fan where it belongs and keep the AC. You need a slim 16" electric fan and I bought the brackets from Street & Performance.
__________________
94 X-cab, SAS, LT1, T350, 205TC, 35" swampers, molded bushwackers, custom bumpers and winch soon
94 Springer Softail, 7 gal stretched tanks, 18" ape hangers, kick/electric start, dakota digital dash, 80 twisted spoke wheels
one2high is offline
Old 04-07-2008, 03:16 PM   #4 (permalink)
RevNL's Avatar
Quote:
Nice. Does it stay cool? Would that have worked with the factory engine brackets?
I formed a pocket into the firewall last night for the distributor so the block now sits as far back as an LT1 would fit. Still has that water pump pulley in the front, though. At the very least, there is now a lot more room to work with than before.
The plan at the moment is to use a Summit aluminum 22"x19" radiator, trim the sheet metal so the AC condensor can move in a little closer to the engine, and then mount a fan or two in front. Need to make sure the grill will still fit.
__________________
RevNL is offline
Old 04-07-2008, 06:48 PM   #5 (permalink)
one2high's Avatar
I made my own motor mounts and moved the cross-member to fit. Can you go with a short water pump and keep the serpentine belt? I would check on that option. It would give you the room you need for the A/C and room for the fan also. I used a V6 auto radiator and the original LT1 pressure tank.
__________________
one2high is offline
Old 04-08-2008, 10:44 AM   #6 (permalink)
RevNL's Avatar
The long pump is required for the GM serpentine belt setup. I like the reliability of the stock belt drive, and the more OEM parts the local smog police see under the hood, the less trouble they'll give me.
Wonder if I can use a belt fan? All this work to carve out 3 or 4 inches for a high dollar electric fan. Why wouldn't a low profile belt driven fan fit in the same space? That would solve a lot of problems.
Hmm...
__________________
RevNL is offline
Old 12-19-2008, 08:03 AM   #7 (permalink)
v-8 swap
I am in the middle of this same problem right now on a 85 4runner with chevy small block. So far the cheapest route I have found is a sep. kit from www.alangrovecomponents.com It uses the corvette short water pump reverse roatation which is within an 1/8" from the old shorty pumps from the 60's Looks like you could also still use an engine driven fan without clutch and not have too hack anything on the yota
LouisianaToyota is offline
Old 12-19-2008, 12:53 PM   #8 (permalink)
RevNL's Avatar
Quote:
I still haven't figured this one out. With a long pump and GM serpentine belt accessory drive, the choices are:
Radiator in stock location, electric fan in front of radiator = No A/C
Move radiator forward in grill, electric or belt fan behind radiator = No A/C
And I've modified the firewall for the distributor and moved the block back as far as the valve covers will allow. Even then, it's tight up front.
A short pump setup would help a lot.
I'm contemplating building a small freon-to-water intercooler under the hood, then plumbing it into a mini-radiator under the bed. Hey, it might work?
__________________
RevNL is offline
Tags
1993, 57, air, belt, conditioning, dakota, engine, ford, grill, route, routing, serpentine, swap, toyota, v6, v8, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Removing Air Conditioning or converting to air compressor??? NMcruser Offroad Tech 8 11-28-2008 01:46 PM
95 air conditioning into an 88 ozziesironmanoffroad 86-95 Trucks & 4Runners 6 11-22-2007 06:49 PM
Air conditioning Road Head 95.5-2004 Tacomas & 96-2002 4Runners 2 01-16-2006 03:45 PM
Air Conditioning nigeltufnel3 95.5-2004 Tacomas & 96-2002 4Runners 4 04-03-2004 06:31 PM
Air Conditioning castrolSi 95.5-2004 Tacomas & 96-2002 4Runners 6 07-08-2003 06:06 AM
2009 InternetBrands, Inc.
