| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Torque converter 2nd & 3rd lockup?
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 |
#2 (permalink) |
Well, you would think that the 2nd and maybe the 3rd lockup might be handy for passing, but if you floor it, you're gonna downshift anyways. I had a camaro with a 700R4 and the lockup was really touchy in 4th so it would be nice to be able to hold it in there when you needed to.
__________________
2001 Toyota 4Runner SR5 4-Dub TRD supercharger, Thorley Headers, URD 7th, Toytec Coilovers, OME 890's, baseball card in spokes |
#3 (permalink) |
I think I will wire it up for 2nd, 3rd & 4th on one leg and 4th only on the other and see how it functions.
I will post my results.
__________________
#4 (permalink) |
Either way you go, that's a killer option to have at the flip of a switch, good luck with that.
__________________
#5 (permalink) |
I put in a relay with a floor switch in my Toyota auto (343f) for this option. I did it because I have a diesel and try to get really good mpg by going easy from stops. The high factory stall (2200 rpm) makes this a pita so I lock it up @ 15mph in 2nd and then shift through the gears keeping it between 1500-2100 rpm which works great for the diesel. The floor switch makes it nice to turn off and on easily in traffic.
#6 (permalink) | |
Quote:
I am installing an LED indicator so I will be able to tell what I have selected more easily. I like the floor switch idea!
__________________
#7 (permalink) |
where did you get this lock-up switch from. cuz i am doing pretty much the same set up as you i just havent decided on runnigh the stock ECU or using the mega squirt 2 system yet.
__________________
1990 PU total of 8" lift, SAS, 5.29 gears, front lock right rear spool, 22re, 5 speed, std cab, short bed, supra AFM, thorley header, and 37" toyos. future mod: some spydertrax full axles as beefy as they got' em,ARBs front and rear, and some good bumpers, supra 7mgte with all the go-fast parts, new cab and body. 1994 2wd PU LCE intake and full custom exhaust.-for sale. |
| Tags |
| 343f, 4runner, 700r4, 7mgte, converter, high, indicator, lock, lockup, stall, switch, tc, torque, toyota, wiring |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Converter lockup switch (for the auto guys) | Flash319 | 86-95 Trucks & 4Runners | 3 | 10-31-2008 07:43 AM |
| torque converter lockup problems | toyotaoffroad91 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 08-12-2005 09:37 PM |
| Torque Converter Lockup | 93ToyKid | 95.5-2004 Tacomas & 96-2002 4Runners | 9 | 03-17-2005 05:50 AM |
| No converter lockup | quick2300 | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 12-20-2004 04:28 AM |
| I want to manually work the Torque converter lockup | williemon | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-16-2004 07:32 AM |
