Temperature Sender Adapter? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-21-2008, 11:58 AM   #1 (permalink)
RevNL's Avatar
I want to thread the Toyota temp gauge sender into a Chevy block. Everybody says I should be able to find a thread adapter at an autoparts store, but every time I ask for it they look at me like I have an arm growing out of my forehead.
I tried a hydraulic shop, and although they understood what I described, they didn't have anything that fit.
This has been done before. Does anyone know if I can just call somewhere and order one?
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift
RevNL is offline
Old 11-21-2008, 04:05 PM   #2 (permalink)
texcat101's Avatar
http://www.novamaxindustrial.com/adapt-main.htm
Maybe this will help, I have seen the specific one you need referanced somewhere.
I will try to find it.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster.
4.3 vortec / 700r4, Megasquirt II, EDIS6
texcat101 is offline
Old 12-08-2008, 08:36 AM   #3 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
I got mine at Home Depot in the plumbing section.
I forget the exact sizes though. Bring in your Toyota sender, and the stock Chevy sender, and you should be able to match it up.
I think the Toy sender is actually a metric thread, but standard threads will work. Mine actually leaks just a little tiny bit. I need to take it out and re-seal it.
Adam F is offline
Tags
4runner, 57, 700r4, 88, adapt, adapter, chevy, fit, ford, sender, speedometer, temp, temperature, thread, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
temp sender caf325 86-95 Trucks & 4Runners 7 04-24-2008 02:06 PM
Speedometer sender sniper626 The Classifieds GraveYard 2 12-14-2006 11:26 AM
EGR Valve Temperature Sender PAhydrohead 86-95 Trucks & 4Runners 7 08-12-2006 06:23 AM
Virus sender Pt. II MRael Off Topic Talk 13 07-20-2002 04:12 PM
Virus sender Corey Off Topic Talk 7 07-18-2002 09:48 PM
2009 InternetBrands, Inc.
