| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#101 (permalink) | |||||
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 Last edited by texcat101; 02-04-2009 at 06:31 PM. |
#102 (permalink) |
looking good!
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#103 (permalink) |
update
I thought I would post the Gates part #'s for the radiator hoses, the short one is the lower. The rubber adapter bushings are for 1 1/4" but they easily stretched over the 1 3/8" radiator nipples, it didn't make for as tight a fit as I would like but with a good clamp I think it will work okay. I double clamped the lower.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 |
#104 (permalink) |
update, taking shape
got the edis plug wires, and air filter installed this afternoon. Very close now, this engine does look strange in the 4runner, but I like it.
__________________
#105 (permalink) |
Wow I like how empty it looks in there lots of room to work unlike the 3.0. I am thinking about doing the same to my 93 but not sure if my 4 cylinder 5 speed will hold up to it or if I need a v6 5 speed either way I LIKE IT looks super clean.
__________________
1990 4 runner 5 Speed Pro Comp Stage II 4" Lift 6" coils rear Aussie Locker front 5.29's Front And Rear 35 x 12.5 x 15 MT's Micky Thompson Classic II Wheels Super Charged 3.4 on the way 1993 SAS 4runner 22re 5 speed 4" front 5"rear 5.29's 35 x 12.5 BFG KM'S Dick cepek DC 1's 88 stock 4runner 3.0 auto for now 1955 Harley Davidson Springer Stock 1955 Hardtail Frame 4 Speed Kick Start Only 1998 Harley Custom Dresser 107 rwhp 139 ft.lbs.trq. |
#106 (permalink) |
The 4.3 fits well I removed most of the harness, filter box, pwr steering reservoir. Lots of guys doing v8's- not for me, I like having the room.
__________________
#107 (permalink) |
weekend update
I finished wiring the MSII relay box, I needed an Isolator for all of the extra terminals and circuits [ edis, starter relay, stereo amp...] so I installed this battery isolator switch to serve both purposes...
![]() ..finished the tranny cooler plumbing ![]() installed the adjustable vacuum switch for lockup control on the 700r4, this will allow more control over the lock up and kickdown timing.
__________________
#108 (permalink) |
exhaust installation
I had my exhaust installed today by a local shop, 2.25" from the header on each side to 2.5" at the Y, on back thru a generic flomax and out on the drivers side.
The big question on this job was where to crossover, we chose to do it back of the t'case instead of the gap between the tranny pan and converter cover The tailpipe exits a little too low [something I can fix] but overall its a good job- we shall see how it performs and sounds. ![]() ![]() ![]()
__________________
#109 (permalink) |
how close are you to firing this thing up?
__________________
#110 (permalink) |
I had to learn some of the megatune basics and configure the program to burn to the ecm....
I fired it up today and it sounds mean!! ![]() I have to do more tuning and that will be much easier to do tuesday when my buddy with the MS Zuk comes over... but It's alive!!
__________________
#111 (permalink) |
__________________
#112 (permalink) |
Nice feeling to finally get it running huh? I like the exhaust work!
Where did you get that shorty intake boot? What diameter is the opening on your throttle body?
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#113 (permalink) |
sounds mean. Nice work.
__________________
#114 (permalink) |
The intake " Hat " came off a late model vortec in a junk yard, I found it laying in the grass next to several new chevys, the spectre filter from autozone had 3" 3.5" and 4" adapters that came with it, the 3.5" fit nicely.
The throttle body opening on the mercruiser intake is the same size as the stock GM 4.3 but does not have the restricter on the back of the plate.. right at 3"
__________________
#115 (permalink) |
Here's the screen from the first run at warmup, needs some tuning, but cool!
__________________
#116 (permalink) |
Dad its seriously a beast now, and yes i made a account, cause it ticked me off that i couldnt message u on this thread. U goin 2 ft phantom 2 test it out? U still got some wiring left right? Oh btw my tranny in the mazda is startin 2 slip a little bit I THINK. So if u could check it out wit me nxt time u come down itd b much appreciated! TTYL
#117 (permalink) | |
Quote:
I got the wiring 90% finished today, maybe 30 minutes left . I have to rebuild the drivelines before I do the real test runs.
__________________
#118 (permalink) |
With the 700r4 swap there is a clearance problem with the tranny pan, its necessary to change to a smaller diameter drive shaft and it must be lengthened as well. I also picked up an old dbl cardon from the wrecking yard to convert the rear driveshaft to a CV type setup.
I installed the old stock 4.30 gears in the rear diff in preparation for a good testdrive, should give me 2100 rpm at 70mph. If I like the results I will install the front set.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 Last edited by texcat101; 02-25-2009 at 07:20 PM. |
#119 (permalink) |
I got the driveshafts back from our local shop, He installed the double cardon from the wrecking yard that I rebuilt and shortened the shaft -44"
The front shaft had to be lengthened and a smaller diameter main tube was installed to give clearance for the 700r4 tranny pan. Road test tomorrow!!
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster. 4.3 vortec / 700r4, Megasquirt II, EDIS6 Last edited by texcat101; 03-04-2009 at 06:35 AM. Reason: spelling |
#120 (permalink) |
wow! congrats man. looks great. i really like the looks of how the engine bay came out. very clean, especially the fan shroud. can't wait to see some road/trail pics.
__________________
Wherever, Whenever, However...Tread Lightly! |
#121 (permalink) |
I am not getting the T's in the heater hoses. Why did you set it up that way?
#122 (permalink) | |
Quote:
The mercruiser intake doesn't have the coolant bypass fitting that comes on the automotive vortec, and my water pump has the bypass plumbing so I plumbed a bypass loop to provide a small amount of coolant flow to prevent hot spots during warmup. It appears my heater still gets enough flow to work ok.
__________________
#123 (permalink) | |
Quote:
#124 (permalink) | |
Quote:
I have been tuning on the MSII, it's really waking up! I think I am going to enjoy this setup for a while. It may need 35's or larger??
__________________
| Tags |
| 1994, 43, add, alternator, engine, fuel, header, ii, injection, megasquirt, mercruiser, samurai, swap, toyota, v6, vortec |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| chevy 350 swap into and 89 toyota pickup | yotamaster1988 | 86-95 Trucks & 4Runners | 24 | 05-28-2008 09:16 PM |
| chevy 4.3L swap | runnerboy97 | The Fab Shop | 18 | 06-03-2007 06:55 AM |
| 5.0 Chevy Swap | blainelukens | The Fab Shop | 2 | 05-16-2005 05:16 PM |
| chevy 4.3 swap.. | playboy | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 01-05-2004 08:01 PM |
| Chevy Swap! | descendents | Offroad Tech | 12 | 06-20-2003 04:32 PM |
