The Swap is On! Toyota,Mercruiser and Chevy? - Page 4 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-21-2008, 03:42 PM   #76 (permalink)
texcat101's Avatar
EDIS system
I soldered up the EDIS setup and fabbed a galvanized bracket today, looks
like a stock plug wire set should do the job, will likely buy the V8 set just to have a couple of extra length options.
It looks like the B&M Unimatic shifter is the answer to my shifter problem. It has a very small base (note the template I printed from the online installation instructions) that will easily fit in the space I have, it comes with all the brackets, cable, boot etc..
I think the stock double shifter boots common in the first gens will work with a little trimming of the plastic shifter cover. Looks like another trip to the salvage yard....
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster.
4.3 vortec / 700r4, Megasquirt II, EDIS6
texcat101 is offline
Old 12-21-2008, 05:35 PM   #77 (permalink)
texcat101's Avatar
BTW, for anyone planning a swap of any kind.
The one thing I have learned to date is...
If there is an option to get a complete donor vehicle - do so!
I have spent way too much time looking for bolts, brackets, lines etc... I found an engine from one salvage yard, then a tranny from another place, now I need coolant lines, shroud, alternator, trans inspection cover....
__________________
Old 12-31-2008, 11:35 AM   #78 (permalink)
texcat101's Avatar
B&M shifter
I got the basic B&M shifter I ordered and have built the mounting plate from some 1/8" galvanized plate I had laying around the shop.
Simple but it should do the job.
Will have to modify the plastic cover to accomodate the full range of the shifters movement, when in park there is about 3" from the shifter to the dash.
There was a boot that came with the shifter that I may be able to use but will likely have to fab something from a couple of cheap aftermarket boots.
With the Alternator and a/c compressor set in place.
__________________
Old 01-04-2009, 02:42 PM   #79 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
any updates? I can't wait to see this thing finished.
__________________
Obama is an acronym.
OBAMA = One Big Ass Mistake, America
Hayes is offline
Old 01-06-2009, 03:56 PM   #80 (permalink)
texcat101's Avatar
Quote:
Sorry Hayes, I am working on the accellerator and TV linkage and some other little stuff that is very time consuming, I did order a new chevy swap radiator from extremeradiator.com
__________________
Old 01-06-2009, 05:30 PM   #81 (permalink)
Hayes's Avatar
I'm fining here... Get some pics up.
__________________
Hayes is offline
Old 01-09-2009, 07:56 PM   #82 (permalink)
texcat101's Avatar
The TV/kickdown and accellerator cable bracket
Had to drill and tap for another vacuum port for the brake booster, being a marine intake all it had was the port for the pcv.
__________________
Old 01-09-2009, 08:12 PM   #83 (permalink)
Hayes's Avatar
nice work!
I am giving a lot of consideration to the MS, seeing your quest for power has me hungry. I'm going to look at the low boost LCE supercharger, with MS tuning... Hmmmm, :drool
__________________
Hayes is offline
Old 01-10-2009, 12:25 PM   #84 (permalink)
texcat101's Avatar
[quote=Hayes; I'm going to look at the low boost LCE supercharger, with MS tuning... Hmmmm, :drool[/QUOTE]
http://www.toyotacatalog.net/M1WebGe...F-E6DF0C03E232
Wow! that supercharger is sweeeeet! but thats alot of $$, maybe one off craigslist or ebay... or second mortgage on the house.. forget the kids tuition.. or just forget the kids..
__________________
Old 01-10-2009, 01:41 PM   #85 (permalink)
ocdropzone's Avatar
Very Cool, first time I saw your thread. I think a 4.3 may find it's way into my '8` sometime.
Have your tried putting the truck in to 4WD/low range yet?
Looks to me like you are gonna need to make a larger hole and maybe dog leg the TC lever..With the body lift and flex of the TC it is more than likely gonna knock itself out of 4WD....
__________________
~Robb
'81 Trekker The B4Runner Build
TREKKER Forum
Mini FAQ/Misc Ideas Thread
**TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES
LINK TO ONLINE FACTORY SERVICE MANUALS
Drive a real 1st Gen
Wheel Responsibly, Don't Screw It Up for Others
ocdropzone is offline
Old 01-10-2009, 06:30 PM   #86 (permalink)
texcat101's Avatar
Thanks ocdropzone, I have about a 1/2" of clearance in 4 low, I will leave the boot off until I can road test/trail test it.
Yet another reason why this forum is awesome is help like that, btw I have seen many of your posts/ threads and your 81 Trekker is way cool, That was a heck of a find!
__________________
Old 01-14-2009, 07:52 PM   #87 (permalink)
texcat101's Avatar
Well just got the radiator today but my schedule is shot for the next 2 weeks. Will try to get some work done and post up the progress before Feb 1st.
The "chevy swap" radiator from extremeradiator.com looks like the stock 3 core with the inlet and outlet locations swapped side to side.
Only problem I see is they used 1 1/4" inlet & outlet and the 4.3 lower hose is 1 3/4" at the water pump so I have to find a short flexible radiator hose with 1 3/4 & 1 1/4" ends.... It really would have been much easier and better for swap purposes for them to put the correct size outlets in.
The radiator is several lbs lighter which suggests it has more aluminum, perhaps it will perform better.
__________________
Old 01-14-2009, 10:21 PM   #88 (permalink)
Hayes's Avatar
pics? Bummer about being booked up for 2 weeks...
__________________
Hayes is offline
Old 01-25-2009, 06:03 PM   #89 (permalink)
texcat101's Avatar
It's been a real drag!
__________________
Old 01-25-2009, 08:22 PM   #90 (permalink)
Hayes's Avatar
Quote:
I'll take being tied up for two weeks...
__________________
Hayes is offline
Old 01-27-2009, 07:59 PM   #91 (permalink)
texcat101's Avatar
Okay, the ice storm blows out of here tomorrow and its back to work. I need some ideas on where to run the exhaust. This setup requires that I install the wideband o2 sensor before I can start the engine
__________________
Old 01-27-2009, 09:51 PM   #92 (permalink)
Hayes's Avatar
ice storm in Texas? What's it been there, like 45 degrees?
It's been between 0-25 the last few days... It's friggin' cold. I worked on my truck and had to take breaks to warm my hands with the space heater...
__________________
Hayes is offline
Old 01-28-2009, 06:36 PM   #93 (permalink)
texcat101's Avatar
Okay Hayes, I just got back from the Caribbean and low teens with 1/2" of ice on everything is plenty cold enough to keep this wuss indoors for a couple of days.
It thawed this afternoon and forecast for 50's tomorrow, yeehaw!
BTW, saw your picture on the other post, shaved head and a cold beer...
probably why your hands keep freezin up, lol !!
__________________
Old 01-28-2009, 08:35 PM   #94 (permalink)
Hayes's Avatar
, trust me, I know that feeling.
that's sounds nice...
BTW, saw your picture on the other post, shaved head and a cold beer...probably why your hands keep freezin up, lol !!
Ha, ha. The shaved head has to stay... I look goofy with hair.
Welcome back, now get some pictures up, I'm sick with anticipation.
__________________
Hayes is offline
Old 01-28-2009, 10:59 PM   #95 (permalink)
How did you connect the A/C wires?
43runner is offline
Old 01-29-2009, 02:21 PM   #96 (permalink)
texcat101's Avatar
Quote:
To be determined, but I think I should be able to use the old circuit pretty much as is.
Do you know of a problem I might encounter?
__________________
Old 01-29-2009, 02:45 PM   #97 (permalink)
No, I'm just trying to figure out which wire i'm supposed to connect to the GM A/C compressor. I know that one of the wires from the compressor connects to the ground, but I don't know which color toyota wire connects to the compressor.
43runner is offline
Old 01-29-2009, 03:12 PM   #98 (permalink)
texcat101's Avatar
It will be the one that carries a positive 12v when the switch is engaged so a tester will show you.
I have to chase it down also so I can't help with the color, sorry. When I get to the shop tomorrow I can look at my old harness and let you know.
__________________
Old 02-01-2009, 07:40 AM   #99 (permalink)
texcat101's Avatar
update
The shifter cable is not supposed to be exposed to high heat so I chose to run it behind the heat shield and that should keep it tucked out of the way of possible snags.
I used 5/16 brake tubing for the coolant lines. A $3 tubing bender from harbor freight was all I needed.
More posts coming.
__________________
Old 02-04-2009, 06:14 PM   #100 (permalink)
texcat101's Avatar
Had to run 3 hrs east to pickup a po up camper my wife found on craigslist so I burned some time with that and some other work related things but I finally got in the shop this afternoon for a few hours...
I cut up an old chevy shroud to fit the width then built some brackets to mount it. This is after alot of test fitting for clearance... I still have to seal it up and paint it to make it look better.
__________________
Tags
1994, 43, add, alternator, engine, fuel, header, ii, injection, megasquirt, mercruiser, samurai, swap, toyota, v6, vortec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
chevy 350 swap into and 89 toyota pickup yotamaster1988 86-95 Trucks & 4Runners 24 05-28-2008 09:16 PM
chevy 4.3L swap runnerboy97 The Fab Shop 18 06-03-2007 06:55 AM
5.0 Chevy Swap blainelukens The Fab Shop 2 05-16-2005 05:16 PM
chevy 4.3 swap.. playboy 95.5-2004 Tacomas & 96-2002 4Runners 4 01-05-2004 08:01 PM
Chevy Swap! descendents Offroad Tech 12 06-20-2003 04:32 PM
2009 InternetBrands, Inc.
