The Swap is On! Toyota,Mercruiser and Chevy? - Page 3 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-05-2008, 03:46 PM   #51 (permalink)
texcat101's Avatar
Santa came early
You never know what your going to get when you order a swap kit for the first time, but I have to say this is quality stuff.
I test fit it this afternoon.
Advance Adapters kits rock!
And the engine mounts are beefy too.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster.
4.3 vortec / 700r4, Megasquirt II, EDIS6
texcat101 is offline
Old 12-05-2008, 06:01 PM   #52 (permalink)
Hayes's Avatar
Send a message via AIM to Hayes
are you using the toyota t-case?
__________________
Obama is an acronym.
OBAMA = One Big Ass Mistake, America
Hayes is offline
Old 12-05-2008, 08:32 PM   #53 (permalink)
texcat101's Avatar
Yes I am using a 21 spline gear drive Tcase with the forward shifter, the adapter will accomodate either forward or top shift.
I will post up more detailed pics of the parts and thier relation in the coming days.
__________________
Old 12-05-2008, 08:46 PM   #54 (permalink)
Hayes's Avatar
looks good, you are making me want to do this swap... Too bad I just put in a new 22re.
__________________
Hayes is offline
Old 12-06-2008, 07:30 AM   #55 (permalink)
A little info when I was doing mine:
I had to remove the snap ring that holds the bearing in place on the front of the transfercase. The snap ring prevents the adapter from seating fully against the transfercase. I did not see anything in the instructions about that. The adapter prevents the bearing from moving so a snap ring is not needed.
This looks little different than mine, but it is the lower one in this picture
akarocket is offline
Old 12-06-2008, 04:54 PM   #56 (permalink)
texcat101's Avatar
Thank's Rocket I will check that tomorrow.
I installed the 2" 4crawler body lift with new neoprene bushings today and removed my old engine mounts from the frame and ground the welds.
I should make some progress in the next few days.
I love the way the body lift makes the 4runner look.. more aggressive.
__________________
Old 12-09-2008, 05:00 PM   #57 (permalink)
texcat101's Avatar
While test fitting the 4.3 with headers and mounts attached I found that it required moving my fuel line and slightly bending the brake lines on the passenger side of the engine bay to position them directly above and outside of the frame.
The headers, mounts and new starter look good. This part of the swap goes way too slow with all of the test fitting... but ya gotta get it right.
__________________
Old 12-09-2008, 05:13 PM   #58 (permalink)
texcat101's Avatar
Headers on the driver side, note the upward bends to take the runners away from the steering and the tight taper that it takes to get the collector inside the frame. This swap needs custom headers!
__________________
Old 12-11-2008, 07:30 PM   #59 (permalink)
texcat101's Avatar
engine mount positions
When positioning the 4.3 engine with the Advance Adapters mounts on the 1985 4runner, 20 1/4 " to the center of the mount from the front frame crossmember worked best for me, the mount is close to flush with the bottom of the frame.
Working on the theory that lower and farther back is better this is as far back as I was comfortable with. This position combined with the AA adapter and a 700r4 and forward shift gear drive T'case nets a 2 3/4" longer tranny relative to the crossmember. I am fabing a plate to weld to the crossmember to accomodate the transfer case mount.
Plenty of clearance in front even with the stock fan and radiator, should be more than enough for the aftermarket ones on the way!
__________________
Old 12-12-2008, 06:11 AM   #60 (permalink)
idayota's Avatar
nice work man!
__________________
Wherever, Whenever, However...Tread Lightly!
idayota is offline
Old 12-13-2008, 07:26 PM   #61 (permalink)
texcat101's Avatar
While installing the new output shaft in the 700r4 I noticed the "rebuilt" transmission I purchased had some questionable parts in it.
All the frictions and hard parts looked new but the rebuilder had not upgraded the pump and had used the old stock band.
I chose to install a 10 vane pump and a new raybestos wider band.
I reassembled it today and will try to install the tranny and t'case tomorrow.
Then its just the megasquirt, fuel supply, shifters, exhaust.........
__________________
Old 12-13-2008, 07:44 PM   #62 (permalink)
Hayes's Avatar
Are you worried about the gear choice and birfields and all that with the new found power?
__________________
Hayes is offline
Old 12-13-2008, 08:02 PM   #63 (permalink)
texcat101's Avatar
Quote:
I have the stock 4.30's that should give me 2200 rpm's at 70 miles per hour with the 33's and a final drive of .70/1
It's the birf's that worry me.
Maybe they will be ok with the clutch type posi up front, but I don't dog it too bad while on the trail.
__________________
Old 12-13-2008, 08:04 PM   #64 (permalink)
Hayes's Avatar
See, they would be my major concern while off road too. One tip a buddy of mine gave me was to adjust the steering stops (so you can't turn as tight). While you lose turning radius, he's never broken a birf and he is hard on his rig...
__________________
Hayes is offline
Old 12-13-2008, 08:08 PM   #65 (permalink)
bigt's Avatar
longfeilds are in your future but its gonna be one heck of a yoter
__________________
1991 HILUX SURF SSR-X turbo diesel right hand drive toyota imported in 2005 from japan,
130,000 km 31 bfg a/t auto
current build
1987 LWB suzuki samurai. turning 2 into one.. yota axles welded front to back, yota springs , ifs steering box,, this bad boy will not only eat jeeps but toyotas aswell \m/
bigt is offline
Old 12-13-2008, 08:13 PM   #66 (permalink)
texcat101's Avatar
Makes sense, then theres always aftermarket birf's - maybe next year!
__________________
Old 12-13-2008, 08:23 PM   #67 (permalink)
texcat101's Avatar
Quote:
Yea I guess the thing to do is go try to break something
__________________
Old 12-14-2008, 08:12 PM   #68 (permalink)
texcat101's Avatar
update
Got the tranny and t'case installed today as well as the new front shackles. I will try to get some new pics of the 4runner with the 2" body lift and the new shackles, the stance looks awesome!
__________________
Old 12-15-2008, 11:19 AM   #69 (permalink)
texcat101's Avatar
2" body lift and 1 1/2" longer shackles
The goal was to swap in the V6 for more power as I researched it my only apprehension was the required (or at least strongly suggested) 2" body lift.
I wanted to keep it low for best CG on the trails.
During my trip to Colorado last summer, I found I needed the longer shackles as my spring ends were hitting the frame under extreme flex. 1 1/2" longer would give me 3/4" of lift as well.
This is what it looks like now with the 4crawler 2" body lift and the longer shackles installed.
I like it!
__________________
Old 12-15-2008, 06:25 PM   #70 (permalink)
Hayes's Avatar
time for 35s? looks good.
__________________
Hayes is offline
Old 12-15-2008, 06:47 PM   #71 (permalink)
texcat101's Avatar
Longfields and 35's..... A man has to have his priorities straight!
__________________
Old 12-15-2008, 07:03 PM   #72 (permalink)
Hayes's Avatar
Quote:
ha ha, good to know!
__________________
Hayes is offline
Old 12-16-2008, 12:32 PM   #73 (permalink)
I like it!
Is that with the weight of the 4.3?
Old 12-16-2008, 03:22 PM   #74 (permalink)
texcat101's Avatar
Quote:
Yes, Its got the engine and tranny installed, everything but the small stuff like the radiator, belts, fluids etc..
__________________
Old 12-19-2008, 08:16 PM   #75 (permalink)
texcat101's Avatar
update on swap
After installing the transfer case I found the shifter in its most forward position leaves very little room for the floor mount shifter. I was going to use the B&M Megashifter because it has the 4spd cable shift capabilities I need for the 700r4.
Not sure if I will have enough room now. I searched everywhere for the shifter base size...
Gonna have to do some more research on this one
Fabbed a plate to move the T'case mount back 2 3/4"
Installed the open IAT sensor in the intake just before the throttle plate. This should provide very accurate readings for the Megasquirt
The manufacturer says you can mount the MS relay box in the open but I had this box from the donor vehicle... so why not
__________________
Tags
1994, 43, add, alternator, engine, fuel, header, ii, injection, megasquirt, mercruiser, samurai, swap, toyota, v6, vortec
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
chevy 350 swap into and 89 toyota pickup yotamaster1988 86-95 Trucks & 4Runners 24 05-28-2008 09:16 PM
chevy 4.3L swap runnerboy97 The Fab Shop 18 06-03-2007 06:55 AM
5.0 Chevy Swap blainelukens The Fab Shop 2 05-16-2005 05:16 PM
chevy 4.3 swap.. playboy 95.5-2004 Tacomas & 96-2002 4Runners 4 01-05-2004 08:01 PM
Chevy Swap! descendents Offroad Tech 12 06-20-2003 04:32 PM
2009 InternetBrands, Inc.
