YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-16-2008, 04:28 PM   #1 (permalink)
sbf or sbc????
im deciding whether i should go for a ford 302 or chevy 350 for my 87 4runner that has a 22re. i would like to keep my stock drivetrain, if at all possible. i just use the truck for everyday driving, and the 4wheel when the snows too deep or if a friend is stuck, and im not one for stomping on the throttle from a dead stop.
mungo06 is offline
Sponsored Links
To remove this ad, register today!
Old 08-16-2008, 04:55 PM   #2 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Keeping the IFS and swapping in a V8 will be difficult, but can be done. You will want to find the shortest oil pan possible.
Ford will be much easier to fit and give you more room to mount a radiator due to the front mounted distributor.
Chev may be a little cheaper for parts
Use a ford or chev transmission, the stock 4cy wont last.
Gas mileage will suck unless you go with a mild version and EFI.
Adam F is offline
Old 08-16-2008, 05:16 PM   #3 (permalink)
ok. i was planning on using just a stock motor with no add ons, and where would i go to find a 5-speed and everything else needed for the swap?? and as for the mileage, im not too worried about it.
mungo06 is offline
Old 08-17-2008, 11:28 AM   #4 (permalink)
Adam F's Avatar
Unless you have friends with parts, then a junkyard is your best bet. Do some research on the 'net for manual transmission options, wether it be Ford or Chevy. Popular trannys are SM465, NV4500, T-18.
Here's a good guide of many manual trannys
http://www.motivegear.com/tech_info/...nny_guide.html
And here is a lot of good engine and trans info
http://www.novak-adapt.com/knowledge...ge_gateway.htm
Adam F is offline
Old 08-17-2008, 12:52 PM   #5 (permalink)
AxleIke's Avatar
I'll plug for the 350 simply because it is cheap, parts are plentiful, and LOTS of people have done it, so there is a lot of info to help you when you run into snags.
Plus, its just a burly motor.
__________________
IFS SAS
My mods aren't bling enough for the signature line.
-All Terrains are for when you know how to drive.
AxleIke is offline
Old 08-17-2008, 03:19 PM   #6 (permalink)
my buddy has a 350 he'll sell me, the only thing i need to really find is a transmission, t-case, and everything else needed, and how hard would it be exactly to do a 350 swap???
mungo06 is offline
Old 08-17-2008, 03:20 PM   #7 (permalink)
and thanks for help and advice so far
mungo06 is offline
Old 08-17-2008, 05:30 PM   #8 (permalink)
Adam F's Avatar
How much money do you have?
Adam F is offline
Old 08-17-2008, 06:18 PM   #9 (permalink)
at the moment nothing.... im awaiting to hear from ,im hoping, my new job by tomorrow or later this week. why do you ask??
mungo06 is offline
Old 08-18-2008, 08:34 PM   #10 (permalink)
Adam F's Avatar
Because....its expensive. I'm assuming you cant fab, so you'll have to buy all your motor mounts and t-case mounts. Headers, exhaust work, radiators, fans, drive shafts, and the list goes on. It is NOT cheap. There are SO many little things that you might not think about that will add up. Trust me, I'm in the middle of a 350 swap myself.
And what about tools? Do you have air tools? Do you have an engine hoist? Do you have an engine stand? Transmission jack? You'll NEED all that to get the job done.
And you know the old saying, "if you have to ask, you probably wont/cant/shouldnt"
Not trying to burst your bubble, just look at it realisticly. Its not a job your going to get done over the weekend. It will take LOTS of time and LOTS of money.
Adam F is offline
Old 08-18-2008, 08:43 PM   #11 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
i was thinkin bout a SBC swap for mine,but decided against it, since i bought my truck cuz its a toyota. once you drop a chevy in it, its a chevy in disguise. plus it would handle like a diff truck, i personally like the way mine handles. now im not saying im against it, id love to have one, but not in my truck. maybe a 4runner purchased as a project/crawler/prerunner. trust me, i used to have a chevy with a 350, and they are VERY thirsty, you do NOT want one as a daily driver. ...unless someone is paying for your gas. just ask yourself if its really worth it.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 08-18-2008, 09:14 PM   #12 (permalink)
the tools i have, i have some experience in modifying and im well aware about time, i have a 1960 chrysler that needs brake work, i have a hoist stand, all the stuff neede todo the work, and that chrysler was my daily driver my senior year of highschool and that has a 383 and that was a thirsty motor, and before that i drove a 74 chevelle with a 350 so i know how thirsty they can be, so i ended up driving a 1985 ford f250 with a straight six and a 4 speed, and after that i bought my first yota, a 92 pickup, two wheel drive, 22re 5spd manual steering, nothing fancy, than i got rearended just this january, the truck was totalled and but the motor was still good so i pulled it and the trans, so i looked for another toyota with a bad motor, i found it for 300 bucks, 87 4runner with a custom lift, it was chillin in a corn field, it had a rod knock, so i replaced the motor and ran fine, than a couple months later it started missing on cylinder 2, i replaced the injectors, didnt work, i left the upper intake off for a week, put it back together it ran fine, two days later i was back to where i was, no one has been able to help me out so i decided to do the swap for a carbuerated 350
mungo06 is offline
Old 08-22-2008, 09:13 PM   #13 (permalink)
phildelfino's Avatar
Send a message via Yahoo to phildelfino
Good luck, but did you ever think about a 4.3L chevy swap?
You can keep all the other toy stuff in the drive train.
Phil
__________________
1988 4 Runner w/225,XXX miles, 3.slow V6. A/T. 4.10s?-(G292 code) and power everything else that still works, except someone broke off my electric antenna. 1.25" BL. Used Marlin Crawler Rear Bumper, 33 x 12.50 x 15 on Steel Chromies w 3.5" BS. Has new shocks, leafs.
Soon; Trail Gear Sliders, ZUK brackets & coils, rear shock brackets & flip kit,
Wish List; Rear lockrite, 529's, sliders (got them for $100.oo, new in box), 5 speed swap
http://www.cardomain.com/ride/3171939
phildelfino is offline
Old 08-23-2008, 08:51 PM   #14 (permalink)
really???? im not much of a chevy fan so i dont know much about the 4.3.. if i did go with that option, what exactly would i need??? besides the motor...
mungo06 is offline
Old 08-23-2008, 08:53 PM   #15 (permalink)
TOYOTA 1's Avatar
id go with a chevy motor.
__________________
91 Toyota stdrd cab short bed 22re 5spd. sas'ed, Yukon 5:29's. 3.5" tuff country e-z ride springs in the front. 5" allpro long travels in the rear. pro comp es 9000 shocks, 12" tg long spline front d shaft. k&n, 35x10.50x15 boggers. cobra cb/ashtray mod, 3' fire stick. etc.
2000 Toyota Tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flow master, etc.
2001 Toyota Camry, the girlfriends,
www.22re.com
TOYOTA 1 is offline
Old 08-23-2008, 10:22 PM   #16 (permalink)
ok, ok... ill go with the chevy... now all i need is to know what excatly ill need for it to work out. and where ill be able to locate some of the items, or whatever
mungo06 is offline
Old 08-24-2008, 10:07 AM   #17 (permalink)
Adam F's Avatar
You have to decide if you want the chevy trans and tcase or toyota trans and tcase or chevy trans and toyota tcase. Then you'll need the adapters if you keep some of the yota stuff. Toy 4cy wont hold up, you'll need a V6 trans.
then you'll need a bigger radiator, motor mounts, tcase crossmember, drive shaft work, probably a body lift
most parts can be bought from http://www.advanceadapters.com/
Adam F is offline
Old 08-27-2008, 02:24 PM   #18 (permalink)
all i need is a little advice on what is the better option so i can run a carberated motor instead of fuel injection cuz of some issues im having at the moment, and all im looking for in a motor is for it to start up everyday and be a daily driver, and the occasional 4 wheel for the snow, cuz the area i live in is trying to make the town a better place, so they're getting rid of all the fun stuff and mud holes...
mungo06 is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
sbc 350 in 4runner overheating ron2k1 General Vehicle Related Topics (Non Year Related) 15 09-05-2007 05:05 PM
350/v8/sbc swap. Anubiscougar 86-95 Trucks & 4Runners 3 12-16-2006 10:11 PM
built toyota truck sbc cartune777 Vehicles - Trailers (Complete) 2 09-07-2006 07:37 AM
Engine SWAP - SBC yotaman17 86-95 Trucks & 4Runners 9 01-25-2006 07:01 PM
SBC/Yahoo DSL Tacoma Dude Computer Talk 14 07-30-2005 11:43 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
