YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-10-2008, 02:06 PM   #1 (permalink)
Rear mount Radiator ??s
Hey all, I have a SBC in my 85 ext cab. The engine placement is far enough forward that it got into the radiator on it's first trail run. I've picked up a new rad (22" tru cool from speedway) and I'm planning on putting it in the back with a turaus fan. I'm trying to figure out the plumbing now. I figure I'll need an electric aux pump to help things along.
I've read around and have decided to price out both copper and hrew, but I'm wondering what size. I've seen suggestions going from 1" to 2". I'll be running rubber hoses up from the pipes to/from the block and the rad in the back, So I assume I'll be able to compensate for the different hose sizes there.
What diameter should I run the tubes down the frame?
__________________
DD - 02 ext-cab Taco, SAW/AAL lift, Armor a la budbuilt, bentup and badlands, manual hub conversion, 265/75-16 TKO's
Project - 85 ext-cab lawn ornament
mrdoug is offline
Sponsored Links
To remove this ad, register today!
Old 07-10-2008, 02:30 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
go with similar size tubing that the raditor uses in the first place about 1". I think 2" would be overkill. As for tubing I would say copper as it can dissapate heat faster than steel.
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 37x14" Iroks, Rear Leafs, 5.29's , Air locked front, Welded rear, 4.3L, Chevy V6 , 5spd swapped, dual T/C's MC10R10, flatbelly with custom skids, sliders, and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 07-10-2008, 03:05 PM   #3 (permalink)
Thanks fillsrunner4. I would like to go copper, but unless I get a solid pro/con one way or another, the $$ will probably be the deciding factor (1.5" x 10' copper was $72 at home depot). I'm thinking that copper will dissipate heat better like you said, but hrew would be stronger (and cheaper) if I came down on any rocks or such.
I was hoping that I could get away with smaller diameter tubing since the water pump and rad all have 1 5/8" ID hookups and trying to run/secure 3"+ of tubing down the already tight frame rail was going to be challenging to say the least.
__________________
mrdoug is offline
Old 07-10-2008, 03:13 PM   #4 (permalink)
the hrew would be stonger but your gonna want to tuck them away anyway. Could run it through the frame although that can be alot of work to do. Also if you add a small body lift you can put it right ontop the frame. Ive seen that and liked it aside from the body lift.
Just be sure not to take away sizing so dont go smaller than any of the inlets and outlet sizing and youll be good.
What also would be sick but probably out of your price range would be stainless line like brakelines. your not gonna hurt those things thats for sure. I would love to do that to mine although its a bit too much for me. Will see!
One more thing! A real nice fan im using and is similar but bigger than the taurus fan is a lincoln 4.6 V8 fan. 18" blade, fits perfect around my stock Rad, sounds like you changed that though. Ide look into it though its a real nice fan and will cool the piss out of your 350 and its two speed
__________________
Old 07-11-2008, 09:51 AM   #5 (permalink)
Heh, it already has a 3" BL on it that I'm trying to eliminate. With a 4" suspension on top of (or below) that 7" lift is just to much for the rocks I want to play on.
Running the coolant lines thru the frame would be great, but cutting open the frame, bending the pipes and re-welding the frame would be just too much at this point.
I did price out some braided/teflon/bling hoses (found them on earls plumbing) instead of the metal ones, only about 500 bones too much for my taste.
And your right, the stock radiator is long gone. I got this thing after somebody did the conversion (poorly I might add) and let the truck sit for 3 or so years. I bought it knowing that just about everything from the electrical to the suspension had to be redone. I was really hoping that the cooling was going to be easier than it has been but alas, Murphy setup shop in my garage.
__________________
mrdoug is offline
Old 07-11-2008, 11:51 AM   #6 (permalink)
If anything take the body lift down to an inch and use that area to run those lines. should be real easy with a body lift and a perfect area to tuck those lines running toand from the back. Pluis then they are away from the elements
__________________
Old 07-19-2008, 11:46 AM   #7 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Why Hrew? Why not just plain old pipe or tube? Just use a small section of rubber hose in between the motor and the tube and tube and the radiator so it can flex. Just make sure your radiator is mounted higher than the tube.
Adam F is offline
Old 10-07-2008, 06:57 PM   #8 (permalink)
Quote:
Problem with pipe is that it rusts easy same with hrew thats why I reccomend either copper or rubber hose most likely both! Im thinking about going all rubber tube now cause its cheaper but may still use copper bends and a few feet maybe along the frame
__________________
Old 10-16-2008, 07:48 PM   #9 (permalink)
There are some pretty cool food-grade clear flexible tubings sold at various supply stores, variety of sizes, and it seems like pretty tough stuff too, might be worth looking into.
toyscraps is offline
Old 10-16-2008, 10:51 PM   #10 (permalink)
problem with alot of materials is temp! How hot can it get?
__________________
Old 10-21-2008, 04:51 PM   #11 (permalink)
Not sure, and can't remember a manufacturer or product name. I do know there was a pretty good variety of sizes and other specs, some very flexible, some more like just a softer pipe, Most are "ribbed" to be more or less crush proof. Here's a link to one example. Good to 120 C, or about 250 F. May not be the cheapest or most flexible stuff tho.
http://www.greggdistributors.ca/catpdfs/CatX017.pdf
Old 10-21-2008, 08:57 PM   #12 (permalink)
Check out the stuff on the top of the page in the link.
Just one example, no idea on cost, etc, but could be pretty workable I think.
Old 10-22-2008, 09:30 PM   #13 (permalink)
Adam F's Avatar
250F is not enough. Your rig might see temps that high occasionaly, or close to it. You want something that is rated much higher than what you expect to see.
I dont think clear plastic tubing is the way to go.
Adam F is offline
Old 10-22-2008, 10:18 PM   #14 (permalink)
http://www.novaflex.com/productcart/...eam%20Hose.pdf
Some other stuff that could work too.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Anyone mount lights on rear fin before? KTMR1der03 86-95 Trucks & 4Runners 11 04-09-2007 09:50 PM
rear motor mount surfmobile 86-95 Trucks & 4Runners 0 07-29-2006 09:28 AM
Rear Bumper Firestik mount?? kittykat GPS & Communication 13 09-24-2005 06:42 PM
rear shock mount question marlopez 95.5-2004 Tacomas & 96-2002 4Runners 8 08-12-2004 09:31 PM
New Rear shock mount location??? deathrunner The Fab Shop 3 07-12-2004 12:46 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
