help please fwd gm v6 swap questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-22-2008, 12:31 PM   #1 (permalink)
kenbo53's Avatar
i have a 93 v6 5 speed pickup i also have a 93 buick century with a 3.3 v6 ( same 90 block as 3.8 only different stroke length) i understand that these moters have a different belhousing (smaller it appears) than the more common smallblocks 4.3 v6s and rwd 3.8. Ive seen a few post on here on this subject but everyone just sugest the more powerfull and simpler 4.3 swap. But im not looking for the extra wieght of power just better low end torque and gas millage. I can probably figure out the wiring and build the motor mounts but have no were to find a bellhousing adapter or a gm automatic that can be adapted to my transfercase any help and information would be greatly apreciated thanks!
kenbo53 is offline
Old 12-26-2008, 02:22 AM   #2 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
I'm not all that familliar with Buick engines, but cant you hook a turbo 350/400 or a 700R4 to it? If so, then you can use an advance adapters adapter
http://advanceadapters.com/category/...sfer-Case.html
Adam F is offline
Old 12-28-2008, 07:07 PM   #3 (permalink)
oldschool4runner's Avatar
Contact Downey Off Road and ask them the question, or Advanced Adapters. Both of them are very helpful and very knowledgeable. I have a RWD Buick 231, TH350 with AA adapter to Toyota transfer case. I have about $2000.00 into the conversation (motor,trans,adapter,custom radiator, holly truck avenger carb,motor mounts). Check Craig's list for RWD V6's I believe that they would be an easier conversation.
oldschool4runner is offline
Old 12-28-2008, 07:20 PM   #4 (permalink)
scuba's Avatar
Quote:
Originally Posted by oldschool4runner View Post
$2000.00 into the conversation....
conversation.
hmm.......?
bahha
__________________
Screw you guys I'm goin to TTORA
Mods, please be mature and leave my sig alone, thanks.
No, I will not be your friend.
scuba is offline
Old 12-28-2008, 07:51 PM   #5 (permalink)
mouse4x4's Avatar
Get a turbo 350 that is what i used in my oringinal swap with the 225 buick but i lucked out and found a dual bolt pattern housing which is both buick and chevy
__________________
1987 Toyota 4-Runner Custom SAS All built not bought, dual cases, 4.3 chevy, turbo 350 trans, chevy 64 in the rear , chevy 46 inch springs up front, batterys relocated to rear, interior cage, (long fields 30 spline, chromo hud cogs, detroit up front, spool rear, 5.29 yukon) All gone now front 60 rear 14 bolt install goint on right now no more lifting off the skinny pedal for me!!!!, front and rear custom hitch mounts, front stinger, super heavy right foot!!!!!
mouse4x4 is offline
Old 01-06-2009, 12:24 PM   #6 (permalink)
kenbo53's Avatar
thanks for the help guys but im begining to see that its either gona be imposible or cost a lot more money than im willing to spend i think ill just gear my t case down so itll at least go through the woods a little better and just keep beating on my poor 3.0 for now plus i might be geting a cheap 64 buick 430 and th 400 for my 71 gmc so then id have a great runing 350 looking for a home =]
__________________
93 pu v6 5speed rear lockright 31mts
87 xtracab mudtruck welded rear 31x12.5 boggers
80 pu for parts pm me if ur looking for glass or interior parts
71 gmc 3/4 ton
05 gmc canyon
kenbo53 is offline
Tags
2008, 33, 38, adapter, buick, chevy, fwd, gm, identification, length, motors, stroke, swap, tag, toyota, transmission, v6, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2001 Tacoma disable FWD? bf253 95.5-2004 Tacomas & 96-2002 4Runners 4 07-16-2006 09:44 PM
FWD drifting lol payyourtoll Off Topic Talk 2 02-28-2006 08:46 PM
FWD...Whats the point? bob200587 Off Topic Talk 27 12-22-2005 12:03 AM
2009 InternetBrands, Inc.
