| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Another 302/5.0L swap post
__________________
First time Yota Owner - '87 4Runner...let the fun begin. '98 Camaro SS 638rwhp/588rwtq-11psi-pump gas w/meth injection 10.37 @ 137.78, 1.65 60' on 93 octane Webshots 1 Webshots 2 2nd DIY kit |
#2 (permalink) |
5.0 swap
Okay lets see. Your driveline will hold up as long as you don,t warp on it too much. The front ifs is the weak link. I have had my 5.0 in for about 4 years and haven,t even snapped a u joint and I abuse mine, but each vehicle is different.When you do the swap by a good pressure plate meant for your year 5.0. The NWOR kit has a good clutch disc. I also bought the motor mounts. As far as fuel it depends on how stock your motor is. Believe it or not I am running the Toyota 4 cyl. pump in mine and it seems to work fine. Now gauges are a different story. The oil pressure should work ok and the battery voltage also. I found that the stock temp gauge didn't read properly at all. I assume it has something to do with the different levels of resistance built into the sensors and gauge. As far as oil pan clearance and such I had a suspension lift in the truck and I had to do a body lift to be able to clear the bellhousing. I had a 4" ifs lift and a 3" body lift. I kept breaking cv's so I swapped to a solid axle.As a far as driveshafts if you leave the trans in the stock location you wont need to modify them.If I can give any more help let me know.
#3 (permalink) |
Get an adapter for your stock temp gauge sender to work in the ford block.
go to www.advanceadapters.com for parts
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#4 (permalink) | |
Quote:
#5 (permalink) |
Thanks for your help, that's the info I was looking for.
Ok so factory flywheel for the 5.0, my choice in 5.0 pressure plates but of course have to use the NWOR disc so the yota trans input shaft fits...or do I have to use a conversion specific pressure plate too? Have any pics?
__________________
#6 (permalink) |
did you use the ford or toyota SENDER? you have to reuse the toyota.
__________________
#7 (permalink) | |
Quote:
#8 (permalink) |
I am using a centerforce PP and clutch and it grabs quite nicely
__________________
#9 (permalink) |
Hey there,
I am just completing a 5.0 efi swap on my 84 sr5 pickup. Here is a few things I've learned so far 1 use the mustang flywheel but realize that it is smaller then the truck flywheel normally used in the kit. You will have to modify the starter flange my drilling a new hole and moving the starter inboard and in my case grind a little off the nose of the starter to clear the flywheel teeth at the revised angle. 2 headers - I tried to use the stock ford mustang headers and ended up just cutting them all apart and making new ones with the pieces and some new j bends, if your headers are still rust free and solid this works good but allow some time to fab the new headers (it took me 20 + hours) 3 the slave cylinder will be very close to the exhaust on the drivers side especially the line which faces straight forward. I made up a tight 90 fitting by welding two brake line fittings together and also added a tin heat shield to deflect the heat. 4 the emergency brake cable needs to be moved or changed. I went to the wreckers and got one out of a newer model and made it fit. It has the cable running inside the floor pan. even then I had to reshape the floor pan to provide clearance for the drivers side cylinder head. 5 I`ve been told that a stock v6 rad will do the job but I ended up using a sprint car rad from speedway motors as I plan to tow my bike trailer a lot with this truck. I used two pusher fans designed for corolla air conditioned cars. They are an add on to the corolla when the dealer installs air. I used two and mounted them side by side between the grill and rad. Currently I have less then quarter inch of clearance between the rad and water pump pully bolts. I plan to make up some flush mount bolts to help with this but if I was to do it again I would try to find a later model mustang motor with the shorter waterpump and pully setup or convert the engine to this settup. I actually reused the toyota power steering pump by making a plate and mounting it to the Ford bracket and machining the Ford pully to fit. I think I would just use the Ford pump next time....this was a lot of work and hard to get lined up. If you plan to use the stock alternator bracket plan to use a rad with the top hose on the drivers side. This might mean using a 4cyinder turbo rad as I am not sure of the configuration of the v6 rad hoses. If you need more just PM me or see my website funfactorfab.ca ![]() Kevin Last edited by 84foyota; 04-26-2009 at 01:01 PM. |
| Tags |
| 302, 50, 50l, 69, 84, alternator, bracket, brackets, drivers, efi, mustang, side, stock, swap, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 302 swap is about to go down! | jmcbmx | 86-95 Trucks & 4Runners | 86 | 03-31-2009 11:26 PM |
| 22 to 302 Engine swap? | nickormerod | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 02-27-2008 09:58 AM |
| 302 Swap | LittleSilver113 | 86-95 Trucks & 4Runners | 8 | 12-13-2007 12:09 AM |
| 302 swap what is a prefered trans? | jmcbmx | 86-95 Trucks & 4Runners | 18 | 09-30-2007 09:26 PM |
| Another 302 Swap thread | DeepSeaSnake | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 09-08-2005 10:50 AM |
