93' 4runner with 4.3v6 th400 &np208
#26
Looking good, so how much body lift? So have you got the exhaust figured out. Mine works, but it kinda ratty. I took a blazer y pipe and cut it and reversed it so the exhaust goes down the driver side. Looking forward to see what you come up with.
#28
Wireing is very close to being done. Need to install my electric fan yet and do the driveline. The hoses belts are all done up nicely. Need to change oils and filters and run my spark plug wires. Hopefully b firing it up this week!
#29
Well i got it to run but not well. Need to put a new pump in it, just gonna put an inline pump in it. Driveline is made, oil's and filters changed. Just waiting for parts now.
#30
#31
Well it's running pretty good. Got most of the loose ends finished. Having an issue with thedriveline now! I used a ford ranger driveline and it turned out good and i got the front adapter u joint no prob but the ford ranger to toyota 4runner is a no go! Soon as get that figured i should be able to drive it!!!
#37
Yeah i had oil pan clearance issue's but i just dimpled the pan in with a hammer. The 208 is in stock position, i tried to rotate it up but the torision bar was in the way.
Flying91
45
04-11-2024 04:39 PM
BeMiceElf
10-10-2015 09:40 PM
