Domestic Swaps Chevrolet, Ford, ect
400 small block install for 94 4runner
Old 06-15-2012, 05:30 AM
mechanical_mind's Avatar
Im sick of this weak 3.0 and have a nice 400 chevy small block sitting in my shop. My question is what transmission/transfer case configuration do i need for my 94 4Runner 4x4? i was told the existing auto trans would not work because of electronic shift issues when switching to a carb engine. any advice or parts recomendations would be helpful...
Old 06-15-2012, 05:35 AM
wii_tarded's Avatar
switch to a manual, use advance adapters for a bell housing, or use GM 400turbo auto and atlas t-case. Putting in the v8 means you're gonna have to do a lot of fab work anyway.
Old 06-15-2012, 06:00 AM
fab work wouldn't be a problem at all as i own a machine shop so i'm ready for that. just couldn't get a good answer as to what set up i would need. im thinkin on buying a silverado off my father in law that has a blown motor but good running gears. figured i could scavange what i needed off that
Old 06-15-2012, 06:13 AM
i would like to get 10 in wheels on it soon as well. its a factory truck but suprising to me when i found it there was no rust, dents or driveline problems at all. engine was junk so i parked it in my shop. started looking at building it but for the cost i may as well just v8 the thing and be done with it. only gave 800 for it so not a bad deal
Old 06-15-2012, 06:54 AM
wii_tarded's Avatar
Is this a just because project or do you have a purpose behind putting the V8 in?
Old 06-15-2012, 07:28 AM
well im a gear head and i love HP so the 3.0 just doesnt get it with me. i have a DD so it gonna be a project truck. got a cool idea using some left over hydro systems i have. its a really nice truck so i dont want to butcher it up too much. the 400 is tricked out so it looks really good, rock crawler engine i built but never used. 435HP without the supercharger or N.O.S . was using dual carbs but went back to a single 850cfm edelbrock. i know the stock axles would explode so those are gonna be beefed up as well if i use the 400. i thought also of making a adapter plate for the transfer case and bolting the turbo trans to the toyota box but im not sure how much the stock unit will handle before turning into metal shavings and goop. lol
Old 06-15-2012, 09:44 AM
bob200587's Avatar
TH400 transmission, atlas II, dana 60 front, 14 bolt rear
Old 06-15-2012, 10:18 AM
donomite49's Avatar
x2 what bob said ^ that would be one strong runner.if you use a toyota transfer case, a gear drive from a 4 cyl is stronger than your chain drive case but you still have the weak stock stuff.
git r done...pics. build thread.
Old 06-15-2012, 08:37 PM
abecedarian's Avatar
This is a topic more suited for the engine swap forums.
https://www.yotatech.com/forums/f158/
Old 06-18-2012, 01:27 AM
pics coming soon. made a decision over the weekend to build the runner into a gas sucking monster. found a sweet deal on a supercharger, tranny and axles.
bigjstang
08-25-2021 12:41 AM
MMA_Alex
25
04-18-2017 05:07 AM
coryc85
09-09-2015 06:24 AM
coryc85
07-07-2015 04:05 AM
Quick Reply: 400 small block install for 94 4runner
