40 to 50 is my max road speed...help
I have plenty of power,when the trans shifts it chirps tires,I'm just wound out like I'm in 4lo...I tried to search t400 with 5.29,I found drag racers like this setup for 1/8 mile...witch is about the distance I'm in high rpm,3500 to 4000...I seen some time slips with rpms,one was 73mph at 6900,so I think my tire/gear/trans setup is my problem...gona look into 4.11s and repost
Can you borrow a set of 35" or larger tires from someone?
Yeah I'm in the boat with the rest of the guys saying your gearing is to low. Get your hands on some 4.10's (Should be able to source them fairly easily) and you will be laughing all the way to the trail!
So was it your gears being too low? Seriously switch to 4.10s or even 3.73s.
5.29s and small tires combined with a 4k rpm limit and I could see only doing 50....
nvwiggins
13
06-16-2016 03:05 PM
