350 valve tick - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-02-2009, 03:59 PM   #1 (permalink)
Ron's 85's Avatar
350 valve tick
so i recently put a remanned 350 in my runner and the builder says its good to go. i have about 500 miles on it now. Should i do a valve adjustment???
the valve train is a little noisy..
i have hydralic lifters and i thought there was no adjustment necessary.
i hear that it might just be my lo-rise valve covers on the z28 valve springs. is that true?
i'm affraid to crank down on my new valvetrain!!!!
any advice??????
Ron's 85 is offline
Old 04-02-2009, 04:09 PM   #2 (permalink)
okie81's Avatar
Rocker arms might just need adjusting
__________________
2001 Toyota 4Runner SR5 4-Dub
TRD supercharger, Thorley Headers, URD 7th, Toytec Coilovers, OME 890's, baseball card in spokes
okie81 is offline
Old 04-02-2009, 04:54 PM   #3 (permalink)
Ron's 85's Avatar
valve lash adjustment does require cranking on the rocker arm nuts, but i dont think the rocker arms are loose
Ron's 85 is offline
Old 10-15-2009, 12:11 PM   #4 (permalink)
I had the same rocker problem. Take your valve cover. With the rig running do one side at a time with a 5/8 socket turn one at a time loosen one till you hear a tick and tighten till it stops making noise then turn another 1/2 turn do that to all of them and you are done all but the mess if you have a old valve cover cut the top off so the oil all stays in.
cbrwags is offline
Old 11-02-2009, 07:47 PM   #5 (permalink)
Sometimes the new lifters will settle in plus with cam break in a good valve adjust will be needed.
You can do it the way CBR said but I have a cleaner way if y'all would like!
First take all your spark plugs out. You will be cranking the motor by hand and this will make it easier.
Next remove the valve covers and get a 5/8 socket and ratchet.
Place one finger on the intake pushrod of a single cyl. Rotate the crank clockwise(normal rotation) and feel the pushrod and rocker come up (valve open) and the down. When the rocker stops rotate just a few degrees more to make sure its down. Both lobes on this cyl are on the base circle and are ready to adjust. Tighten the nut while rotating the push rod with your fingers. You will feel the pushrod start to drag and get tight. You want just a slight amount of resistance on the pushrod with hydraulic lifters. Adjust both on this cyl and then repeat with the other 7 cyls. This also works for solid lifters with the exception of using a feeler gauge between the rocker and the valve.
I should also mention that if your not using poly locks you should be! They are cheap and easy to use and will stop the rocker from ever coming loose again. Poly lock are just a longer rocker nut with a set screw. If you don't have em'...get em'!
countryboy69 is offline
Tags
350, adjustment, coming, reasons, sbc, spring, tick, ticking, ticks, valve
« gm 3.4 | Tranny? »
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Valve tick? BAMF_CT2004 03+ 4Runner/GX470, & 05+ Tacomas 10 04-09-2009 12:54 AM
water over the hood 'tick tick tick" east_texas_yota 86-95 Trucks & 4Runners 1 03-23-2009 12:16 PM
valve tick help midnightoys General Vehicle Related Topics (Non Year Related) 0 01-04-2007 04:25 PM
Random Valve tick... Gangus2006 95.5-2004 Tacomas & 96-2002 4Runners 2 08-04-2005 05:50 PM
Vacuum Switching Valve Vsv Constantly Switch / Tick When Running? P0441 Please Help! BOSTON4RUNNER Maintenance & Repair Archives 42 06-24-2005 11:54 AM
2009 InternetBrands, Inc.
