350 swap exhaust ? - YotaTech Forums
Go Back   > >
Domestic Swaps Chevrolet, Ford, ect
350 swap exhaust ?
LinkBack Thread Tools Search this Thread
Old 03-16-2011, 12:06 PM   #1
350 swap exhaust ?
Has anyone tried using block hugger headers and they clear the inside rail's of the frame on your toyota swap?
Jfoust is offline   Reply With Quote
Old 03-16-2011, 12:13 PM   #2
Check out my build thread. I used the stock manifolds.
2DoorRunner is offline   Reply With Quote
Old 03-16-2011, 02:43 PM   #3
Quote:
I have tried and i also tried "Ram horn" style manifold but they both hit the frame..
Old 03-16-2011, 02:43 PM   #4
meswoleshane's Avatar
Quote:
Yep. My old ext. cab had a 6" suspension lift and a 3" body to help though.
meswoleshane is offline   Reply With Quote
Old 03-16-2011, 02:59 PM   #5
It's a tight fit but I am still wondering..
Old 03-16-2011, 03:09 PM   #6
Here is pics of the ram horn I bought. and where it hits the frame and don't quite line up on the exhaust ports,
Here is advanced $120 more headers picture
And here is a picture of block hugger 350 headers???? which this is a quick picture i found of them they normally look like the adavanced one with the outer tubes on the outside not inside like these ones in this oicture
So this is actually why i am asking before I purchase a set..
Old 04-07-2011, 02:20 PM   #7
Dras16's Avatar
I used the block hugger headers just like the ones in the second picture. By looking at your pictures i think my engine sits a little higher than yours which gives a little more clearance between the frame and block. But be careful with those headers, mine didnt fit quite right ( i bought mine from ebay) and so i had to pound a dent on the inside of the drivers side header by the collector. Thats probably why AA has the outer tubes on the outside. Check out my albums on my profile for some pics of my exhaust.
Dras16 is offline   Reply With Quote
Old 10-22-2011, 07:00 AM   #8
minizilla's Avatar
Use s10 v8 conversion headers and or northwest Offroad has Toyota to gm specific headers I used the s10 conversion headers and work fine my motor also sits up using the stock Toyota motor mounts
minizilla is offline   Reply With Quote
Old 10-24-2011, 12:08 AM   #9
GVX
look 1955 chevy v8 exhaust manifolds just cut the alternator mount off the drivers side and reverse the left to right. I also have a set of manifolds off a 1999 silverado 4X4 5.7 vortec engine both sides angle to the rear I haven't tried them yet but the look like they might work. They both exit to the rear at an angle. I am hoping they will work they are much more free flowing exhaust.
GVX is offline   Reply With Quote
1982 Toyota Pickup build 82yodahickman Pre 84 Trucks (Build-Up Section) 30 03-18-2016 07:13 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
22re complete exhaust: please advise tj884Rdlx Newbie Tech Section 25 08-28-2015 01:04 PM
Most powerful engine in an 89 pickup rondogracing Engine Swaps 16 08-24-2015 04:02 AM
96 3.4, very high idle no vacuum leaks I can find greenbuggy 3.4 Swaps 4 07-23-2015 12:51 PM
Tags
350, 4runner, 95, block, chevy, conversion, engine, exhaust, headers, hugger, manifolds, s10, swap, toyota, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
