350 Swap Cooling Issue - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-08-2009, 04:17 PM   #1 (permalink)
01mudslinger's Avatar
Question 350 Swap Cooling Issue
My buddy has a 79 yota with 38's and has swapped a 350 in it. he cannot keep it from overheating, currently it has a high flow waterpump and thermostat, a 19x22 aluminum radiator, and 2 10" electric puller fans. It also has a 4 inch cowl hood on it to let the heat out. Does anybody have any ideas that have a V8 swap that could help him out on this one. Thanks.
01mudslinger is offline
Old 02-08-2009, 06:18 PM   #2 (permalink)
rockymountian yota's Avatar
Is that a 4 core radiator or a 2?
rockymountian yota is offline
Old 02-08-2009, 07:01 PM   #3 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
tell him to make sure the thermostat is good, and to make sure its a 4 core radiator and a badass water pump
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back.
1988 Toyota P/U 4x4
22re, 1200 miles on the rebuild
engine builder .268 cam
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 02-08-2009, 07:56 PM   #4 (permalink)
everything sounds good but the radiator, if its not a 4 core it not going to move enough fluid through it to cool off a 350
Old 02-08-2009, 08:02 PM   #5 (permalink)
everything sounds good but the radiator, with a 350 it needs to be a 4 core, or you want be coolin enough fluids to keep that engine happy.
Old 02-09-2009, 01:23 PM   #6 (permalink)
Ill find out about the Radiator, I was looking at the Taurus fan upgrade last nite, reading up on that, what is the CFM on that. would that be a better fan that the 2 10's.
Old 02-10-2009, 01:06 PM   #7 (permalink)
Radiator is 4 core, anybody got any info on the taurus fan, CFM Rating and is it better?
Old 02-11-2009, 03:43 PM   #8 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
i have a SINGLE core aluminum radiator from a camero and a taurus fan running in reverse in front of the radiator and have no cooling issues.
Adam F is offline
Old 02-12-2009, 04:30 PM   #9 (permalink)
thanks man, this may sound stupid, but what do you mean by reversed, fan in the front of the radiator?
Old 02-13-2009, 07:12 AM   #10 (permalink)
Adam F's Avatar
Yep
Adam F is offline
Old 02-13-2009, 07:30 AM   #11 (permalink)
86Toyrunna's Avatar
just for giggles.. have you pressure checked the cooling system?? could be something stupid like a bad radiator cap.. (had that happen in my cuzins old blazer) maybe its got air pocket some where in the system to. also could it be running really lean? creating more heat then in a rich condition? my dads yamaha raptor use to over heat like crazy till jetted the carbs right. these are just some things i might look at.
__________________
current: 1986 4Runner, Rebuilt 22RE with engnbldr HP head, cam'd, battery/intake swap, SASed, 5.29s, detroit rear, 35in MTRs, trussed and armored axles, marlin HD clutch, soon to be dual cased, TG rear bumper, Best mod todate CHROME METAL SR5 DOOR HANDLES, thats whats up
RIP: 1985 Standard Cab SR5 pickup, add-a-leafs and shackels, 33" BFGs, it died a horrible death (50mph roll over)
DD: 2006 Scion Tc w/TRD Supercharge and TRD stainless cat-back exhaust
86Toyrunna is offline
Old 02-13-2009, 09:34 AM   #12 (permalink)
Quote:
Originally Posted by Adam F View Post
Yep
thanks man, to put it on the front did you have to re wire it for the blades to turn the other way or something to make it push the air through? does any taurus from 90 to 95 work, i looked it up on car part and they got 3.0's and 3.8 motors, regular taurus and SHO's. wanna make sure he gets the right one. cool thing was they are only 35 bucks. What else will he need to get it hooked up right?
Old 02-13-2009, 09:49 AM   #13 (permalink)
Also does the taurus fan fit between the motor and radiator also or does it have to be put in the front? Thanks for your help guys.
Old 02-13-2009, 02:10 PM   #14 (permalink)
RevNL's Avatar
What about the hood latch? Does the grill and bumper fit over all that? Are there any problems caused by completely removing the lower core support?
I'm currently working on the cooling for my swap. It is a tight fit, no matter what. Especially without a body lift.
__________________
1993 Toyota Xtra-Cab - Mods In Process: 5.7L TPI V8, 4L60, NP208, Dana 44 F, Ford 9" R, Lift
RevNL is offline
Old 02-14-2009, 07:15 AM   #15 (permalink)
Adam F's Avatar
You want a 3.8L V6 taurus, 90-95. Should have 3 wires, for the two speeds.
That fan is designed to fit BEHIND the radiator like any other fan. I diddnt have room that way.
I just reversed the positive and negative wires so that the fan spun in reverse. It was never designed to work this way, but it does.
Bumper and grill DID NOT fit. I had to notch the bumper (TJM) and completely cut up the grille to "fit".
No hood latch. I use hood pins.
Not sure if all this will cause any problems. Ill find out here shortly when I take it wheeling.
Read up on my swap page
http://staff.4x4wire.com/adamf/88/v8swap.htm
Adam F is offline
Old 02-18-2009, 02:18 PM   #16 (permalink)
im runnig a 350 in mine too with the same size rad and 2 10 inch flex-o-lite fans in front of the rad i works ok till you get into heavy wheeling i have also filled the gaps on the side of the fan to make a semi decent cowling a little cutting on he rad cradle and i was able to fit it in without modifying the grill but im going to put a 9x25 inch rad in there in the spring by moving the windshield washer bottle over a bit to make the clearance for the rad but shes never gone over 200degrees
stovtop is offline
Old 02-18-2009, 02:19 PM   #17 (permalink)
sorry meant 19x25 inch rad
stovtop is offline
Old 02-28-2009, 12:54 PM   #18 (permalink)
RevNL's Avatar
Thought I'd show off my work.
Ignore the cardboard covering the core. That stays until final assembly. Try not to laugh at my welds. Welding sheet metal was touchier than I expected.
I used a Summit Racing Hod Rod series aluminum radiator in 22"x19" size with 2 one inch cores and a 7 plate internal transmission cooler. The fan is the biggest baddest Flex-a-lite pusher that would fit between the side tanks. It blew my hat off when I test fired it.
I sawzalled out the stock mounts and welded in two strips of 1.5" x 3/16 plate steel instead. They give a flat surface on the inside to bolt up the radiator and something beefy on the outside to weld on a new fan support and core support. A 1/2" x 3/16" angle braces the two sides of the lower core support. Another 1/2 angle on top supports the hood latch and is gusseted at both ends. Both pieces are positioned so that the fan will bolt in, rather than use those through-the-core nylon ties that tend to destroy radiators.
The hood latch is solid. I can stand on it and it won't budge.
Everything fits under the hood. There's plenty of room for the radiator cap. The inlet fitting was pointing into the alternator so I had a welding shop move it to the side, like the Advance Adapters radiator. Yes, I probably should have just ordered the Advance Adapters radiator.
With the cardboard removed, there'll be about 2" between the waterpump pulley (a long pump!) and the radiator. I wanted a belt fan, but without a body lift, there' s just no way to sink the radiator into the grill without cutting out the lower frame rail. This is just the best I could get.
So there it is. Hope it will keep cool.
__________________
RevNL is offline
Old 04-23-2009, 03:23 PM   #19 (permalink)
ChevyTacoma's Avatar
Send a message via AIM to ChevyTacoma
Im running the Vortec 350 in my 87 yota and running the stock radiator with 1 tauras fan pushing and my truck never over heats. Runs about 180 all day long in the trails... I think its the Factory radiator. i got the truck with no motor and that radiator was in there.
350-swap-cooling-issue-toyota-350.jpg   350-swap-cooling-issue-my-toyota-006.jpg
__________________
HillBilly Deluxe
87 Toyota pickup
Vortec 350-stock. headers, EdleBrock 750,small cam, Accel Ign.
1 ton axles all around
35's--- Needing 38's or 40's
ChevyTacoma is offline
Old 04-23-2009, 07:44 PM   #20 (permalink)
jpmountainboy's Avatar
hey man, i couldnt stop my new 3.0 engine from overheating after the install, and had air trapped in the lines after thinking it was a bunch of other crap. I tried all tricks, but in the end i just ripped the middle of my thermo out as to let the water pass freely for a while and that worked like a champ. sometimes there can be air way up there that you cant get out, but with the thermo out you can really flush the system through while filling it little at a time with the cap off.
its an easy thing to at least try if you have an old thermo around to gut. I ripped out the middle to leave the rest to make a good seal.
im not saying that this is your problem but thought it might be worth a shot before spending a bunch of time and cash.
good luck.
__________________
94 pickup trail rig/3.0, & 96 tacoma stock.
jpmountainboy is offline
Tags
19x22, 350, aluminum, cfm, cooling, core, fan, issues, problems, radiator, sho, single, swap, taurus, toyota, tpi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
What headers work with a 350 engine w turbo 350 swap in an 85 toy 4x4 HELP! sethwilliamd Engine Swaps 10 09-25-2009 02:01 AM
Cooling system gurus! Overcooling issue. Kiff 86-95 Trucks & 4Runners 13 09-22-2007 07:23 PM
Weird cooling issue w/ 22re boostaddctn 86-95 Trucks & 4Runners 8 09-25-2006 01:01 PM
What part is this?? Cooling issue. Funk_Runner 95.5-2004 Tacomas & 96-2002 4Runners 13 11-08-2005 11:11 AM
Weird cooling issue. 88RunnerV65Spd 95.5-2004 Tacomas & 96-2002 4Runners 3 11-19-2004 05:05 PM
2009 InternetBrands, Inc.
