2002 4.3 into 88 4runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > Domestic Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-16-2008, 06:47 AM   #1 (permalink)
I am getting started with my 4.3 install. I am slowly gathering parts. The engine is a 2002 4.3 Vortec with 30000 miles. I am using a Howell engine harness and computer. Going to mate that to a TH350 and then use a Advance Adapters to the Toyota case.
I got the TH350 all done. Rebuilt with a shift kit and a 2000 RPM stall converter Going to use a Lokar shifter:
Engine looks good. Now I need to start stripping off what I won't use
Cleaned up:
Waiting for my stuff from Advance Adapters to show up. Still need to figure out how I am going to do the accessories on the front. I think I might switch to a short water pump and run a drive system similar to a street rod. Otherwise, I might just get some brackets out of the salvage yard. More updates to come.
akarocket is offline
Old 09-17-2008, 11:32 PM   #2 (permalink)
fillsrunner4's Avatar
Send a message via AIM to fillsrunner4
Looks great That motors gonna be nice in there.
Ya I think your going to have to get another water pump in there. I dont think it will fit. You might want to look into an electric fan for the front also it will free up some space. I like the taurus fans. Im using the bigger Mark VIII but the taurus fan is small and fits perfect to the toyota radiator if your gonna use that. Theyre cheap and easy to wire not to mention 2 speed and can cool to 5000 CFM
Gives you some idea of what your gonna have for space up front. Not much. I even put my radiator in the back but thats for more than just this reason
Good luck hope to see plenty of pics
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more.
Might as well start reading this if ya want know more
Fillsrunner4 3.4crawler Build Thread
Fillsrunner4.3 crawler (Part Two) build thread
fillsrunner4 is offline
Old 09-18-2008, 07:13 PM   #3 (permalink)
Making a little bit of progress. Found accessory brackets from a 2000 Astro Van.
Before:
After:
Notice anything missing?
I think the stock pump will fit. I guess I will find out.
Old 09-19-2008, 08:21 PM   #4 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
No A/C?
Nice project. The 4.3 vortec is a peppy little motor. Pushes a little Astro van around quite well, should be nice in a Toyota.
Adam F is offline
Old 09-20-2008, 12:29 PM   #5 (permalink)
Quote:
Originally Posted by Adam F View Post
No A/C?
I cut the idler bracket off the alternator side and the A/C off the other side. Need to do that because I am changing the belt routing around.
Old 10-02-2008, 12:49 AM   #6 (permalink)
No A/C?
Removing the AC pump makes a nice location for the supercharger on this motor
__________________
Old 10-05-2008, 06:20 AM   #7 (permalink)
Making a little progress:
Old 10-05-2008, 07:42 AM   #8 (permalink)
texcat101's Avatar
Awesome project I am a little behind you in my 4.3 swap, so I will be watching.
I am looking for a 700r4 non electronic tranny, wish I could find used advanced adapters and output shaft - but not likely.
NWOR has some cool engine mounts and headers, Downey also has some good stuff.
__________________
85 4runner, 3" spring lift, 4Crawler 2" body lift, Precision Gear 5.29's w/power brute posi frt & rear, M/T Baja MTZ 33x12.5x15, Warn M8000 winch, Optima redtop, Marlin Crawler Front, Rear Bumpers and Sliders, Allpro crossover steering & U bolt flip, LC rotors, '94 calipers and booster.
4.3 vortec / 700r4, Megasquirt II, EDIS6
texcat101 is offline
Old 10-05-2008, 01:05 PM   #9 (permalink)
I purchased the mounts, headers, and TH350 adapter from Advanced Adapters. Find a vendor that deals with them and they can get you a hefty discount compared to their website. I went through www.rockbuggysupply.com
Excellent service!
Old 10-05-2008, 02:41 PM   #10 (permalink)
texcat101's Avatar
Quote:
Excellent service!
Thanks rocket! I will check it out. Those items are pricey!
__________________
Old 10-14-2008, 04:00 PM   #11 (permalink)
Motor is ready to drop in. I have got everything bolted on and ready to go. I was able to remove the oil cooler adapter from the block and screw the filter straight on.
I thought the front accessories turned out pretty well :mrgreen:
Found a 150 amp alternator from a Yukon Denali. I disassembled it and had TMCO powdercoat the case. BLING BLING!
Power steering pump is a Saginaw from a 00 Chevy truck.
March underdrive pulleys.
Old 10-14-2008, 04:46 PM   #12 (permalink)
toy power's Avatar
very cool. i couldnt live without air conditioning though
toy power is offline
Old 10-14-2008, 07:39 PM   #13 (permalink)
Quote:
My truck lives with no doors or top from early spring to fall. I am sure there are times I will miss it.
Old 10-14-2008, 07:49 PM   #14 (permalink)
texcat101's Avatar
Awesome 4.3! like I said I am a little behind your timeline. Keep up the good work.
__________________
Old 10-19-2008, 09:04 AM   #15 (permalink)
Well yesterday was productive. Started at the beginning of the OU-Kansas game and finished just as Texas was putting the final butt kicking on Misery .
Had to severely tilt the engine to get it in there:
Almost looks like it belongs.
Plenty of room for a radiator and a fan.
Up tight against the firewall:
View from under:
Make sure and remove the bracket on the rear of the head for the 4.3 and the bracket that holds the clutch slave line. They will interfere with each other:
Old 10-19-2008, 11:07 AM   #16 (permalink)
Adam F's Avatar
That 4.3 fits VERY nicely in there.
Keep us updated. Id like to know how well it performs. What kind of HP/TQ numbers are you expecting?
Adam F is offline
Old 10-19-2008, 11:43 AM   #17 (permalink)
Very clean
Ide recomend getting some spark plug heat sheild wrap to go over them near the headers. I say this cause my friends gone through a few wires just cause the headers get so hot and the plugs run very close to them
Very nice
__________________
Old 10-19-2008, 12:06 PM   #18 (permalink)
I am guessing with under drive pulleys, headers, exhaust, and a custom tune somewhere around 220/270
Old 10-19-2008, 12:07 PM   #19 (permalink)
Quote:
Originally Posted by fillsrunner4 View Post
Very clean
Very nice
Ya, I need to pick some of that stuff up!
Old 10-19-2008, 12:10 PM   #20 (permalink)
Same here!
Looks great!
__________________
Old 10-25-2008, 08:17 PM   #21 (permalink)
Began working on the cooling system today.
Tru-cool radiator from Speedway and a Flex a lite fan:
Lower Mounts:
I had less room than I thought
About a 1/2" between the water pump and fan:
I went ahead and added some additional bracing on the bottom:
Top mounts, Had to test fit the hood to make sure it was going to close!
Need a upper and lower hose and its done!
(the cooling part anyway. )
Old 12-06-2008, 05:16 PM   #22 (permalink)
texcat101's Avatar
Hey Rocket what are you doing for radiator and fan?
__________________
Old 12-07-2008, 09:49 AM   #23 (permalink)
Trukool radiator and Flexlite fan from Speedway
http://www.speedwaymotors.com/Speedw...hevy,3557.html
http://www.speedwaymotors.com/HEAVY-...-155,1807.html
Old 12-16-2008, 03:53 PM   #24 (permalink)
texcat101's Avatar
C'mon Rocket time for an update.
__________________
Old 02-28-2009, 03:15 PM   #25 (permalink)
Though I would post an update since I haven't done so in a while.
I blocked off the holes for the old A/C lines and added a Lokar transmission dipstick:
The Lokar shifter and center console is all finished:
I have started with the fuel system. I removed the fuel pump from the factory module. I tried to save the factory fitting, but is snapped off . Now I don't know if I should just use a clamp and fuel injection hose or try to put a fitting on there and flare it? I would like to run AN lines all the way up to the fuel rail. The Pump is going to be mounted on the frame. I don't know how high of pressure the line would have before the pump? The line needs over 90 PSI after. That is the reason I am changing all of this and running larger line.
I also fabbed up a bracket for the kickdown cable and hooked up the throttle cable:
I am sure I have done more than that, but I have kinda lost track . Going to get after this in the next few weeks!
Tags
14000, 2002, 2004, 2005, 43, 43l, 4runner, 96, cable, center, compare, consol, disassemble, engine, kick, swap, th350, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2002 4Runner w/99 springs Atwater27 95.5-2004 Tacomas & 96-2002 4Runners 13 10-11-2008 10:07 PM
2002 4Runner ?'s crazyquadrider83 95.5-2004 Tacomas & 96-2002 4Runners 15 03-29-2008 08:35 AM
2002 4runner $14,000 jla123 The Classifieds GraveYard 6 09-24-2007 09:04 AM
New here: Question about 2002 4Runner Mac6135 95.5-2004 Tacomas & 96-2002 4Runners 8 11-03-2004 05:56 AM
2009 InternetBrands, Inc.
