TDSwaps Parts Wanted
I am interested in some TDSwaps parts. I have tried to buy from them, but, they do not return my emails.
I do not need an adapter. Can use the following:
Fuel lines
Gm or Toyota Alternator Bracket
Bracket to relocate MB Power Steering
Throttle Bracket/Mount
Notched Oil Pan
OM617 going into a 94 4Runner that was a V6 automatic. Need motor mounts also.
I know I am missing something. Also open to suggestions if you have a better way to go.
Fuel lines
Notched Oil Pan
Just build tabs for the stock Mercedes motor mounts and make sum limit straps. so thay don't break. you can copy my stuff if u want. probably not selling it though. You might be able to shave down the power steering pump bracket a bit and make it work. i will b selling my oil pan as soon as i sas my runner.
I am Captain Jack from Yakima. Still have not got to my swap. Have all the important part on hand. Work has been a bear and we are preparing to retire in Nov.
509.834.9999. Appreciate hearing from you Waltt.
Hope all is well with you. Did you do the sas? If so, is your notched pan available?
MMA_Alex
25
04-18-2017 05:07 AM
Vargntucson
07-04-2015 12:15 PM
