Diesel Swaps Diesel engines
Swap 3L from Toyota forklift?
Old 08-26-2015, 11:27 AM
Badfish740's Avatar
Just wondering if anyone has done this. The 3L's never made it to the states in any road vehicles (maybe Canada though?) but are supposed to be more stout than the 2Ls, which are prone to cracking heads, and a lot of Toyota forklifts used them. The specs I've seen on the forklift 3L are 75HP @ 4000 RPM and 140 ft/lbs @ 2400 RPM. The 3L in the Hilux was rated the same for torque but 90HP, so the forklift version probably just has the fuel turned down.
At 90HP (and there's probably room for some improvement there too)/140 ft/lbs, performance is not all that different from a 22RE with one key difference. Peak HP and torque occurs 800 RPM lower in both cases. For my purposes, top end really doesn't matter as the truck won't see highway driving much, plus I plan to put 5.71s in it, so acceleration shouldn't be a problem
Old 08-28-2015, 08:12 AM
wyoming9's Avatar
Red face
Be interesting for sure
Would you need to run to the fork lift( Toyota Industrial engines) dealer for parts?/
Does it bolt to the bell housing or do you need to make a custom bell housing
Seems like a major undertaking
Old 08-28-2015, 08:16 AM
Badfish740's Avatar
It bolts up just like a 22RE would, same clutch, flywheel, motor mounts, etc...it came in Hilux pickups with the W56 5 speed pretty much everywhere in the world except here As far parts I guess it depends. I'm willing to bet that a lot of parts are shared with the 2L, which was available here. The 3L just has a different bore and stroke. In fact, you can bolt a 3L head to a 2L or 2LT block which gets around the fact that the 2L/2LT heads are prone to cracking, and supposedly will give a little more power, so I'm leaning toward that.
Old 08-30-2015, 12:40 PM
instantninja's Avatar
You can bolt up a 2LT turbo setup to a 3L and it makes decent power.
You will need an L series bellhousing to bolt it up and a flywheel for the 3L, a 22r flywheel will not bolt up.
The motor mounts bolt up to 22r frame mounts though.
Old 12-08-2016, 05:17 AM
Rustbucket1990's Avatar
where can I find one of these engines,
And, Where can I find a bell housing/ flywheel etc for this?
Old 12-08-2016, 05:18 AM
where can I find a 2lt intake system?
Old 12-08-2016, 06:05 AM
Will My 22re power steering pump, alt, ac etc bolt on w/o modification?
Old 12-08-2016, 02:15 PM
bootscootboogie's Avatar
You can find a lot of the answers you're looking for in the engine swaps section. Check pirate4x4.
Research everything before you buy anything. Instant information awaits ye, praise be to the almighty google!!!
Good luck. Diesel swap.... Mmmm in my dreams!
Old 12-09-2016, 06:18 AM
thanks bootscootboogy
I'll check him out! My 22re died a couple weeks ago, and a diesel has always been on my wish list....(was gonna do a TDI, but that's a lot of work and $$$).... This seems more up my alley.
LittleUgly
15
01-02-2020 01:30 PM
primordialbeast117
12-19-2015 12:23 PM
scott90
10-04-2015 09:21 AM
JookUpVandetti
09-30-2015 08:58 AM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: Swap 3L from Toyota forklift?
