Om617 to toyota wiring/ vacuum
I need help on wiring up my truck its a 1990 pickup that had a 3.0 in it i used the tdswaps kit and i have no idea where i can pull power from for the factory glow plug relay harness any help also how to run the vacuum shut off switch.
I used my alternator wires to run the glow plug realy, it works on mine. for the shutoff i used the vac switch off of the Mercedes adla circut and wired it off the same alt signal wire as the glow plug realy i have the wireing code in my thread.
Glow plug relay wiring
30 (large red) +bat
31 (orange/brown) ground
15 (red-black stripe)start switch (I think can be ign, relay should time out)
50 (red/pink/purple) safety circuit (not needed to run)
LA (white-blue stripe) lamp indicator
30 (large red) +bat
09-04-2015 09:27 AM
