2lt swap
2lt swap
Sry guys, i've not found answers on my question by using search.
I have toyota 4runner '91 with totaly broken 3vz engine. And i have 2lt engine (with wiring). What i need, to swap 2lt into my car? Are 3vz transmission and 2lt engine compatible?
i believe you have to get the diesel bellhousing and swap it out. but the trans should still work.
https://www.yotatech.com/forums/f2/t...98/#post113208
James
and it's to my understanding that bellhousing is really hard to come by. Might be easier to find over there in Europe though, I have no idea. Keep us updated if you decide to do the swap.
and what about engine Brackets? have 2lt and 3vz the same fixing points?
I have 2lt transmission, but i think he's broken =)
But with bellhousing =)
Ok, we'll make photos of the engine swap process.
PS:sry for my bad English - i'm from Russia
The engine brackets I believe you can use the diesel ones but they will have to be moved back on the frame. If the truck was originally a 22R, I think it will bolt right it but yours is not.
