| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
turbo or super charged 22re
#2 (permalink) |
Turbo is factory. Supercharger is expensive and it takes power to make power.
That being said, I think I would go supercharger because it is more on demand than turbo (generally speaking). Factory turbo parts can be found for fairly cheap though.
__________________
Obama is an acronym. OBAMA = One Big Ass Mistake, America |
#3 (permalink) |
if i went turbo i would have to do wireing and my compression is to high but the kits at LCE are both 3000 bucks............and its a instant 64hp gain
#4 (permalink) |
id say turbo cuz its cheaper and would be more worth the HP gain than spending 3000 dollars on a supercharger, when you could use that 3000 for tires, rims, sliders, etc.
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#5 (permalink) |
I ran both both types of forced induction on a 1994 22RE 4x4 5 Speed.
The Camden supercharger that LCE uses in their kit is very old technology, with no bypass valve, like the Eaton/Magnacharger (TRD) does in Tacomas. This lack of bypass valve and the straight cut of the lobes gives it terrible gas mileage. I saw easily as low as 12mpg with the supercharger. A bit of an easier install, though, than the turbo, and great low-end torque. The turbo, with the intercooler, actually improved my combined city/highway gas mileage by about 2 mpg so I was getting about 23-25 mpg. It also pulled way harder at any comparative boost level to the supercharger, probably due to the lack of intake air temps. Install necessitated a local welder to attach the downpipe and wastegate pipe to the exhaust. A much more involved install with much better results. I would recommend getting the CNC'd manifold LCE kit over their tubular-style one. For either, you will have to provide more fuel and be able to retard the timing at anything over about 3-4 psi, at least that's how it was for my truck. It's a lot of money to spend for only 3-4 psi run off of the factory computer. I would suggest LCE's MAF conversion from the later Tacoma 4 cylinders in conjunction with URD's "5th Injector" kit. This will allow you to control fuel and timing. You will need a hi-flow fuel pump as well as a way to monitor the Air/Fuel Ratio. You could also go the stand-alone engine management route, but that requires tuning at a pretty complex level. It's definitely worth it. Boost puts a smile on my face every time.
__________________
2002 TRD Ext Cab Tacoma Auto Complete ICON Suspension with Deaver 8-Leafs |
#6 (permalink) |
If you can't decide, just do both.
Twincharging FTW.
__________________
86 SR5 Turbo pickup Fiberglass bed, Fiberglass Fenders. 91 1.5JZ GT40 Supra. 77 Celica Liftback. (WTB: 20R Carb!) |
#7 (permalink) |
I have a friend who bought a eaton supercharger off of a t bird supercoupe and built a manifold to bolt it on too
he is using supra injectors and maf and a stand alone mega squirt system he built using there kit. I think he is using a supra fuel pump as well. it is all in an 84 celica |
| Tags |
| 22r, 22re, 4runner, 89, 91, charge, eaton, horsepower, kit, manifold, ratio, super, supercharger, toyota, turbo |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Super charged 3.4 finally Pic's included | olharleyman | 86-95 Trucks & 4Runners | 10 | 09-14-2008 03:37 PM |
| Super Charged guys and towing? | Gerdo | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 07-10-2008 11:51 AM |
| ? for super charged 3.4 owners | olharleyman | 86-95 Trucks & 4Runners | 2 | 05-18-2008 05:46 AM |
| 1990 Cherokee 2-DOOR Vs 1990 Toyota 22 R super-charged | BCtoyota | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 03-07-2007 02:39 PM |
| FS: Dynomax Super Turbo muffler | jev2022 | The Classifieds GraveYard | 6 | 05-19-2006 04:02 PM |
