Toyota Engine 4.0 v6 Swap Questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-02-2009, 10:58 AM   #1 (permalink)
how hard is it to put the 4.0l v6 motor in a 95 4runnner. and if it is even possible to do so. frame is off the body. i am doing a sas with the 4link front and rear. what trans and t-case should i use????
rob261 is offline
Old 10-02-2009, 11:08 AM   #2 (permalink)
Send a message via Yahoo to vandert
Alot of people say it's not worth it due to the OBD system's, it is possible but considered harder than any of the v8's but harder than a 3.4 swap so people just go with it. Not ot mention tranny etc...
__________________
04 4Runner - Sold
97 T100 - Sold
86 Runner - Project - Sold
02 Mustang GT Vert - Stuff done, 181 GPS confirmed miles per hour on Autobahn A-5 between Stuttgart and Hockenhiem:) For Sale
92 4Runner 3.slow - little lift, ISR, Dynomax catback, manual hubs conversion, Downey rear springs, more coming count on it...
vandert is offline
Old 10-03-2009, 07:10 PM   #3 (permalink)
would like more info?? Isn't the 4.0 a v6?? I am thinking about the land cruiser motor. or the tundra motor?? Any info would be greatly appreciated.. thank you
rob261 is offline
Old 10-03-2009, 07:58 PM   #4 (permalink)
yeah it is and will fit, but it will be ALOT of work, easier to swap a chevy engine in etc... Search is your freind, soooo many post on this.
__________________
04 4Runner - Sold
97 T100 - Sold
vandert is offline
Old 10-04-2009, 04:03 PM   #5 (permalink)
Ok I did some research on the matter. Found alot of info. Thanks guys... Here is the deal with the runner. I got it with a broken frame. I pulled the motor and sold it. I got his old core in the deal. My plan was at that time to do the 3.4 swap with the trans and t-case I had. I have already got a replacement frame and planned to do the sas. Now I love the advantages of the link suspension and the use of coil overs for the 18" of travel. I am thinking that there should not be any issues with the oil pan and the front dif. I will use the 6 speed with the tacoma t-case putting the drive line on the drivers side. Why I want to use the 4.0 is that motor fully dressed with all fluids only weigh 375# And the 235 bhp. I am wondering how much of the wiring harness I will have to use from the tacoma. I know where I can get a badly wrecked 2007 taco with 23k on it cheap. If anyone has info about what all this involves it would be great. Welding and fab work is no problem for me. Wiring and that stuff can be crazy...
rob261 is offline
Old 10-04-2009, 04:13 PM   #6 (permalink)
RMA
There was a thread here on yotatech on a succsesful 4.0 swap, but I cant find it anymore , search you may have better luck .
If you can get the whole truck cheap and able to customize things with out a big problem , Then Id say go for it .
With the wiring you can download everything you need from toyota TIS ,those diagrams are very detailed and in color .
Good luck and be sure to take alot of pics .
__________________
'89 2wd X-tracab,W55,22re,My DD
'94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD
'88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907,
XRC8, Homemade Roof rack.33x10.50,15 KM2
1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front.
My swap thread
http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/
RMA is offline
Old 10-04-2009, 04:15 PM   #7 (permalink)
RMA
Found it , Have fun reading man !!
http://www.yotatech.com/f2/swapping-...3-0l-v6-53160/
__________________
My swap thread
RMA is offline
Tags
3vze, 40, 97, engine, fit, motor, sale, swap, swapping, t100, toyota, v6, weigh
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
