toyota 4.0 swap
toyota 4.0 swap
anyone swapped in the toyota 4.0 engine tranny into a older toyota 4x4?
im considering the fj cruiser route in my 93 ext pickup with 81 axels.
im sure id need the esc,cluster,harness,engine,tranny and t case....just curious if this has been done before.
its a 240-260 hp v6,manual shift tcase.
thanx!
thanx!
i figued a lift was rquired.
i had a 07 fj,had the 240 horse 4x4 model.....power and acceleration was very impressive.
too bad i couldnt pay the note back then......i miss that bad boy!
my local pull a part has a 06 fj,i may go pull everything i need for under $300.
i believe taco's/some runners of the same years were equipped with the same engines.
edit
info i found on the 4.0
The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. An updated version of this engine features Dual VVT-i, increasing output to 254 hp (189 kW) and 270 lb·ft (366 N·m) on 87 octane and 285 hp (213 kW) and 289 lb·ft (392 N·m) on 91 octane. Inside, the 1GR uses a "taper-squish" combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are two such passages for each bank for a total of four. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
A bolt-on TRD supercharger kit is available on Tacoma, and FJ Cruiser
Applications (with VVT-i) in Model years:
2003-2009 Toyota 4Runner / Hilux Surf (GRN210/215)
2007 Toyota Land Cruiser (GRJ200)
2003-2009 Toyota Land Cruiser Prado (GRJ120/121/125)
2005-2011 Toyota Tacoma (GRN225/245/250/265/270)
2005 Toyota Hilux (GGN10/20)
2005-2006 Toyota Tundra (GSK30)
2007-2010 Toyota Tundra (GSK50/51)
2005 Toyota Fortuner (GGN50/60)
2007-2009 Toyota FJ Cruiser (GSJ10/15)
Applications (with Dual VVT-i) in Model years:
2010-present Toyota 4Runner (GRN280)
2010-present Toyota FJ Cruiser
2009-present Toyota Land Cruiser Prado (GRJ150/155)
2011-present Toyota Tundra (GSK50/51)
edit
Unless the new t-cases are different, when they went to Taco's they went drivers side drop. The 4.0 is huge compared to the 3.4's I have seen a post with a swap done in a desert racetruck setup.
RaginAsian91
07-27-2015 07:11 PM
thelifeadventure
07-02-2015 03:09 PM
