if you lifted your toyota please check if you can answer this - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > Engine Swap Talk > All Other Toyota Swaps
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-11-2009, 04:25 AM   #1 (permalink)
footbalfreak's Avatar
Exclamation if you lifted your toyota please check if you can answer this
i lifted my toyota a little to much and now the drive shaft is to short. if you lifted your toyota can you tell me what you did to solve this problem. will any other drive shafts work from a ford or chevy or will i have to costom order it or get one made. this is one of the few last peices of my puzzle and it would be greatly appreciated if anyone could help out.
footbalfreak is offline
Old 03-11-2009, 12:35 PM   #2 (permalink)
eric-the-red's Avatar
Depensing on what year and model you may be able to use the shaft from another Toyota. Otherwise you can get yours lengthened.
__________________
2001 4Runner
4.30 ratio 1999 e-locked rear axle and front diff;
OME881/N91S front; OME891/N86 rear;
Tundra brake swap;
1" 4Crawler body lift;
63" 4Crawler SliderZ;
TJM T-15 with Warn M8000 winch and Amsteel blue synthetic line;
265/75R16 Nitto TGs or 255/85R16 Truxs MTs;
Cobra 75 WX ST cb;
Alinco DR635 VHF/UHF ham radio;
ham call sign license plates - VE7 EGC
eric-the-red is offline
Old 03-11-2009, 03:37 PM   #3 (permalink)
GSGALLANT's Avatar
You have too many posts with the same question going on at the same time. I think I've counted at least three. When you're posting questions, pick which section of the forum is most appropriate for your question, and post it only there... it helps keep things less cluttered.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 04-14-2009, 06:21 AM   #4 (permalink)
whorider's Avatar
You might be able to try this.
http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Or just have it lengthened, for twice that price.
__________________
I may be dumb but I'm not stupid.
whorider is offline
Old 05-11-2009, 07:15 PM   #5 (permalink)
twitch6989's Avatar
you should try downey drive shafts
twitch6989 is offline
Old 05-26-2009, 10:06 PM   #6 (permalink)
gjms5150's Avatar
what year toyota is it? the ifs toyota's had a longer driveline than the solid axles ones did. I have a 85 with 12" of lift and I just used one out of a 91 4 runner with the 22re engine. otherwise they sell combination u joints so you can use allmost any driveline. if you need any help just get back to me I have lots of great advice and I have been building toyota's for 10 years.
gjms5150 is offline
Tags
10, bc, lifted, toyota, toyotas
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Check this lifted van! project91 95.5-2004 Tacomas & 96-2002 4Runners 24 01-27-2009 11:07 AM
Where can you go with a lifted Toyota? Reverend Off Topic Talk 5 03-20-2008 08:33 PM
1999 4runner Limited - 3.4 SCd - Auto - Elocker - Lifted - CHECK IT OUT!!!!! montypower The Classifieds GraveYard 23 04-27-2007 10:40 PM
check out this lifted civic YeloSub7 Off Topic Talk 18 09-25-2005 09:29 PM
2009 InternetBrands, Inc.
