engine swap 87 to 92 22re - YotaTech Forums
Go Back   > >
All Other Toyota Swaps I4, I6, Lexus V8
LinkBack Thread Tools Search this Thread
Old 09-28-2010, 02:31 AM   #1
Rusted Rooster's Avatar
Hi, Planning an engine swap,, need some tech advice please. putting a 1992 22re in a 1987 truck, what will i need to change or look for?
the 92 is a 22re automatic trans, 2x4, the 87 is 22re 5 speed stickshift 4x4.
I know oil pan, any other changes? thanks guys!
Rusted Rooster is offline   Reply With Quote
Old 09-28-2010, 04:48 AM   #2
94toy4x4fever's Avatar
Is your truck a stick? If so you will need to change the flywheel out. Im sure some of the wiring is different from the 87 to 92. There are alot of things that could be different. I would start with looking at both engines and see what is different between the two!
94toy4x4fever is offline   Reply With Quote
Wiring help toyotamonster 3.4 Swaps 6 12-30-2016 05:38 PM
MMA_Alex's 1990 4Runner Build Thread MMA_Alex 86-95 Trucks & 4Runners (Build-Up Section) 22 06-14-2016 06:58 PM
FS[SouthEast]: Mercury Villager Fan & DCC Fan Controller coryc85 Misc Stuff (Vehicle Related) 6 09-09-2015 07:24 AM
83 pickup lift and engine rebuild God's Bounty Hunter Pre 84 Trucks 6 07-08-2015 01:54 PM
88 4Runner build CJ94yota 86-95 Trucks & 4Runners (Build-Up Section) 2 07-03-2015 11:14 PM
Tags
22r, 22re, 87, 8792, 92, 94, differences, engine, info, motor, oil, pan, qswap, swap, swapping, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
