All Other Toyota Swaps I4, I6, Lexus V8
E-locker swap
Old 05-22-2013, 03:04 PM
blueballs1980's Avatar
E-locker swap
Hello this is Jack, I have a E locker out of a 1998 Tacoma superchargered sr5 ( the hole third member with 4:10 or 11's actualy). Wondering what size third member it is and what axle housing I need to locate? I have a 1980 toyota 4x4 and Iv been told that the third member wont fit so I figured ill just find a Tacoma axle oe anything along those lines. Any help or insight would be greatly appreciated.
Old 08-09-2013, 12:15 PM
85toyman's Avatar
It is an 8" third member. Your axle housing will work, but you will need the use of a metal grinder to make it fit. I suggest that you buy the paper gasket and use it as a template for where you need to make your cuts and you should be good to go.
Old 08-11-2013, 09:46 AM
BigBluePile's Avatar
There's lots of tech on converting axles to house elockers. Just have to search
06-01-2021 01:51 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
GeoRoss
07-24-2015 03:03 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: E-locker swap
