| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Could i swap a 90 4runner engine into a 85 4runner?
#2 (permalink) |
Possible to swap engine from 90 to 85 4runner?
I found an 85 4runner for under $1000 the guy claims the engine just died one day
I have a 1990 4runner with no 4WD could i swap them? How much would it cost? the 85 is in pretty good shape color red my 90 is black messed up when ibought it,the folowing is wrong: windows dont go down and up get badly stuck and cant get them all the way back uplol windshield wipers wont stop needs bumper top and bottom new front and back light (right side) tie rod grill fender back hatchback wont open looks glued shut HAHA for realll pluss drivers seat is stuck in position lol a little too far back for me so can i swap them? how much would it cost and would it be cheaper to swap then to repair the 90? |
#3 (permalink) |
If the 85 had a 22RE and the 90 has one then it should be a simple drop in. if the 85 had a 22r or the 90 has a 3.0 it becomes a bit more difficult.
__________________
Weekend Rig - 85 SR5 Pickup: 4x4, 5-Speed, 22RE, 35/12.50/R15 Mud Brutes Custom built box with big stepside fenders, About 3" body lift Pioneer CD player (iPod Controll) with 10" sub woofer Current Daily Driver - 2000 Corolla
Alpine iDA-X303 Deck Alpine 12" Type X Subwoofer in Ported Box |
#4 (permalink) | |
Make sure the two trucks have the same motor to make it easier. The 85 must either have the 22r or 22re. And I'm guessing your 90 4runner has the 3.0. If it does have the 3.0 most people including me would say its a waste of money because the 3.0 has bad head gasket issues and is underpowered. You'd be better off putting in a newer 3.4 if that is the case but if the 90 4runner has a 22re then yes, I'm pretty sure it would work.
__________________
96' 4Runner SR5 Bone Stock, 100K as of 7-9-09 Quote:
#5 (permalink) |
what if the labor on the swap was going to be free? also how do i check 22re etc
#6 (permalink) |
i have a 4 cylinder
#7 (permalink) | |
If the 85 4runner has a 22re and the 90 4runner has the same motor (22re) then it will work. If the 85 is a carb motor then it might require a little more work.
__________________
#8 (permalink) | |
This is a 22r
![]() And this is a 22re
__________________
#9 (permalink) |
just strip the motor from the 90' down to a long block and swap all your 85' accessories onto it. i put a 22re from a 94' 2wd pickup into my 87'.
__________________
87' ext cab, sas, 36" iroks |
#10 (permalink) |
Then you have a 22re (fuel injected) the 85 may have a 22r (carbureted), If it has fuel injectors, then they should be right next to the block and have EFI engraved on top of them. The motor swap should be virtually bolt on in this case, if it is carbureted, then all you have to do is modify a little and swap out the mounts from your 90 to the 85. Good Luck Man
__________________
-Dave "It is possible to store the mind with a million facts and still be entirely uneducated." Sorry Guys but I am trying chevy for a while, Current Rig- 2000 Chevy S10 ZR2, but I am sure I'll be back! 1990 Deluxe Extended Cab 22RE 5spd, Roll Bar, KC Lites, Flowmaster 50 series- SOLD 1988 4Runner SR5 3.0 3VZE Auto, 31" BFG A/T KO, Bushwhackers, 205,000 miles- SOLD and was driven 4500 miles to Anchorage AK 2003 KTM SX125 |
#11 (permalink) |
Yep, I put an 86 into a 91, And watched a buddy put an 87 22R into a 91 truck w/ EFI while keeping EFI...
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#12 (permalink) |
so what engins are in them currently?
im gonna bet the 90 4runner has a 3.choke, the worst toyota engine ever and the 85 has a 22re, then it wont work, and its not worth the time, but if u got lucky and your 90 4runner has a 22re, then its easy and deffinantly worth it
__________________
i drive by brail. Rock Solid Motorsports http://www.rocksolidmotorsports.net/ http://www.lunatic4x4.org/forums/forumdisplay.php?f=45 |
#13 (permalink) |
The 4Runner will be fuel injected unless its actually an 84
__________________
88 4Runner. 350 V8, R150 5-speed. SAS, 36" TSL's, elocker rear |
#14 (permalink) |
so if this guy is wrong its carb which could only mean its actually an 84 not an 85? otherwise mine and an 85 would be the same?
meaning no modifications and if modifications just some parts off the 90? |
#15 (permalink) |
what kind of modifications will i need to do if my engine is fuel injected and the other is carb?
#16 (permalink) |
okay he said its a 4 cyl just like my 90 is BUT mine is an auto (90) and the 85 is a (stick)
can a swap still be done? and with what modifications? Last edited by dirtymuddtrucks; 04-06-2009 at 08:02 AM. |
#17 (permalink) |
Yot'll need all the electronics (wiring, computer etc.), and the fuel system from the 90.
There is probably more....
__________________
Mostly Stock 90 4Runner SR5 V6 Auto w/ 33" Durango MT's (bent lower valance removed), bush bar w/ 55w Baja Offroad Lights, Custom fit 1st. gen rollbar (used to mount Hi-Lift and fire extinguisher), extended diff breathers, (Comming soon rear spool and 2" body lift..) My very slow buildup on Sontt.com - currently building. http://www.sontt.com/forum/viewtopic...&t=109&start=0 |
#18 (permalink) |
the factory offered carbs up to 89' in some areas. so because it's an 85 doesn't mean it's fuel injection. i had an 88 that was carb'ed. if the 85 is a 22re and the 90 is 22re then yes they will swap easily, some of the sensor plugs will need to be changed, but other than that a very easy swap.
__________________
91 SAS, 22RE, 529's, 35" swamper tsx's, Lincoln Locked Front and Rear, Marfield outers, 8000 lb Warn, passenger side OH HELL handle and the skinny pedal with a magnet on the bottom. 94 stock, 262k miles, 31" bfg Mall terrains |
#19 (permalink) |
#20 (permalink) |
What transmission do you want to use?
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#21 (permalink) |
i guess a auto so my wife could drive it if ever needed, what would need to be done, could you still use the same engine?
#22 (permalink) |
I just swapped in a 92 into my 85 and I just took all of the 85 stuff onto the 92 motor and dumped it in. Runs and works fine. If I was to do it all over again I would have just bought a rebuilt one for a $1000, this motor has oil leaks and what not. I still cant get the damn thing timed right.......
#23 (permalink) | |
Quote:
there should'nt be any mods though. just swapping parts over. the good thing is you've got 2 complete trucks to do this swap. u just gotta' make a decision.... stick or auto EFI or carbureted (if the 85 is carb) Mike |
| Tags |
| 1989, 350, 4runner, 85, 87, 89, 93, bolt, cost, differential, engine, factory, locking, motor, swap |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 88 4runner engine swap | RED1 | 86-95 Trucks & 4Runners | 1 | 04-06-2008 10:50 AM |
| 1991 4Runner body swap or engine/tranny swap? | 91slowrunner | 86-95 Trucks & 4Runners | 2 | 05-21-2007 10:11 PM |
| 90 4runner engine swap | bayou_bandit | General Vehicle Related Topics (Non Year Related) | 4 | 01-25-2007 02:51 PM |
| 4runner engine swap | redneck 4runner | Newbie Tech Section | 3 | 02-09-2006 10:53 AM |
| 85 4runner engine swap | pablo55 | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 05-27-2004 08:13 AM |
